Re: K&R Pro Cube delay box
[Re: 68roadrunner]
#1640595
07/01/14 01:30 AM
07/01/14 01:30 AM
Posts: 52,972 Romeo MI
MR_P_BODY
i have not used one, several mega boxes, but there are alot of those k&r boxes around. i did talk to kevin about a wiring kit and he was very nice and helpfull
Same here... I have a mega 400 in the car.. I cant help with any info on a K&R box
[Re: sg66mopar]
#1640599
07/02/14 01:45 AM
07/02/14 01:45 AM
Posts: 877 ky
68roadrunner
ky
I also have the "cube" and agree with the above statements.
I mostly run Super Gas and when the tech inspectors see I have the K&R box they don't waste time looking at any of my wiring.
the tach wire is legal(nhra) on the mega 450 box now, not sure if it needs to be routed separate or not.
[Re: ChrisJohnston669]
#1640601
07/02/14 10:08 AM
07/02/14 10:08 AM
Posts: 2,224 Arlington, Tx.
BJS racing
Arlington, Tx.
I have put a many K&R boxes in cars when I was building race cars. Very simple hook up and if you are using the K&R wiring and switch panel its even easier. Great product and if I was going to build a delay box car the only choice in my opinion.
Back in the swing of things at Painless again! Great to be back!
[Re: BJS racing]
#1640604
07/02/14 01:48 PM
07/02/14 01:48 PM
Quicktree
have one in my arrow now, wouldn't think about anything else
[Re: Jeepmon]
#1640607
07/03/14 04:05 AM
07/03/14 04:05 AM
Posts: 19,367 Las Vegas
Al_Alguire
Las Vegas
Biondo 450 here for me. Easy to use, the tach wiring is now allowed so you can get some easy data logging which is a very nice option. Especially if you are running a .90 program.
[Re: markz528]
#1640610
07/05/14 02:39 AM
07/05/14 02:39 AM
Posts: 877 ky
68roadrunner
ky
Can you clarify what that means? I know that the year I bought my box I could not run a wire from the msd to the delay box so I had to use an external rpm box to fire the shifter.
Is that what you are referring to? How does that apply to a data logger?
running the tach wire from the msd to the delay box enables the delay box to record rpm of the whole run, you can see your shift point and converter info
