Re: Dana 60 Gears options
[Re: JohnRR]
#1636512
06/23/14 10:19 PM
06/23/14 10:19 PM
Posts: 6,531 Jacksonville, FL
Chris2581
Jacksonville, FL
My 1968 SM says a 3.31 was avalable.
[Re: JohnRR]
#1636515
06/24/14 07:02 PM
06/24/14 07:02 PM
Posts: 184 Vernon Ct.
bp27
Vernon Ct.
There was a 3:3? but I'm 99% sure it was a ford ratio , you'll have to search to see if you can find an old set , nothing new is available that I have ever seen.
3.33 where in 1980s ford 3.31 where in 80s dana 61
[Re: six-pack-mopar]
#1636516
06/24/14 08:08 PM
06/24/14 08:08 PM
Posts: 2,963 Wisconsin
Stewpar
Wisconsin
Dana's are well known for their 3:54 and 4:10 gears as standard ratios. Are there gear sets out there that fit the Dana 60 in options lower than the 3:54 like perhaps 3:40 or 3:33 or 3:23? I know Ford made a 3:73 for a Dana 60 but thats about it. Thoughts? I know it was possible to have a 3:23 behind a Hemi with an automatic but that came with an 8 3/4" and not a Dana 60.
Buddy
Is it really worth all the hassle, I don't think you will notice the difference between a 3.54 to a 3.23 or especially anything in-between
[Re: Stewpar]
#1636517
06/24/14 09:38 PM
06/24/14 09:38 PM
Posts: 1,567 Ky
jt4406
Ky
According to RPM calculator (http://www.csgnetwork.com/multirpmcalc.html )a car with 27 inch tires, 1:1 high gear (regular 4 spd),and a 3.54 will be turning 3084 RPM at 70 MPH (speed limit here in ky). Same car with 3.33 gear will be turning 2900 RPM, worth the hassle..?? jess
Yeah, it's hopped up to over 160...
