Dana 60 Gears options #1636510
06/21/14 10:00 PM
06/21/14 10:00 PM
Rapid City, South Dakota
six-pack-mopar Offline OP
Dana's are well known for their 3:54 and 4:10 gears as standard ratios. Are there gear sets out there that fit the Dana 60 in options lower than the 3:54 like perhaps 3:40 or 3:33 or 3:23? I know Ford made a 3:73 for a Dana 60 but thats about it. Thoughts? I know it was possible to have a 3:23 behind a Hemi with an automatic but that came with an 8 3/4" and not a Dana 60.
Buddy
Re: Dana 60 Gears options [Re: six-pack-mopar] #1636511
06/22/14 11:01 PM
06/22/14 11:01 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
There was a 3:3? but I'm 99% sure it was a ford ratio , you'll have to search to see if you can find an old set , nothing new is available that I have ever seen.
Re: Dana 60 Gears options [Re: JohnRR] #1636512
06/23/14 10:19 PM
06/23/14 10:19 PM
Jacksonville, FL
Chris2581 Offline
Chris2581  Offline
Jacksonville, FL
My 1968 SM says a 3.31 was avalable.
Nautilus Racing-
Re: Dana 60 Gears options [Re: six-pack-mopar] #1636513
06/24/14 12:52 AM
06/24/14 12:52 AM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
Go to an International dealer,the old Scouts,Travelall's and pickups had a variety of different ratio's.
Re: Dana 60 Gears options [Re: Chris2581] #1636514
06/24/14 04:17 AM
06/24/14 04:17 AM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
Actually, the 3.31 gears available in 1968 fit Dana 53 rears.
Re: Dana 60 Gears options [Re: JohnRR] #1636515
06/24/14 07:02 PM
06/24/14 07:02 PM
Vernon Ct.
bp27 Offline
bp27  Offline
Vernon Ct.
3.33 where in 1980s ford 3.31 where in 80s dana 61
Re: Dana 60 Gears options [Re: six-pack-mopar] #1636516
06/24/14 08:08 PM
06/24/14 08:08 PM
Wisconsin
Stewpar Offline
Stewpar  Offline
Wisconsin
Buddy
Is it really worth all the hassle, I don't think you will notice the difference between a 3.54 to a 3.23 or especially anything in-between
Re: Dana 60 Gears options [Re: Stewpar] #1636517
06/24/14 09:38 PM
06/24/14 09:38 PM
Ky
jt4406 Offline
jt4406  Offline
Ky
According to RPM calculator (http://www.csgnetwork.com/multirpmcalc.html )a car with 27 inch tires, 1:1 high gear (regular 4 spd),and a 3.54 will be turning 3084 RPM at 70 MPH (speed limit here in ky).
Same car with 3.33 gear will be turning 2900 RPM, worth the hassle..??
jess
Yeah, it's hopped up to over 160...
