Big block cylinder head castings post #1640994
07/02/14 11:59 AM
07/02/14 11:59 AM
Northern Indiana
Dunnuck Racing Offline OP
Northern Indiana
I am starting this post to try and help clear up some confusion. There have been a few posts about various new big block heads and people seem to be confused on if they are all the same.
There are some new castings being sold by several builderst that are,members here, other castings by Procomp, and yet a different casting on EBay.
The heads the builders here have been working with I was told will be called " Sidewinder"heads.
Although they look similar to some popular heads, they have some well thought out upgrades in the castings
I was lucky enough to get a set of these castings to review and work with and thought I would share some results
I compared them to Edelbrock RPM out of the box heads and then used the same Edelbrock valves so the comparison would not be skewed by any trick valves changing flow.
First numbers are RPM heads untouched, second is a Sidewinder untouched.
Keith
Re: Big block cylinder head castings post [Re: Dunnuck Racing] #1640995
07/02/14 12:11 PM
07/02/14 12:11 PM
Northern Indiana
Northern Indiana
With nothing more than a minor bowl blend and rich up of the valve seats flow was over 290 cfm.
Keith
Re: Big block cylinder head castings post [Re: Dunnuck Racing] #1640996
07/02/14 12:18 PM
07/02/14 12:18 PM
Northern Indiana
Northern Indiana
Blended pic.
Keith
Re: Big block cylinder head castings post [Re: Dunnuck Racing] #1640997
07/02/14 12:24 PM
07/02/14 12:24 PM
Northern Indiana
Northern Indiana
I then opened up the pushrod pinch, cleaned up the common wall, reshaped the roof and bowl area slightly to where I would normally push an RPM casting
Keith
Re: Big block cylinder head castings post [Re: Dunnuck Racing] #1640998
07/02/14 12:35 PM
07/02/14 12:35 PM
Northern Indiana
Northern Indiana
Here is a comparison of a heavily ported RPM head versus what some basic work on the Sidewinder casting did for flow. I have half as much time in getting these castings to this point as I do when porting an RPM head.
I have no doubt there is more flow available in them but these received a level of work that will work great on a hot street engine they will be run on.
Thanks to Todd at CompWedge Engines for giving me an opportunity to look at these, I will be selling a few sets when all the testing is done.
I will keep people updated as the build is soon to be done and when it is I will do some dyno testing and compare these to nice set of Iron heads.
Keith
Re: Big block cylinder head castings post [Re: Dunnuck Racing] #1640999
07/02/14 12:46 PM
07/02/14 12:46 PM
Graz, Austria
DGS Offline
DGS  Offline
Graz, Austria
Thanks Keith for posting the numbers on these heads! Looks like most improvement is at lower lift which should work well for a street engine.
Will you be posting the heads here (when you sell them) or do I need to e-mail you? I'm very interested in a ported set!
Stefan
Re: Big block cylinder head castings post [Re: Dunnuck Racing] #1641000
07/02/14 12:57 PM
07/02/14 12:57 PM
Canada
CTD5.9 Offline
CTD5.9  Offline
Canada
I'm not sure what's more exciting, these heads potential or that there are so many new castings for BB Mopar heads kicking around that there is confusion. Thanks for sharing this with us.
Re: Big block cylinder head castings post [Re: DGS] #1641001
07/02/14 12:58 PM
07/02/14 12:58 PM
Northern Indiana
Northern Indiana
I'm not positive on my pricing yet but these castings with and without porting will be available through CompWedge and Marsh Performance also. I think there will be a couple other dealers I'm just not sure who at this point.
I just wanted to get a few numbers out there to show how nice they are
The low and mid lift flow is really good on them and I'm sure with more work upper lift could be improved upon. I just didn't want to get to big of a cross section on this set as they are going in a heavy street car.
Keith
Re: Big block cylinder head castings post [Re: Dunnuck Racing] #1641002
07/02/14 01:06 PM
07/02/14 01:06 PM
Nebraska
451Cuda Offline
451Cuda  Offline
Nebraska
Are the ports 440 sized? Raised at all? What cc chamber and runner?
Very interested for a mild 383 I have that currently has stock 516's.
