msd vs mopar ecu #1635320
06/18/14 03:11 PM
06/18/14 03:11 PM
United states wisconsin
bigblockbryan Offline OP
I have been thinking about getting a msd 6 plus box for the fury is this a lot better then the orange or chrome box?
Re: msd vs mopar ecu [Re: bigblockbryan] #1635321
06/18/14 03:22 PM
06/18/14 03:22 PM
SE PA
Yellow Fever Offline
SE PA
I'll throw the Pertronix Ignitor III in the mix.
I have their billet dist., built in rev limiter, multi spark through the entire rpm range........
http://mopar1.us/cuda/cuda/dist2.jpg
http://www.pertronix.com/prod/ig/ignitor3/default.aspx
Re: msd vs mopar ecu [Re: Yellow Fever] #1635322
06/18/14 06:10 PM
06/18/14 06:10 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I will say the MSD is a good ign. Now on my sons car we switched from the orange MP ECU to MSD and it ran the same et as with the MP ign. So if the ign on the car now is working good I dont think you will go faster but you will have the multi-spark ign and it helps keep the plugs clean longer. You cant go wrong with the MSD but as long as you have a good ign now you wont be going faster but may start better with the MSD multi-spark ign. My sons Dart did not as it started and ran the same but his orange box worked good. Ron
Re: msd vs mopar ecu [Re: bigblockbryan] #1635323
06/18/14 06:18 PM
06/18/14 06:18 PM
What Ron said, are you having a problem now or are you wanting to change something/spend some money (the story of my life). Or are looking for more power. I've considered the "P" III also
Re: msd vs mopar ecu [Re: bigblockbryan] #1635324
06/18/14 08:29 PM
06/18/14 08:29 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
The mopar stock electronic ignition is fine for mild performance. I use it on both my muscle cars.
It's when you build a high compression race engine is when you need the MSD, not for a street/strip car. IMO
Re: msd vs mopar ecu [Re: bigblockbryan] #1635325
06/18/14 09:33 PM
06/18/14 09:33 PM
Northern Indiana
Dunnuck Racing Offline
Northern Indiana
I can post a dyno comparison tomorrow if that will help you.
A multi spark does almost nothing on a well tuned engine. Its the ignitions other characteristics that make an MSD worth a little power.
The MSD 6 al was designed back when Mopar designed their ignition systems. There are better components available today. The good thing about the MP boxes is its cheap to carry a parts store replacement to get you home if it fails.
Keith
Re: msd vs mopar ecu [Re: bigblockbryan] #1635326
06/18/14 11:42 PM
06/18/14 11:42 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Points and condenser would be better than an orange box.
YMMV
Re: msd vs mopar ecu [Re: JohnRR] #1635327
06/19/14 10:01 AM
06/19/14 10:01 AM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
I like the MSD myself. Where I noticed the biggest difference on mine was cold weather. Below 40 mine would foul a plug on start-up with an orange box and never pick it back up. With an MSD it started clean at -7.
Re: msd vs mopar ecu [Re: slantzilla] #1635328
06/19/14 10:54 AM
06/19/14 10:54 AM
Cincinnati, Ohio
Cincinnati, Ohio
This reminds of this day, the day of the freezer bowl. My 73 challenger with a 340 700 double pumper and stock mopar ignition was the only car that started on my street this day. It was a rusty, loud header equipped junker that sat out on the street.
web page
Re: msd vs mopar ecu [Re: Challenger 1] #1635329
06/19/14 11:28 AM
06/19/14 11:28 AM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
i've had an MSD 6 for years which i used to replace the MP electronic upgrade on my 440 RR. keep in mind 25 years ago there were few options back then but i did notice easier starts and maybe better mileage. that said would i go with MSD if i were doing it today? Probably not. most likely choice would be to try that Rev-n-ator. i like what i've read about it, the dyno tests posted and the fact that it's plug and play for piece of mind....
Re: msd vs mopar ecu [Re: mikemee1331] #1635330
06/20/14 10:25 AM
06/20/14 10:25 AM
West Palm Beach, Florida
Copper Dart Offline
Copper Dart  Offline
Consider how you will be using the car.
