Tubes or no Tubes #1642293
07/05/14 06:53 PM
07/05/14 06:53 PM
K
Kiddart Offline OP
Kiddart  Offline OP
K
Hey guys and gals,
Took the dart out yesterday for a gentle ride around the block with only one very small shot. come to find out somehow my tube valve stem is torn. could have been low air pressure or god knows what. I know my question is very controversial but, should I replace it or should I just go tubeless.
Street/Stip car more street than stip.
thoughts
Thank you
Kiddart
Re: Tubes or no Tubes [Re: Kiddart] #1642294
07/05/14 07:13 PM
07/05/14 07:13 PM
MR_P_BODY Offline
MR_P_BODY  Offline
What tires
Re: Tubes or no Tubes [Re: MR_P_BODY] #1642295
07/05/14 08:56 PM
07/05/14 08:56 PM
SE Michigan
TS3303 Offline
TS3303  Offline
SE Michigan
STREET car no debate, tubes
Re: Tubes or no Tubes [Re: MR_P_BODY] #1642296
07/05/14 09:51 PM
07/05/14 09:51 PM
aotearoa
rebel Offline
rebel  Offline
aotearoa
What tires
what he said
Re: Tubes or no Tubes [Re: rebel] #1642297
07/05/14 09:52 PM
07/05/14 09:52 PM
K
Kiddart Offline OP
Kiddart  Offline OP
K
Tries are
Mickey Thompson ET streets 28 x 10.5 x15
Thank you
Kiddart
Re: Tubes or no Tubes [Re: Kiddart] #1642298
07/05/14 09:56 PM
07/05/14 09:56 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Tries are
I run the ET streets without tubes
Re: Tubes or no Tubes [Re: MR_P_BODY] #1642299
07/05/14 11:14 PM
07/05/14 11:14 PM
Tries are
Me too, 1.42 60 ft on them, 13.5x30x15 Take some shoe polish and mark the tire and rim at the valve stem, when it rotates, slips the tire, on the rim about 4 inches swap (Rotate) the rims and tires on the back side to side and wait for the marks to go to the other 3 to 4 inches pass the valve stem and then swap them again, and again each time they move that much
Re: Tubes or no Tubes [Re: Cab_Burge] #1642300
07/05/14 11:46 PM
07/05/14 11:46 PM
aotearoa
rebel Offline
rebel  Offline
aotearoa
unless they used some super slippery lube to make the tire slip over the bead, they probably wont get back to the stem mark after you've swapped them over. I've run multiple sets of ET Streets, never saw a set get back before the tire was worn out.
Re: Tubes or no Tubes [Re: rebel] #1642301
07/06/14 12:11 AM
07/06/14 12:11 AM
baldwinsville new york
a493demon Offline
a493demon  Offline
use dawn liquid on the inside of the tire.
high tack on the bead and good to go .
Re: Tubes or no Tubes [Re: a493demon] #1642302
07/06/14 12:35 AM
07/06/14 12:35 AM
MR_P_BODY Offline
MR_P_BODY  Offline
ET Streets are a street tire and dont call for tubes
or any dish soap.. you can use glue or high tack on
the bead... I didnt bother because you tend to run
more air pressure and that helps them from slipping
Re: Tubes or no Tubes [Re: Cab_Burge] #1642303
07/06/14 11:22 AM
07/06/14 11:22 AM
Az
Crizila Offline
Crizila  Offline
Az
Tries are
what I do.
Fastest 300
Re: Tubes or no Tubes [Re: Crizila] #1642304
07/06/14 11:42 AM
07/06/14 11:42 AM
Toronto
mshred Offline
mshred  Offline
Toronto
If they are the ET street Bias ply tires, I believe they do call for tubes.
I ran the 28x12.50's without tubes for 2 seasons on the street and strip with no issues...However, tires would spin bit by bit on launch, so I do recommend some rim screws
Re: Tubes or no Tubes [Re: mshred] #1642305
07/06/14 12:58 PM
07/06/14 12:58 PM
K
Kiddart Offline OP
Kiddart  Offline OP
K
Thanks everyone. I am going to try them without tubes. whats the worse thing that happens. My tire goes flat in my garage?? I know the whole track thing can bit me in the but. I think I can save the $70 on a new tube and buy a new HHR fan.
Thanks a million.
Thank you
Kiddart
Re: Tubes or no Tubes [Re: Kiddart] #1642306
07/07/14 10:33 AM
07/07/14 10:33 AM
Sweet Home Alabama
MRMOPAR622 Offline
MRMOPAR622  Offline
Sweet Home Alabama
No Tubes,No Screws
"To Be The Man'You Have Got To Beat The Man" "T/D and Pro-Bracket Racer"
Re: Tubes or no Tubes [Re: MRMOPAR622] #1642307
07/07/14 10:37 AM
07/07/14 10:37 AM
K
Kiddart Offline OP
Kiddart  Offline OP
K
I know a lot of guys run no tubes no screws. Will be heading to McCormicks this week so they can take the tubes out and rebalance.
Thank you
Kiddart
Re: Tubes or no Tubes [Re: Kiddart] #1642308
07/07/14 01:37 PM
07/07/14 01:37 PM
Sweet Home Alabama
MRMOPAR622 Offline
MRMOPAR622  Offline
Sweet Home Alabama
When you have them take the tubes out make sure where the bead of the tire seats on the rim is clean.They also need to be smooth free of any nicks and if clean and you will not have a problem with them losing air.
PS if you can feel a nick or scratch on the inside of wheel lip where the tire seats it needs to be sanded/filed smooth or some times a coat of $.99 Wal-Mart spray paint will make it smooth.When you hear someone complain about their tires losing air 99.99% of the time that is the problem.
