Analyze this? (Wheel hop) #1620498
05/15/14 10:50 PM
05/15/14 10:50 PM
Northern MN
1E2C Offline OP
1E2C  Offline OP
Northern MN
My 83 D150 has had a wicked wheel hop issue since I put it together, imagine sitting on a jack hammer when you mash the loud pedal enough to break 'em loose. Because of that I seldom beat it hard since I'm too afraid of destroying the driveshaft or rear end. Finally nailed it hard on pavement again the other day and looking at the marks I thought them interesting as I've never seen 'scalloped' burn out marks before. Both wheels spinning (at least intermittently) it feels like hook/spin/hook/spin and looks the same on pavement. Any ideas on the easiest fix or do I just go on being easy on it?
Mike
Re: Analyze this? (Wheel hop) [Re: 1E2C] #1620499
05/15/14 10:50 PM
05/15/14 10:50 PM
Northern MN
1E2C Offline OP
1E2C  Offline OP
Northern MN
Here's a little closer shot of just one.
Re: Analyze this? (Wheel hop) [Re: 1E2C] #1620500
05/15/14 11:01 PM
05/15/14 11:01 PM
Northern MN
1E2C Offline OP
1E2C  Offline OP
Northern MN
Maybe a bit more info is in order - 83 D150; 360 @ 30 over w/MP 340 repro cam, edelbrock performer intake/carb (600 cfm), Thorley tri-y headers to 2 1/2" duals; A833 trans (not o/d); centerforce df clutch; 8 3/4 rear w/3.23 SG
Re: Analyze this? (Wheel hop) [Re: 1E2C] #1620501
05/15/14 11:03 PM
05/15/14 11:03 PM
Grand Prairie,Texas
stumpy Online content
stumpy  Online Content
Grand Prairie,Texas
What are you using for shocks and springs? Also what tires and tire pressures. Wheel hop basically comes from spring wrap up.
Re: Analyze this? (Wheel hop) [Re: 1E2C] #1620502
05/15/14 11:14 PM
05/15/14 11:14 PM
Harm City Md.
Dan Halen Offline
Dan Halen  Offline
Harm City Md.
Nitrous! Seriously though, my van would do the same thing until I put the big block in, now it takes two lanes but no more wheel hop.
Re: Analyze this? (Wheel hop) [Re: Dan Halen] #1620503
05/15/14 11:16 PM
05/15/14 11:16 PM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
time for some kind of traction device..
I am truckless..
Re: Analyze this? (Wheel hop) [Re: stumpy] #1620504
05/15/14 11:24 PM
05/15/14 11:24 PM
Northern MN
1E2C Offline OP
1E2C  Offline OP
Northern MN
Factory springs in the rear with 2500 lb progressive helpers and Monroe sensa-trac shocks. Need the overloads for it's real, intended use and kinda thought they should help stiffen things up too. Have been considering yanking them and put in air bags for when I have to load it down. Tires are typical winter daily driver in NW MN tires, P235-75R15 Bridgestone Dueler Revo (fairly soft compound w/lots of siping). It acted the same with the previous tires which were a more typical all season tire. Oh yeah, 32 psi is usual.
Re: Analyze this? (Wheel hop) [Re: 1E2C] #1620505
05/15/14 11:30 PM
05/15/14 11:30 PM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
are the front segments of the springs clamped ??
I am truckless..
Re: Analyze this? (Wheel hop) [Re: 340SHORTY] #1620506
05/15/14 11:42 PM
05/15/14 11:42 PM
Northern MN
1E2C Offline OP
1E2C  Offline OP
Northern MN
The factory strap up front plus the front of the helper is tied to a plate under the springs. Found a pic of when I put it together....
Now don't bust on me 'cause I've been putting up with this issue since just after this photo was taken.
Re: Analyze this? (Wheel hop) [Re: 1E2C] #1620507
05/16/14 12:40 AM
05/16/14 12:40 AM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
I don't think that progressive helper spring is doing anything for your wheel hop. You need to clamp each leaf to the spring bundle in front of the axle. That is the easiest and cheapest thing to try right now.
If you do it let us know if it helped then you can consider other options if needed.
Don't be the exception.
Re: Analyze this? (Wheel hop) [Re: Supercuda] #1620508
05/16/14 02:04 AM
05/16/14 02:04 AM
scratchnfotraction Offline
your overload spring is not helping and can be causing the wheel hop.
I removed the overload leaf from my spring pack for a 4 leaf spring pack...I added 2" drop shackles...I built some traction bars that bolt on top of leafs.
I also made a torque strap tying the engine to frame up front.
now my whiplash roller cam 318 with NV4500 5 speed will smoke 1,2,3 gear with no wheel hop.
on the 88-440 truck I did a shackle flip with axle flop, a-body 8 3/4 with 12" rims 29x15x15 MTs in the fenders. no wheel hop what so ever with the flip flop/stock 3 leaf spring.
Re: Analyze this? (Wheel hop) [Re: scratchnfotraction] #1620509
05/16/14 02:06 AM
05/16/14 02:06 AM
Re: Analyze this? (Wheel hop) [Re: 1E2C] #1620510
05/16/14 03:12 PM
05/16/14 03:12 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
My 92 D250 has done that too. It doesn't happen all the time.
Quit doing burnouts. It's a truck setup for carrying loads, not hot rodding.
You need to find a way to keep the front of the spring from flexing.
- Stu Harmon
Re: Analyze this? (Wheel hop) [Re: feets] #1620511
05/16/14 07:33 PM
05/16/14 07:33 PM
indiana
mcmopars Offline
mcmopars  Offline
indiana
quit doing burnouts??in a mopar?in a truck?trucks are the new in thing
Re: Analyze this? (Wheel hop) [Re: mcmopars] #1620512
05/16/14 08:04 PM
05/16/14 08:04 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
My little truck has done burnouts, figure eights, gone airborne, and a multitude of other non-truck things. That Cummins keeps right on pumping.
However, I've had wheel hop on a prepped drag strip. Since my truck is used for mostly truck like work (when not beeing a hoon) my solution was to launch a little easier and save the driveline.
- Stu Harmon
Re: Analyze this? (Wheel hop) [Re: feets] #1620513
05/16/14 10:48 PM
05/16/14 10:48 PM
Northern MN
1E2C Offline OP
1E2C  Offline OP
Northern MN
Yeah, I'm mostly with ya feets, I mean, it's taken over 10 years to ask about it if ya check the photo dates....... I mostly just drive it and avoid the hammer, but the other night after I redid the carb and made the changes I'd been planning for years it ran so sweet I had to try again - and the black marks just looked so dang weird with the scalloped edge kinda thing I had to play it a bit.
Now I'm not against yanking the spring style overloads and putting in some airbags to catch the weight when I absolutely need it so I can effectively play without them most of the time, but it is hard to justify that kinda change for a once or twice a year burnout (or whenever I get unresistable urges to be stoopid.)