Re: Big block cylinder head castings post [Re: 451Cuda] #1641003
07/02/14 01:37 PM
07/02/14 01:37 PM
Northern Indiana
Northern Indiana
They are a standard.440 port size. I will have to pour a chamber and measure it but it looks to be around the same as an RPM head @ 84 cc. I will update when I know for sure.
Keith
Re: Big block cylinder head castings post [Re: Dunnuck Racing] #1641004
07/02/14 02:16 PM
07/02/14 02:16 PM
West Palm Beach, Florida
Copper Dart Offline
Copper Dart  Offline
Common sense, the least common of all the senses.
Mom.
For fear of ridicule, society stifles creativity.
Ricky Valdes
Re: Big block cylinder head castings post [Re: Copper Dart] #1641005
07/02/14 04:47 PM
07/02/14 04:47 PM
dogdays Offline
dogdays  Offline
Back in the day, even in Nebraska, 383s and 440s came with the same head castings. So all the ports were the same in any model year. There isn't any such thing as 440-sized or 383-sized ports. It's not like the chevy world.
Exception: In 1967 there was the 516 head and the 915 head, these were a little different in flow, and there were some 915s that had larger exhaust valves than other 915s.
There are probably some other examples that nit-pickers will focus on, so be it. One of the reasons that I like Mopars so much is that when you buy a 440 from a '69 New Yorker, it has the same head, crank, block and rods as the high-performance ones. You need to change camshaft, carburetor and exhaust manifolds. A double roller timing set and a heavy duty set of valve springs complete the transformation from regular performance to high performance.
R.
Re: Big block cylinder head castings post [Re: Dunnuck Racing] #1641006
07/02/14 05:03 PM
07/02/14 05:03 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
Thanks for the info. I may have to buy a set to play with.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Big block cylinder head castings post [Re: dogdays] #1641007
07/02/14 05:41 PM
07/02/14 05:41 PM
Northern Indiana
Northern Indiana
When somebody asks about port size, it is simply easier to say standard 440 port size, or Max wedge port size than it is to list every engine that came with a non Max Wedge port.
Keith
Re: Big block cylinder head castings post [Re: Dunnuck Racing] #1641008
07/30/14 12:55 PM
07/30/14 12:55 PM
Graz, Austria
DGS Offline
DGS  Offline
Graz, Austria
Hi Keith,
did you do any further testing/porting?
Re: Big block cylinder head castings post [Re: DGS] #1641009
07/30/14 01:30 PM
07/30/14 01:30 PM
Northern Indiana
Northern Indiana
Actually, I have a set on the porting bench right now. Todd from CompWedge Engines and I are doing a joint venture of sorts with them. I will have a nice street/ strip 440 going on my dyno in the near future with a set of these Sidewinder heads to see how everything works out.
I hope to get some e.t. numbers shortly thereafter.
I'll update everyone as soon as I have more to tell.
Keith
Re: Big block cylinder head castings post [Re: Dunnuck Racing] #1641010
07/31/14 02:14 AM
07/31/14 02:14 AM
North Carolina
sasquatch Offline
sasquatch  Offline
North Carolina
Thought you would like to see some internals.
INTAKE view...
Re: Big block cylinder head castings post [Re: sasquatch] #1641011
07/31/14 02:15 AM
07/31/14 02:15 AM
North Carolina
sasquatch Offline
sasquatch  Offline
North Carolina
exhaust view....
Re: Big block cylinder head castings post [Re: dogdays] #1641012
07/31/14 03:19 AM
07/31/14 03:19 AM
Nebraska
451Cuda Offline
451Cuda  Offline
Nebraska
R.
You're preachin to the choir buddy. Learned all that trivia when I got into Mopars in the mid 80's.
It's just easier to type "440" ports than "standard wedge" ports...just like "max wedge" is abbreviated as "MW". There's no misunderstanding, just lazy typing
Re: Big block cylinder head castings post [Re: Dunnuck Racing] #1641013
07/31/14 03:20 AM
07/31/14 03:20 AM
Nebraska
451Cuda Offline
451Cuda  Offline
Nebraska
Keith
Would love to hear how they run in the real world.
