Page 2 of 3 1 2 3
Re: Motor carnage pictures, UGLY! [Re: Cab_Burge] #1639012
06/27/14 05:43 PM
06/27/14 05:43 PM
Washington State
lorenr Offline
lorenr  Offline
Washington State
That internal oil pickup looks suspect. Did the rod bearing look like it wasn't getting oil?
I would suspect that a heavy car like that with a 500 cu in engine would need a pretty good external oiling system.
Loren
Re: Motor carnage pictures, UGLY! [Re: lorenr] #1639013
06/27/14 06:21 PM
06/27/14 06:21 PM
Q
Quicktree Offline
Quicktree  Offline
Q
I wouldn't even consider a crank thats been though that even if it did CLean up
Re: Motor carnage pictures, UGLY! [Re: lorenr] #1639014
06/27/14 06:27 PM
06/27/14 06:27 PM
Cab_Burge Online work OP
Cab_Burge  Online Work OP
Loren
The stock 3/8 internal pickup was hit by one of the rod pieces, it is really bent up in the pictures I had positioned it on the bottom of the oil pan with 1/8 inch clearances between the back edge of the pickup and the front edge of the pickup touching the bottom of the oil pan I run loose bearing clearances, .003+ on the rods and mains, I only use main bearings with full grooves All the other rod and main bearings look really good for a motor that started off in 1998 as a pump gas motor As I stated earlier, this failure still has me puzzled It has been over revved more than once looking at the back sides of the roller cam lobes now I'm thinking a piece of dirt or debris got washed in between the #1 rod bearing and crankshaft and that ended up seizing the bearing to the crankshaft To much damage now to tell, I can only guess AndyF, are you working on any interesting engine projects now?
Re: Motor carnage pictures, UGLY! [Re: Cab_Burge] #1639015
06/27/14 07:03 PM
06/27/14 07:03 PM
Canada
onig Offline
onig  Offline
Canada
That is an interesting statement.
What exactly are you looking for to tell that is was over-revved. Do the rollers "hit" the back side of the cam instead of rolling over them because it is spinning too fast?
I would like to see a pic of these lobes that you mentioned to understand your thinking and what to look for. I want to learn something here.
69 Dart
Re: Motor carnage pictures, UGLY! [Re: onig] #1639016
06/27/14 08:03 PM
06/27/14 08:03 PM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
When the lifter goes over the nose of the cam it goes airborne so to speak and when it lands, it beats the crap out of the heel of the cam and the roller too. Think beat cam with hammer and chisel and imagine the damage.
Kevin
Re: Motor carnage pictures, UGLY! [Re: Twostick] #1639017
06/27/14 09:27 PM
06/27/14 09:27 PM
Canada
onig Offline
onig  Offline
Canada
That's what I was thinking happens, but wanted to confirm. Good to know, thanks.
69 Dart
Re: Motor carnage pictures, UGLY! [Re: onig] #1639018
06/27/14 10:38 PM
06/27/14 10:38 PM
central ohio
N
nss guy Offline
nss guy  Offline
N
central ohio
pretty common knowledge 300+ 1/4 miles runs on a motor makein 600+ hp the main cap webbing starts to crack. Time to swap out the block before a catastophic failure. It's like changing the oil or any other kind of maintenance
Re: Motor carnage pictures, UGLY! [Re: Cab_Burge] #1639019
06/27/14 11:03 PM
06/27/14 11:03 PM
NC
440Jim Offline
440Jim  Offline
NC
Sounds like a lot of years on a race short block without checking/replacing at least the bearings.
I hate to hear of big failures when preventative maintenance might have avoided it.
Re: Motor carnage pictures, UGLY! [Re: 440Jim] #1639020
06/28/14 12:49 AM
06/28/14 12:49 AM
This one was built to be a pump gas motor that might make 8 to 10 passes in the 1/4 in its life to find out what the car would run at LACR back in the 1990s, mainly a trailer queen that was taken to car shows. Plans and things change, you wouldn't beleive the whole story behind this rascal It bit me on the butt twice , I didn't want to use that block to start with due to two external cracks and one internal casting flaw in the cooling passages at the bottom of #6 cylinder that leak coolant into the motor from day one OH WELL some lessons are hard to learn and enforce I now insist that it is my way in my shop or I don't take the job on Sometimes it does not pay to be nice to the customer and go out of your way to make them happy, especially when it ends up making both of you very unhappy
Re: Motor carnage pictures, UGLY! [Re: Cab_Burge] #1639021
06/28/14 01:06 AM
06/28/14 01:06 AM
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
Glycol is death on bearings.
