K&R Pro Cube delay box #1640593
07/01/14 01:15 AM
07/01/14 01:15 AM
Down under
slantman Offline OP
slantman  Offline OP
Down under
Does anyone have any experience using a K&R Procube delay box? I'm looking at installing either one of these or a Biondo Mega450 in the race car I'm building. Any advice or recommendations would be appreciated, thanks.
Re: K&R Pro Cube delay box [Re: slantman] #1640594
07/01/14 01:23 AM
07/01/14 01:23 AM
ky
68roadrunner Offline
ky
i have not used one, several mega boxes, but there are alot of those k&r boxes around. i did talk to kevin about a wiring kit and he was very nice and helpfull
Re: K&R Pro Cube delay box [Re: 68roadrunner] #1640595
07/01/14 01:30 AM
07/01/14 01:30 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Same here... I have a mega 400 in the car.. I cant
help with any info on a K&R box
Re: K&R Pro Cube delay box [Re: MR_P_BODY] #1640596
07/01/14 02:13 AM
07/01/14 02:13 AM
Middletown, Ohio
Joes66dart Offline
Joes66dart  Offline
Middletown, Ohio
I have a KR cube and love it. Its simple to use and the toggle switches make it easy to use with gloves on. Its been in my car for two years now and i have not had any issues with it at all.
Re: K&R Pro Cube delay box [Re: Joes66dart] #1640597
07/01/14 09:38 AM
07/01/14 09:38 AM
Mid west
Gearhead383 Offline
Gearhead383  Offline
Mid west
I have one also. Love it. Very quick and easy to make last second changes and I don't have to get out the manual to "relearn" the box in the spring when racing season kicks off.
Re: K&R Pro Cube delay box [Re: Gearhead383] #1640598
07/01/14 01:19 PM
07/01/14 01:19 PM
sg66mopar Offline
sg66mopar  Offline
I also have the "cube" and agree with the above statements.
I mostly run Super Gas and when the tech inspectors see I have the K&R box they don't waste time looking at any of my wiring.
Re: K&R Pro Cube delay box [Re: sg66mopar] #1640599
07/02/14 01:45 AM
07/02/14 01:45 AM
ky
ky
the tach wire is legal(nhra) on the mega 450 box now, not sure if it needs to be routed separate or not.
Re: K&R Pro Cube delay box [Re: 68roadrunner] #1640600
07/02/14 05:27 AM
07/02/14 05:27 AM
Poulsbo, WA
ChrisJohnston669 Offline
Poulsbo, WA
I have used biondo and dedenbear and now have a pro cube in the charger. It's the only box I'll ever use now.
Re: K&R Pro Cube delay box [Re: ChrisJohnston669] #1640601
07/02/14 10:08 AM
07/02/14 10:08 AM
Arlington, Tx.
BJS racing Offline
BJS racing  Offline
Arlington, Tx.
I have put a many K&R boxes in cars when I was building race cars. Very simple hook up and if you are using the K&R wiring and switch panel its even easier. Great product and if I was going to build a delay box car the only choice in my opinion.
Back in the swing of things at Painless again! Great to be back!
Re: K&R Pro Cube delay box [Re: BJS racing] #1640602
07/02/14 11:30 AM
07/02/14 11:30 AM
Highland beach Fl
P
poisondart2 Offline
poisondart2  Offline
P
Highland beach Fl
K&R is outstanding and the wiring is grest plus any questions about the box ,wiring call Kevin and he will walk you through it
Re: K&R Pro Cube delay box [Re: slantman] #1640603
07/02/14 12:41 PM
07/02/14 12:41 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
I ran the K&R also for a couple years, it worked flawless for me.
Re: K&R Pro Cube delay box [Re: BJS racing] #1640604
07/02/14 01:48 PM
07/02/14 01:48 PM
Q
Quicktree Offline
Quicktree  Offline
Q
have one in my arrow now, wouldn't think about anything else
Re: K&R Pro Cube delay box [Re: Quicktree] #1640605
07/03/14 12:36 AM
07/03/14 12:36 AM
Down under
slantman Offline OP
slantman  Offline OP
Down under
Sold on the K&R, especially since I already have their wiring kit. Thanks guys.
Re: K&R Pro Cube delay box [Re: slantman] #1640606
07/03/14 02:09 AM
07/03/14 02:09 AM
Sunnyvale, CA
Jeepmon Offline
Jeepmon  Offline
Sunnyvale, CA
Doing a quick search, there is about 5 or 6 different models... which one do you all prefer?
Re: K&R Pro Cube delay box [Re: Jeepmon] #1640607
07/03/14 04:05 AM
07/03/14 04:05 AM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Biondo 450 here for me. Easy to use, the tach wiring is now allowed so you can get some easy data logging which is a very nice option. Especially if you are running a .90 program.
Re: K&R Pro Cube delay box [Re: Jeepmon] #1640608
07/04/14 08:59 PM
07/04/14 08:59 PM
communist bloc of new jersey
jamesc Offline
jamesc  Offline
choose the one you need. basically the same box just different features mostly timers.
i've used dedenbear, biondo (digital delay) and K&R. they're all good products with pros and cons use what you like
http://www.krperformance.com/item--PCT0---PRO-CUBE--pro_cube.html
Re: K&R Pro Cube delay box [Re: Al_Alguire] #1640609
07/05/14 12:49 AM
07/05/14 12:49 AM
Morrow, OH
markz528 Offline
markz528  Offline
Morrow, OH
Can you clarify what that means? I know that the year I bought my box I could not run a wire from the msd to the delay box so I had to use an external rpm box to fire the shifter.
Is that what you are referring to? How does that apply to a data logger?
Re: K&R Pro Cube delay box [Re: markz528] #1640610
07/05/14 02:39 AM
07/05/14 02:39 AM
ky
ky
running the tach wire from the msd to the delay box enables the delay box to record rpm of the whole run, you can see your shift point and converter info
