Re: Pro Gears vs Street Gears?
[Re: Cuda_Mike]
#1626751
05/30/14 02:13 PM
05/30/14 02:13 PM
Posts: 1,613 westerly, ri. usa
440lebaron
westerly, ri. usa
dana 60 4.10 progears 60ft 1.22 trans brake 540 ci only weight 2550lbs 5 years about 300 runs.
gary
all parts are sold as is, all parts are considered used no warranties or returns paypal/check/money order, shipping is from zip 02891, buyer pays paypal fees 24% IRS 1099A plus 3% of part price, check/money order preferred site is not monitored 24/7 there might be a delay in response
[Re: Cuda_Mike]
#1626752
05/30/14 05:21 PM
05/30/14 05:21 PM
Posts: 2,937 A shed in England
Tig
A shed in England
Be careful to get the correct carrier
'74 Challenger..9.46 @ 145.9 1/4, 6.001 @ 118 1/8 so far. 4023lb !!! # N/A, Marsh performance 655ci, Indy Maxx, T/R, Indy 600-13 X's, Street legal, pump gas, full interior, Cal-Tracs, mufflers, 3:73's and real 10.5 radials. 9.51 @ 142.4 1/4, 6.003 @ 114 1/8 with our old mule KB, 572-13, 580 wedge. RHD '68 Barracuda Fastback 323ci street/strip. Best ET 13.88 @ 99.03
[Re: Cuda_Mike]
#1626753
05/30/14 06:20 PM
05/30/14 06:20 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Recently busted the pinion gear in my Dana 60, never used pro gears in several years of racing, but I don't want another failure. Pros and cons? How long will pro gears last? Had 4.56 but had been planning to switch to 4.10's. 1.32 60' @ 3,200 lbs. Thanks for all input.
Are you running too many rpms at the traps to cause you to go with the 4.10s... I myself have never run a pro gear.. mainly due to it wasnt in my ratio.. so I cant help there
[Re: MR_P_BODY]
#1626754
05/30/14 06:45 PM
05/30/14 06:45 PM
Posts: 2,008 Sweet Home Alabama
MRMOPAR622
Sweet Home Alabama
Pro gears are softer,they don't break like a hard street gear,they are jut enough softer to cushion the shook at the hit making them better in a race-Car with slicks.But Pro gears being soft are not as good for the street because they will wear faster. PS I know no one wants to hear this but that is one of the advantages of running a 9" ford rear end you can get just about any gear ratio you want.
"To Be The Man'You Have Got To Beat The Man"
"T/D and Pro-Bracket Racer"
