Tubes or no Tubes
#1642293
07/05/14 06:53 PM
07/05/14 06:53 PM
Posts: 1,552 Michigan
Kiddart
Hey guys and gals,
Took the dart out yesterday for a gentle ride around the block with only one very small shot. come to find out somehow my tube valve stem is torn. could have been low air pressure or god knows what. I know my question is very controversial but, should I replace it or should I just go tubeless. Street/Stip car more street than stip.
thoughts
Thank you Kiddart
Re: Tubes or no Tubes
[Re: rebel]
#1642297
07/05/14 09:52 PM
07/05/14 09:52 PM
Kiddart
Tries are
Mickey Thompson ET streets 28 x 10.5 x15
Thank you Kiddart
[Re: Kiddart]
#1642298
07/05/14 09:56 PM
07/05/14 09:56 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Tries are
I run the ET streets without tubes
[Re: MR_P_BODY]
#1642299
07/05/14 11:14 PM
07/05/14 11:14 PM
Posts: 43,228 Bend,OR USA
Cab_Burge
Tries are
Me too, 1.42 60 ft on them, 13.5x30x15 Take some shoe polish and mark the tire and rim at the valve stem, when it rotates, slips the tire, on the rim about 4 inches swap (Rotate) the rims and tires on the back side to side and wait for the marks to go to the other 3 to 4 inches pass the valve stem and then swap them again, and again each time they move that much
[Re: a493demon]
#1642302
07/06/14 12:35 AM
07/06/14 12:35 AM
MR_P_BODY
use dawn liquid on the inside of the tire. high tack on the bead and good to go .
ET Streets are a street tire and dont call for tubes or any dish soap.. you can use glue or high tack on the bead... I didnt bother because you tend to run more air pressure and that helps them from slipping
[Re: mshred]
#1642305
07/06/14 12:58 PM
07/06/14 12:58 PM
Kiddart
Thanks everyone. I am going to try them without tubes. whats the worse thing that happens. My tire goes flat in my garage?? I know the whole track thing can bit me in the but. I think I can save the $70 on a new tube and buy a new HHR fan. Thanks a million.
Thank you Kiddart
[Re: Kiddart]
#1642308
07/07/14 01:37 PM
07/07/14 01:37 PM
Posts: 2,008 Sweet Home Alabama
MRMOPAR622
Sweet Home Alabama
When you have them take the tubes out make sure where the bead of the tire seats on the rim is clean.They also need to be smooth free of any nicks and if clean and you will not have a problem with them losing air.
PS if you can feel a nick or scratch on the inside of wheel lip where the tire seats it needs to be sanded/filed smooth or some times a coat of $.99 Wal-Mart spray paint will make it smooth.When you hear someone complain about their tires losing air 99.99% of the time that is the problem.
"To Be The Man'You Have Got To Beat The Man"
"T/D and Pro-Bracket Racer"