8v92 Detroits were famous for losing their liner seals and dumping coolant in the base. The low coolant light usually came on at the same time it spun all the crank bearings.
Kevin
Re: Motor carnage pictures, UGLY! [Re: Twostick] #1639022
06/28/14 01:02 PM
06/28/14 01:02 PM
Chicago, IL
TonyS451 Offline
TonyS451  Offline
Chicago, IL
ouch, but sounds like it did its job for a long time. They all die eventually...
2 kids and a dog
Re: Motor carnage pictures, UGLY! [Re: onig] #1639023
06/28/14 02:12 PM
06/28/14 02:12 PM
Here you go , the back side of the lobes show the lifter hitting them (sliding down instead of rolling over the nose like they should) marking them up differentily than the front side The lobe on the far right hand side in this pictures is on the opening side so , hopefully, you can see both sides of a lobe on this cam
Re: Motor carnage pictures, UGLY! [Re: Cab_Burge] #1639024
06/28/14 02:13 PM
06/28/14 02:13 PM
Hopefully this picture will show the opening lobe better
Re: Motor carnage pictures, UGLY! [Re: Twostick] #1639025
06/28/14 02:16 PM
06/28/14 02:16 PM
Kevin
All the block flaws where fixed before I built it the first time, no Glycol in these bearings
Re: Motor carnage pictures, UGLY! [Re: Cab_Burge] #1639026
06/28/14 02:27 PM
06/28/14 02:27 PM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
Interesting subject on "over-revving". This would surely be a symptom to look no matter the cam type, right?
A Flat tappet would show the same damage to the cam if repeatedly over revved, correct?
Re: Motor carnage pictures, UGLY! [Re: Cab_Burge] #1639027
06/28/14 02:28 PM
06/28/14 02:28 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
RPM can play a pretty big part in how long a RB can last too. My old RB sweet spot was a 5600-5800 shift point and 6200 trap speed and was 9.93/136 capable at sea level.
Re: Motor carnage pictures, UGLY! [Re: Cab_Burge] #1639028
06/28/14 10:41 PM
06/28/14 10:41 PM
Canada
onig Offline
onig  Offline
Canada
Cab, thanks for the pics. Never seen that before, but it all makes sense.
How deep is the pounding, looks/guessing around a 1/16"?
Could a similar situation show on the lobes if the springs were too weak also?
69 Dart
Re: Motor carnage pictures, UGLY! [Re: onig] #1639029
06/29/14 01:02 AM
06/29/14 01:02 AM
Many things can cause the lifter to float , weak valve springs is one of them To many RPMs is another, especially in the burn out box The cam lobe design is a major factor in that also I just checked two of the valve springs on that motor, one of them has lost 20 lbs on the seat and more at max lift The customer did over rev the motor at the MATS race, he forgot to shift it into high gear on one run Lots of gremlins out there, many of them are man made As far as how deep on the grooves on those lobes I didn't measure or feel them, it has damages to one lobe from the flying motor pieces so I will send it in for repairs and ask them to regrind all the lobes so we can start fresh with a unblemished cam.
Re: Motor carnage pictures, UGLY! [Re: onig] #1639030
06/29/14 04:37 PM
06/29/14 04:37 PM
Central Ohio, USA
Bigbeep Offline
Bigbeep  Offline
Central Ohio, USA
My thought exactly! What is the recommended rpm range on the cam and where was it being operated at. My have been too light on the spring pressure if it really sees a lot of passes. Beep
Re: Motor carnage pictures, UGLY! [Re: Bigbeep] #1639031
06/29/14 06:52 PM
06/29/14 06:52 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
Not knocking what they want you to build because some guys can destroy an anvil. But seeing that pickup tube would scare me. IMO i want a duel line system for anything over 5000 rpm. I see cars with stock or deep pans twisting them 6500 and i feel they just pulled the pin, explosion will follow, just a matter of time. I wouldn't think any thing cam related would cause that rod failure but loss of oil.
Page 2 of 3 1 2 3
