six pack rods #1640831
07/01/14 11:04 PM
07/01/14 11:04 PM
Kentucky
71blackdemon Offline OP
Kentucky
is the rods out of a 70 440 sixpack motor the same as the rods out of a standard 440 thanks.
Re: six pack rods [Re: 71blackdemon] #1640832
07/01/14 11:58 PM
07/01/14 11:58 PM
They're a bit heavier/beefier than std rods & I always thought significantly but a guy just recently posted that they ain't too bad, just slightly heavier. HF has a gram scale on sale for less than ten bucks if you're figuring your bobweights and you can see what the difference is & you can trim the top/bottom pads reasonably, just sayin
Re: six pack rods [Re: RapidRobert] #1640833
07/02/14 03:07 AM
07/02/14 03:07 AM
A collage of whims
topside Offline
topside  Offline
A collage of whims
I prefer the standard "LY" rod, did 2 performance builds with them. 6-pack rods are heavier and harder on the fasteners. I don't like the heavy TRW pistons, either. Lighter recip weight is the direction to take.
Re: six pack rods [Re: topside] #1640834
07/02/14 04:24 AM
07/02/14 04:24 AM
I've built a bunch of stock stroke bracket motors with the heavy firged TRW race pistons and both LY and 6 pak rods, the six pak rod motors run out of steam about 500 RPM before the same motor combination with a set of LY rods do Sell the sixpak rods and buy a set of the better, lighter, stronger H beam forged steel race rods
Re: six pack rods [Re: 71blackdemon] #1640835
07/02/14 12:59 PM
07/02/14 12:59 PM
Kelowna, B.C. Canada
DPelletier Offline
DPelletier  Offline
Yes; all '70 - '75 440 HP's use the misnamed "six pack" rods. Also, modern lightweight rods are obviously better but the "six pack" rods (with good bolts) are stronger than LY's and the slight difference in weight can be more than offsett by using a modern lightweight piston (which is where the REAL weight is). ...still, no reason to use them if you don't need to.
More info here; http://www.440source.com/stockrods.htm
1970 Super Bee 440 Six Pack 1974 'Cuda 2008 Ram 3500 Diesel 2006 Ram 3500 Diesel 2004.5 Ram 2500 Diesel 2003 Ram 3500 Diesel 2006 Durango Limited [url] http://1970superbee.piczo.com [/url]
