Re: Big block cylinder head castings post [Re: Dunnuck Racing] #1641014
07/31/14 11:32 AM
07/31/14 11:32 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
When somebody asks about port size, it is simply easier to say standard 440 port size, or Max wedge port size than it is to list every engine that came with a non Max Wedge port.
Keith
That is what I think when someone asks about port size too.
Thanks for sharing the info.
Re: Big block cylinder head castings post [Re: sasquatch] #1641015
07/31/14 01:10 PM
07/31/14 01:10 PM
Graz, Austria
DGS Offline
DGS  Offline
Graz, Austria
Thought you would like to see some internals.
INTAKE view...
They look pretty for sure..
Re: Big block cylinder head castings post [Re: Dunnuck Racing] #1641016
08/01/14 12:08 PM
08/01/14 12:08 PM
long time lurker, short time p...
P
PorkyPig Offline
PorkyPig  Offline
P
Next time one of you guys who are in contact w/ the Proheaders folks get to bring it up, how about they "find" a modern chamber design for this head. I don't get it why they go to the trouble to "fine tune" something and ignore the obvious technical throwback.
Or maybe come up with an "improved" Indy EZ-type head where the stupid lip in the intake runner is filled in so it can actually be used as a standard-port head.
Re: Big block cylinder head castings post [Re: Dunnuck Racing] #1641017
08/01/14 11:37 PM
08/01/14 11:37 PM
NC, USA
davenc Offline
davenc  Offline
NC, USA
The off the seat flow on the exhaust side is better on the E-RPM both in stock and ported form. Is this low flow area not as important on the exhaust side? Any thoughts on why the RPM is better in this area?
Re: Big block cylinder head castings post [Re: davenc] #1641018
08/04/14 01:05 AM
08/04/14 01:05 AM
Northern Indiana
Dunnuck Racing Offline OP
Northern Indiana
The way the top cut transitions into the chamber is is a little different. I personally wouldn't worry about it if I was going to spec a cam for the combination. The low lift exhaust flow would make scavenging a little easier but could easily be made up for.
It wouldn't take much to make it match the RPM head there.
The Sidewinder could easily go bigger than I have done here but these are at a level I want for the street engine they go with.
Keith
Re: Big block cylinder head castings post [Re: Dunnuck Racing] #1641019
09/11/14 04:45 AM
09/11/14 04:45 AM
Graz, Austria
DGS Offline
DGS  Offline
Graz, Austria
Keith,
how's the testing coming along?
Re: Big block cylinder head castings post [Re: DGS] #1641020
09/12/14 02:05 AM
09/12/14 02:05 AM
North Carolina
sasquatch Offline
sasquatch  Offline
North Carolina
Ours is going fine. We have sold to date almost 20 sets with ZERO returns or problems. While we have several running at the moment we have not dynoed one yet but I should have that chance within the next two weeks. Nothing crazy but should be pretty sporty.
Todd
Re: Big block cylinder head castings post [Re: sasquatch] #1641021
09/12/14 07:09 AM
09/12/14 07:09 AM
Graz, Austria
DGS Offline
DGS  Offline
Graz, Austria
Todd
Are these ported or ootb? Looking forward to seeing a few numbers
Re: Big block cylinder head castings post [Re: sasquatch] #1641022
09/14/14 04:20 PM
09/14/14 04:20 PM
Shannonville, Ont
Blown 68 R/T Offline
Shannonville, Ont
Keith/Todd
Been looking at these & ProMaxx, was wondering if they would hold up to a high spring pressure(750+) Procharger boosted application. Wondering if the weak link would be in the shaft mounts??
Re: Big block cylinder head castings post [Re: Blown 68 R/T] #1641023
09/14/14 11:10 PM
09/14/14 11:10 PM
south carolina U.S.
DOUGG Offline
DOUGG  Offline
south carolina U.S.
I bought a set (sidewinders) from marsh performance 3 weeks ago. Installed them on mild 383/ 9.5 comp,headers,750 holley, 478/494 lift cam(mild).WOW!!! Couldn't be be happier with my setup. 65 b-body/373 gears. This thing is now the beast I wanted it to be.
Re: Big block cylinder head castings post [Re: DOUGG] #1641024
09/15/14 12:25 AM
09/15/14 12:25 AM
North Carolina
sasquatch Offline
sasquatch  Offline
North Carolina
If you go back up this thread to the cutaways, I believe with a .060 cup or locator you could run 750 open pressure as far as the spring seat is concerned. That is a load on ANY aftermarket heads stands. You can look at the structure under them but that is a lot. You could helicoil them ( no big deal) and help a little. Heck even the VIctors had trouble with that with that kind of spring pressure.
Todd
Re: Big block cylinder head castings post [Re: DGS] #1641025
09/15/14 11:04 AM
09/15/14 11:04 AM
Northern Indiana
Northern Indiana
Sorry guys, I left Wednesday evening for Monster Mopar at Norwalk and haven't been on here much.
I have a test engine on the dyno with iron heads and will be doing some back to back testing soon.
Keith
Re: Big block cylinder head castings post [Re: Dunnuck Racing] #1641026
10/14/14 11:38 PM
10/14/14 11:38 PM
Shannonville, Ont
Shannonville, Ont
Any updates on these Sidewinders Keith?
Re: Big block cylinder head castings post [Re: Blown 68 R/T] #1641027
10/14/14 11:53 PM
10/14/14 11:53 PM
Northern Indiana
Northern Indiana
I'm testing a few different combinations using the Sidewinder heads. First up was a back to back with a mild hydraulic cam versus 915 heads.
I'm testing them in ported form right now, with a couple different solid camshaft. I'll be posting results in the next day or so.
But I can say, so far so good! They are looking like a great option.
Keith
Re: Big block cylinder head castings post [Re: Blown 68 R/T] #1641028
10/14/14 11:57 PM
10/14/14 11:57 PM
Northern Indiana
Northern Indiana
In the next day or so, I will post some results up. I have been testing a few different combinations with them and am finishing up now with ported heads and a couple of solid cams. So far they are looking like a real nice option!
Keith
Re: Big block cylinder head castings post [Re: Dunnuck Racing] #1641029
11/07/14 06:11 PM
11/07/14 06:11 PM
Easton, Minnesota
gpuller Offline
gpuller  Offline
Easton, Minnesota
Are these angled plug heads? Any troubles with ordinary headers fitting?
Re: Big block cylinder head castings post [Re: Dunnuck Racing] #1641030
02/07/15 04:52 PM
02/07/15 04:52 PM
Nebraska
451Cuda Offline
451Cuda  Offline
Nebraska
Keith
Any more updates on these heads? Really interested.