For a "Daily Driver" the stock mopar electronic ignition is best only because most part stores have all you will need in stock in a pinch. IMO.
Most of the other better options don't give you an " OUT" if you should have issues on the drive to or from home. It wouldn't make sense to have a second replacement unit in your trunk and have to change it roadside.
I don't know, maybe have an old points and condenser unit handy? Not me but it IS a doable option.
Copper
Common sense, the least common of all the senses.
Mom.
For fear of ridicule, society stifles creativity.
Ricky Valdes
Re: msd vs mopar ecu [Re: Copper Dart] #1635331
06/20/14 11:38 PM
06/20/14 11:38 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
I have always relied on MSD 6AL boxes because I race a stick car and needed the rev limiter. I will go with the new Firecore50 ignition box if my MSD ever fails.
I always wondered why people would run an ignition in their car that is so prone to failure that they'd never take a trip unless they had a spare box and a ballast resistor in the glove box
Personally I would go Firecore50 if I were starting from scratch
Gus
64 Plymouth Savoy
Dana 60
Re: msd vs mopar ecu [Re: fourgearsavoy] #1635332
06/21/14 05:11 AM
06/21/14 05:11 AM
USA
JoesMopar Offline
JoesMopar  Offline
USA
I've never had a problem with the orange or chrome box...don't believe the hysteria.
Re: msd vs mopar ecu [Re: bigblockbryan] #1635333
06/21/14 10:03 PM
06/21/14 10:03 PM
Virginia
hokies1 Offline
hokies1  Offline
Virginia
Petronix 3 is a really good unit. It looks like factory built in rev limiter works great. Got it on my 416. And almost forgot you can do away with the ballast resistor.
Re: msd vs mopar ecu [Re: hokies1] #1635334
06/22/14 12:08 PM
06/22/14 12:08 PM
Right here
HP2 Offline
HP2  Offline
Right here
I have had all kind of different problems with the orange ECU's, but I still run one on my GTX
On a street car you want vacuum advance, on the strip you don't. That's the base line. I don't think there are any bad brands out there, except maybe for the Chinese MSD copies.
Right now I'm building a crank trigger ignition without mechanical distributor for a 440. I believe there are lots of hidden ponies in the ignition. Think all the way from crank to the plugs... Have you seen a steady timing marker on an old V8?
I will try to run it on a chassis dyno before and after to get proved figures!
70 W100 Power Wagon. 318 4-spd
70 Sport Fury 440 2dr HT
71 Duster 340
71 Charger Super Bee - 383/727
72 Charger "Sabotage" - 440/727 - Street/Strip
78 Warlock in beautiful patina
Re: msd vs mopar ecu [Re: HP2] #1635335
06/22/14 03:06 PM
06/22/14 03:06 PM
i wasn't really thinking i would do it for,More h.p. i was just wondering if they are more reliable i think my 69 super bee clone im gonna build will have a msd.My fury will probably just get another box right now i have a blue one from oreillys.
Re: msd vs mopar ecu [Re: HP2] #1635336
06/22/14 04:13 PM
06/22/14 04:13 PM
Ft. Wayne, IN.
Q
QTR MILR Offline
QTR MILR  Offline
Q
Ft. Wayne, IN.
Yep sure have.... Ever since I put the Firecore distributor in it!!
Scott
69 Satellite, 3650lb street car... Dunnuck Racing pump gas 440. Best of 10:60@127...
Re: msd vs mopar ecu [Re: JoesMopar] #1635337
06/23/14 01:43 AM
06/23/14 01:43 AM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
oooooh yes.... believe it! I do, because I have being there!
Re: msd vs mopar ecu [Re: NachoRT74] #1635338
06/23/14 10:42 AM
06/23/14 10:42 AM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
Aren't you the one who takes them apart and fixes them?
Re: msd vs mopar ecu [Re: slantzilla] #1635339
06/23/14 06:39 PM
06/23/14 06:39 PM
NY usa
540challenger Offline
NY usa
here is what i am running
http://www.thertgarage.com/products.html
a little pricy but it bolts in like a stock unit. plus a rev limiter
