Page 1 of 3 1 2 3
360 Street/Strip Bruiser-Dyno results inside #1625558
05/27/14 08:57 AM
05/27/14 08:57 AM
The Great White North
RAMM Offline OP
RAMM  Offline OP
The build:
'84 360 block .060" (bores would not cleanup at anything less)
Eagle steel crank 3.58" (stock stroke)
Scat I-beams (stock length)
Icon Forged flat tops 4.06" @ zero deck 1/16" ring pack Napier 2nd
Felpro 519 SD gaskets
Comp Cam 294 S w Hughes EDM lifters
Heavily ported EQ Magnums 300cfm @ .600"+
T&D 1.5/1.5 shaft rockers
Eddy 2815 SV intake
Holley 950 HP Ultra
1 5/8"-1 3/4" dyno headers with Magnaflow muffs.
So here we have a 10.8 comp stock stroke 360 with a low lift solid lifter camshaft I bought at a garage sale for $60 with heads that are iron. Admittedly the trickest parts of the build are the rockers and induction. Nevertheless I was pleasantly surprised with the outcome. J.Rob
2009 PHR\EMC Competitor
2010 PHR\EMC Competitor
2011 PHR\EMC Competitor
2012 PHR\EMC Competitor
2013 PHR\EMC Competitor
2014 HotRod/EMC Competitor
2015 HotRod/EMC NoShow
2016 HotRod/EMC 3rd place SPEC Bigblock
2018 HotRod/EMC 7th place G3
Re: 360 Street/Strip Bruiser-Dyno results inside [Re: RAMM] #1625559
05/27/14 08:58 AM
05/27/14 08:58 AM
RAMM Offline OP
RAMM  Offline OP
Here's the results. This was the final test last Friday. I turned it 7250 rpm many times just to see the shape of the curve. This engine is the happiest revving 360 I've ever built. This would certainly be happier in a more strip oriented ride I would imagine.
Yes it's a little rich--I ran out of gas and time on Friday. There may be more. J.Rob
Re: 360 Street/Strip Bruiser-Dyno results inside [Re: RAMM] #1625560
05/27/14 10:47 AM
05/27/14 10:47 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Not bad... being that its real rich I'd say there is
more in it
Re: 360 Street/Strip Bruiser-Dyno results inside [Re: RAMM] #1625561
05/27/14 11:52 AM
05/27/14 11:52 AM
Az
Crizila Offline
Crizila  Offline
Az
Impressive #'s. Big time port work to get 300 cfm from those heads. Nice combo. Torque curve nice and broad - and not too far up in to the rpm range.
Fastest 300
Re: 360 Street/Strip Bruiser-Dyno results inside [Re: Crizila] #1625562
05/27/14 12:02 PM
05/27/14 12:02 PM
RAMM Offline OP
RAMM  Offline OP
Thanks guys. Yes the heads are worked extensively as is the intake manifold. I don't find the torque to be all that impressive. I tested at 4000 rpm and it produced 410-415 ft/lbs. However what is impressive is the little .507" net lift after .018" lash cam made even what it did. I was expecting much less to be honest maybe 485-500 hp max. J.Rob
Re: 360 Street/Strip Bruiser-Dyno results inside [Re: Crizila] #1625563
05/27/14 12:03 PM
05/27/14 12:03 PM
CT
GTX MATT Offline
GTX MATT  Offline
CT
Nice
Re: 360 Street/Strip Bruiser-Dyno results inside [Re: GTX MATT] #1625564
05/27/14 12:31 PM
05/27/14 12:31 PM
Weddington, N.C.
Streetwize Offline
Streetwize  Offline
Weddington, N.C.
Very Nice!
Would think a smaller manifold like an Air Gap would broaden the torque curve (higher average) than the SV which (using conventional thought anyway) would skew the power upstairs at the expense of the upper bottom/midrange.
Very Impressive overall power...especially considering the smallish cam.
