Re: msd vs mopar ecu
[Re: bigblockbryan]
#1635323
06/18/14 06:18 PM
06/18/14 06:18 PM
RapidRobert
What Ron said, are you having a problem now or are you wanting to change something/spend some money (the story of my life). Or are looking for more power. I've considered the "P" III also
[Re: bigblockbryan]
#1635324
06/18/14 08:29 PM
06/18/14 08:29 PM
Challenger 1
Cincinnati, Ohio
I have been thinking about getting a msd 6 plus box for the fury is this a lot better then the orange or chrome box?
The mopar stock electronic ignition is fine for mild performance. I use it on both my muscle cars.
It's when you build a high compression race engine is when you need the MSD, not for a street/strip car. IMO
[Re: bigblockbryan]
#1635326
06/18/14 11:42 PM
06/18/14 11:42 PM
Posts: 75,043 U.S.S.A.
JohnRR
U.S.S.A.
Points and condenser would be better than an orange box.
YMMV
[Re: JohnRR]
#1635327
06/19/14 10:01 AM
06/19/14 10:01 AM
Posts: 20,185 Park Forest, IL
slantzilla
Park Forest, IL
I like the MSD myself. Where I noticed the biggest difference on mine was cold weather. Below 40 mine would foul a plug on start-up with an orange box and never pick it back up. With an MSD it started clean at -7.
[Re: slantzilla]
#1635328
06/19/14 10:54 AM
06/19/14 10:54 AM
Challenger 1
Cincinnati, Ohio
This reminds of this day, the day of the freezer bowl. My 73 challenger with a 340 700 double pumper and stock mopar ignition was the only car that started on my street this day. It was a rusty, loud header equipped junker that sat out on the street. web page
[Re: mikemee1331]
#1635330
06/20/14 10:25 AM
06/20/14 10:25 AM
Posts: 1,520 West Palm Beach, Florida
Copper Dart
Consider how you will be using the car. For a "Daily Driver" the stock mopar electronic ignition is best only because most part stores have all you will need in stock in a pinch. IMO. Most of the other better options don't give you an " OUT" if you should have issues on the drive to or from home. It wouldn't make sense to have a second replacement unit in your trunk and have to change it roadside. I don't know, maybe have an old points and condenser unit handy? Not me but it IS a doable option. Copper
Common sense, the least common of all the senses. Mom.
For fear of ridicule, society stifles creativity. Ricky Valdes
[Re: Copper Dart]
#1635331
06/20/14 11:38 PM
06/20/14 11:38 PM
Posts: 10,555 Rittman Ohio
fourgearsavoy
Rittman Ohio
I have always relied on MSD 6AL boxes because I race a stick car and needed the rev limiter. I will go with the new Firecore50 ignition box if my MSD ever fails. I always wondered why people would run an ignition in their car that is so prone to failure that they'd never take a trip unless they had a spare box and a ballast resistor in the glove box Personally I would go Firecore50 if I were starting from scratch Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
[Re: bigblockbryan]
#1635333
06/21/14 10:03 PM
06/21/14 10:03 PM
Posts: 27 Virginia
hokies1
Virginia
Petronix 3 is a really good unit. It looks like factory built in rev limiter works great. Got it on my 416. And almost forgot you can do away with the ballast resistor.
[Re: hokies1]
#1635334
06/22/14 12:08 PM
06/22/14 12:08 PM
Posts: 523 Right here
HP2
Right here
I have had all kind of different problems with the orange ECU's, but I still run one on my GTX On a street car you want vacuum advance, on the strip you don't. That's the base line. I don't think there are any bad brands out there, except maybe for the Chinese MSD copies. Right now I'm building a crank trigger ignition without mechanical distributor for a 440. I believe there are lots of hidden ponies in the ignition. Think all the way from crank to the plugs... Have you seen a steady timing marker on an old V8? I will try to run it on a chassis dyno before and after to get proved figures!
70 W100 Power Wagon. 318 4-spd 70 Sport Fury 440 2dr HT 71 Duster 340 71 Charger Super Bee - 383/727 72 Charger "Sabotage" - 440/727 - Street/Strip 78 Warlock in beautiful patina
[Re: slantzilla]
#1635341
06/23/14 08:37 PM
06/23/14 08:37 PM
Posts: 4,154 bethlehem pa
mikemee1331
bethlehem pa
I've never had a problem with the orange or chrome box...don't believe the hysteria.
oooooh yes.... believe it! I do, because I have being there!
Aren't you the one who takes them apart and fixes them?
he is indeed! but i think he fixes them because it's too hard to get stuff in his country. it's easier to fix what you have or found. i also believe when he wrote his thread about doing that that he determined heat was the number one issue with the internal components. now why do they get too hot? you'd have to ask the crowd who runs them with no ballast.
[Re: mikemee1331]
#1635342
06/23/14 09:26 PM
06/23/14 09:26 PM
Posts: 2,782 USA
JoesMopar
USA
Forgot about that crowd.
I've still yet to have a Mopar ECU crap out on me. I'm patiently waiting and it's getting a bit frustrating to be perfectly frank.
[Re: JoesMopar]
#1635343
06/23/14 09:52 PM
06/23/14 09:52 PM
mikemee1331
bethlehem pa
jump the ballast "Perfectly Frank"!
[Re: CraigS]
#1635345
06/24/14 12:43 AM
06/24/14 12:43 AM
Posts: 2,782 USA
JoesMopar
USA
Do you ever drive your car?
Hell yes! All of them, as much as I can.
[Re: CraigS]
#1635346
06/24/14 09:49 AM
06/24/14 09:49 AM
Challenger 1
Cincinnati, Ohio
Really? Never had an ecu crap out.? Do you ever drive your car?
I had a mopar ECU go bad in 1976, my car sat broke down for 4 or more months until my uncle helped me figure it out.
Then I don't remember another going out on me since.
I have like 6 or more ECUs from cars I parted out. I found that a OEM one from the early 70s runs better than the chrome one I bought in the 2000s
