Re: six pack rods
[Re: 71blackdemon]
#1640832
07/01/14 11:58 PM
07/01/14 11:58 PM
RapidRobert
They're a bit heavier/beefier than std rods & I always thought significantly but a guy just recently posted that they ain't too bad, just slightly heavier. HF has a gram scale on sale for less than ten bucks if you're figuring your bobweights and you can see what the difference is & you can trim the top/bottom pads reasonably, just sayin
Re: six pack rods
[Re: topside]
#1640834
07/02/14 04:24 AM
07/02/14 04:24 AM
Posts: 43,292 Bend,OR USA
Cab_Burge
I prefer the standard "LY" rod, did 2 performance builds with them. 6-pack rods are heavier and harder on the fasteners. I don't like the heavy TRW pistons, either. Lighter recip weight is the direction to take.
I've built a bunch of stock stroke bracket motors with the heavy firged TRW race pistons and both LY and 6 pak rods, the six pak rod motors run out of steam about 500 RPM before the same motor combination with a set of LY rods do Sell the sixpak rods and buy a set of the better, lighter, stronger H beam forged steel race rods ![](/ubbthreads/images/graemlins/Twocents.gif)
Re: six pack rods
[Re: 71blackdemon]
#1640835
07/02/14 12:59 PM
07/02/14 12:59 PM
Posts: 15,134 Kelowna, B.C. Canada
DPelletier
is the rods out of a 70 440 sixpack motor the same as the rods out of a standard 440 thanks.
Yes; all '70 - '75 440 HP's use the misnamed "six pack" rods. Also, modern lightweight rods are obviously better but the "six pack" rods (with good bolts) are stronger than LY's and the slight difference in weight can be more than offsett by using a modern lightweight piston (which is where the REAL weight is). ...still, no reason to use them if you don't need to.
More info here; http://www.440source.com/stockrods.htm
1970 Super Bee 440 Six Pack
1974 'Cuda
2008 Ram 3500 Diesel
2006 Ram 3500 Diesel
2004.5 Ram 2500 Diesel
2003 Ram 3500 Diesel
2006 Durango Limited
[url] http://1970superbee.piczo.com [/url]
