Pro Gears vs Street Gears? #1626750
05/30/14 12:31 PM
05/30/14 12:31 PM
Indiana
Cuda_Mike Offline OP
Indiana
Recently busted the pinion gear in my Dana 60, never used pro gears in several years of racing, but I don't want another failure. Pros and cons? How long will pro gears last? Had 4.56 but had been planning to switch to 4.10's. 1.32 60' @ 3,200 lbs. Thanks for all input.
Re: Pro Gears vs Street Gears? [Re: Cuda_Mike] #1626751
05/30/14 02:13 PM
05/30/14 02:13 PM
westerly, ri. usa
440lebaron Offline
440lebaron  Offline
westerly, ri. usa
dana 60 4.10 progears 60ft 1.22 trans brake 540 ci only weight 2550lbs 5 years about 300 runs.
gary
all parts are sold as is, all parts are considered used no warranties or returns
paypal/check/money order, shipping is from zip 02891, buyer pays paypal fees 24% IRS 1099A plus 3% of part price, check/money order preferred
site is not monitored 24/7 there might be a delay in response
Re: Pro Gears vs Street Gears? [Re: Cuda_Mike] #1626752
05/30/14 05:21 PM
05/30/14 05:21 PM
A shed in England
Tig Online work
Tig  Online Work
A shed in England
Be careful to get the correct carrier
Re: Pro Gears vs Street Gears? [Re: Cuda_Mike] #1626753
05/30/14 06:20 PM
05/30/14 06:20 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Are you running too many rpms at the traps to cause
you to go with the 4.10s... I myself have never run
a pro gear.. mainly due to it wasnt in my ratio.. so
I cant help there
Re: Pro Gears vs Street Gears? [Re: MR_P_BODY] #1626754
05/30/14 06:45 PM
05/30/14 06:45 PM
Sweet Home Alabama
MRMOPAR622 Offline
MRMOPAR622  Offline
Sweet Home Alabama
Pro gears are softer,they don't break like a hard street gear,they are jut enough softer to cushion the shook at the hit making them better in a race-Car with slicks.But Pro gears being soft are not as good for the street because they will wear faster.
PS I know no one wants to hear this but that is one of the advantages of running a 9" ford rear end you can get just about any gear ratio you want.
"To Be The Man'You Have Got To Beat The Man" "T/D and Pro-Bracket Racer"
Re: Pro Gears vs Street Gears? [Re: MRMOPAR622] #1626755
05/30/14 07:02 PM
05/30/14 07:02 PM
Ohio
64dodge572 Offline
64dodge572  Offline
Ohio
I had about 650 runs on an all new Dana 60/4.56 pro gears, twisted an axle at that point, replaced both axles, about 20 passes later broke the ring/pinion. 2800# car running 5.50's 1/8" mile.
Re: Pro Gears vs Street Gears? [Re: 64dodge572] #1626756
05/30/14 09:37 PM
05/30/14 09:37 PM
DFW
mr_340 Offline
mr_340  Offline
DFW
Can you just have the gears tempered to get them a little less hard? Has anyone measured the hardness on each type?
Re: Pro Gears vs Street Gears? [Re: mr_340] #1626757
05/30/14 09:51 PM
05/30/14 09:51 PM
Morrow, OH
markz528 Offline
markz528  Offline
Morrow, OH
Yes you can but it can be expensive to do correctly. It was a trick stock racers did years ago.
I had a set done probably late 80's or early 90's. I may have the original and after hardness somewhere, but I will have to look for it.
The trick is that you need to harden the surfaces after tempering or else you have excessive wear.
The outfit I had do mine did some sort of spray to surface harden the teeth. It was not very effective. After 75 runs, I inspected the gears had almost 100% tooth contact and the gears deformed to the point that the edges of the gears rolled over.
I was cheap and cleaned the edges up and ran it for many years and many runs that way. Never got worse. Sold the rear end about 12 years ago - it never failed on me.
My metallurgist says that what should of been done after the gears were softened is the root of the gears should of been masked and then the teeth hardened by carburizing.
Re: Pro Gears vs Street Gears? [Re: Cuda_Mike] #1626758
05/30/14 11:43 PM
05/30/14 11:43 PM
CEDAR RAPIDS
Plymouth340 Offline
Plymouth340  Offline
CEDAR RAPIDS
I have Richmond 4.88 pro gears in my dana 60. put them in in 1990 made about 1500 passes so far..no issues.. car weights 2830 lbs
