Re: msd vs mopar ecu
[Re: bigblockbryan]
#1635323
06/18/14 06:18 PM
06/18/14 06:18 PM
RapidRobert
What Ron said, are you having a problem now or are you wanting to change something/spend some money (the story of my life). Or are looking for more power. I've considered the "P" III also
[Re: bigblockbryan]
#1635324
06/18/14 08:29 PM
06/18/14 08:29 PM
Challenger 1
Cincinnati, Ohio
I have been thinking about getting a msd 6 plus box for the fury is this a lot better then the orange or chrome box?
The mopar stock electronic ignition is fine for mild performance. I use it on both my muscle cars.
It's when you build a high compression race engine is when you need the MSD, not for a street/strip car. IMO
[Re: bigblockbryan]
#1635326
06/18/14 11:42 PM
06/18/14 11:42 PM
Posts: 75,082 U.S.S.A.
JohnRR
U.S.S.A.
Points and condenser would be better than an orange box.
YMMV
[Re: JohnRR]
#1635327
06/19/14 10:01 AM
06/19/14 10:01 AM
Posts: 20,202 Park Forest, IL
slantzilla
Park Forest, IL
I like the MSD myself. Where I noticed the biggest difference on mine was cold weather. Below 40 mine would foul a plug on start-up with an orange box and never pick it back up. With an MSD it started clean at -7.
[Re: slantzilla]
#1635328
06/19/14 10:54 AM
06/19/14 10:54 AM
Challenger 1
Cincinnati, Ohio
This reminds of this day, the day of the freezer bowl. My 73 challenger with a 340 700 double pumper and stock mopar ignition was the only car that started on my street this day. It was a rusty, loud header equipped junker that sat out on the street. web page
[Re: mikemee1331]
#1635330
06/20/14 10:25 AM
06/20/14 10:25 AM
Posts: 1,520 West Palm Beach, Florida
Copper Dart
Consider how you will be using the car. For a "Daily Driver" the stock mopar electronic ignition is best only because most part stores have all you will need in stock in a pinch. IMO. Most of the other better options don't give you an " OUT" if you should have issues on the drive to or from home. It wouldn't make sense to have a second replacement unit in your trunk and have to change it roadside. I don't know, maybe have an old points and condenser unit handy? Not me but it IS a doable option. Copper
Common sense, the least common of all the senses. Mom.
For fear of ridicule, society stifles creativity. Ricky Valdes
[Re: Copper Dart]
#1635331
06/20/14 11:38 PM
06/20/14 11:38 PM
Posts: 10,556 Rittman Ohio
fourgearsavoy
Rittman Ohio
I have always relied on MSD 6AL boxes because I race a stick car and needed the rev limiter. I will go with the new Firecore50 ignition box if my MSD ever fails. I always wondered why people would run an ignition in their car that is so prone to failure that they'd never take a trip unless they had a spare box and a ballast resistor in the glove box Personally I would go Firecore50 if I were starting from scratch Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
[Re: bigblockbryan]
#1635333
06/21/14 10:03 PM
06/21/14 10:03 PM
Posts: 27 Virginia
hokies1
Virginia
Petronix 3 is a really good unit. It looks like factory built in rev limiter works great. Got it on my 416. And almost forgot you can do away with the ballast resistor.
[Re: hokies1]
#1635334
06/22/14 12:08 PM
06/22/14 12:08 PM
Posts: 523 Right here
HP2
Right here
I have had all kind of different problems with the orange ECU's, but I still run one on my GTX On a street car you want vacuum advance, on the strip you don't. That's the base line. I don't think there are any bad brands out there, except maybe for the Chinese MSD copies. Right now I'm building a crank trigger ignition without mechanical distributor for a 440. I believe there are lots of hidden ponies in the ignition. Think all the way from crank to the plugs... Have you seen a steady timing marker on an old V8? I will try to run it on a chassis dyno before and after to get proved figures!
70 W100 Power Wagon. 318 4-spd 70 Sport Fury 440 2dr HT 71 Duster 340 71 Charger Super Bee - 383/727 72 Charger "Sabotage" - 440/727 - Street/Strip 78 Warlock in beautiful patina