WIZE
In Car:
Re: 360 Street/Strip Bruiser-Dyno results inside [Re: Streetwize] #1625565
05/27/14 12:46 PM
05/27/14 12:46 PM
CT
GTX MATT Offline
GTX MATT  Offline
CT
My 440 suddenly feels inadequate...
Re: 360 Street/Strip Bruiser-Dyno results inside [Re: RAMM] #1625566
05/27/14 01:21 PM
05/27/14 01:21 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
NICE..............
Re: 360 Street/Strip Bruiser-Dyno results inside [Re: RAMM] #1625567
05/27/14 02:23 PM
05/27/14 02:23 PM
Between a rock & a hard place
cudadoug Offline
cudadoug  Offline
Might you share the rest of the cam specs?
Thanks!
Re: 360 Street/Strip Bruiser-Dyno results inside [Re: cudadoug] #1625568
05/27/14 02:41 PM
05/27/14 02:41 PM
RAMM Offline OP
RAMM  Offline OP
Its the old CC 294s 248/248 110. J.Rob
Re: 360 Street/Strip Bruiser-Dyno results inside [Re: cudadoug] #1625569
05/27/14 02:46 PM
05/27/14 02:46 PM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
Thanks!
http://www.summitracing.com/parts/cca-20-248-4/overview/make/dodge
Tony
70 AARCuda Vitamin C
Re: 360 Street/Strip Bruiser-Dyno results inside [Re: RAMM] #1625570
05/27/14 03:39 PM
05/27/14 03:39 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
Very impressive!
I bet a set of 1.6 rockers would add quite a bit, get it more into the flow zone of the heads and slightly improve the PR geometry
Re: 360 Street/Strip Bruiser-Dyno results inside [Re: HotRodDave] #1625571
05/27/14 06:21 PM
05/27/14 06:21 PM
sweden
sshemi Offline
sshemi  Offline
sweden
Wow. Those heads must be HUGE making peak power that high!
Re: 360 Street/Strip Bruiser-Dyno results inside [Re: sshemi] #1625572
05/27/14 06:46 PM
05/27/14 06:46 PM
cudadoug Offline
cudadoug  Offline
I can't speak for these heads, but I doubt it. Velocity seems to be a key part of the Magnum head. When I fist looked a set of RHS ports, I thought, "NO WAY will these flow." I was wrong...end of story.
Re: 360 Street/Strip Bruiser-Dyno results inside [Re: cudadoug] #1625573
05/28/14 02:25 AM
05/28/14 02:25 AM
sweden
sshemi Offline
sshemi  Offline
sweden
I mean that high up in the rpms.
Re: 360 Street/Strip Bruiser-Dyno results inside [Re: HotRodDave] #1625574
05/28/14 03:05 AM
05/28/14 03:05 AM
WA
P
pro451bee Offline
pro451bee  Offline
P
WA
Aren't magnum heads already 1.6 ratio?
Re: 360 Street/Strip Bruiser-Dyno results inside [Re: pro451bee] #1625575
05/28/14 08:24 AM
05/28/14 08:24 AM
Oakland, MI
dizuster Offline
dizuster  Offline
Oakland, MI
Very impressive numbers...can't wait to see what it does in the car.
Jeez I hope my new MCH CNC Eddy's don't want to turn that much rpm...my cast crank hates me enough as it is...lol
Re: 360 Street/Strip Bruiser-Dyno results inside [Re: pro451bee] #1625576
05/28/14 08:52 AM
05/28/14 08:52 AM
RAMM Offline OP
RAMM  Offline OP
These are old T&D rockers in a 1.5/1.5 ratio. J.Rob
Re: 360 Street/Strip Bruiser-Dyno results inside [Re: dizuster] #1625577
05/28/14 08:54 AM
05/28/14 08:54 AM
RAMM Offline OP
RAMM  Offline OP
I have an Eagle 4340 steel crank in this engine. J.Rob
Page 1 of 3 1 2 3
