Small block Eddies and solid roller lifters #1620450
05/15/14 05:58 PM
05/15/14 05:58 PM
Tulsa OK
Bad340fish Offline OP
Tulsa OK
I am assuming it is possible to safely remove enough material from the heads that the lifters can be removed with the heads on? I am running comp 828-16s.
I am changing my roller lifters out before drag week this year so I will have the heads off and would like to modify them if possible. It would be super awesome if I could do it with them on the car, but I am sure its not that easy!
68 Barracuda Formula S 340
Re: Small block Eddies and solid roller lifters [Re: Bad340fish] #1620451
05/15/14 07:00 PM
05/15/14 07:00 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Clark... I did the same thing to my W-2 heads.. the
only ones that had to have work were the end sets..
can you check yours(is your intake off) to see which
ones need work.. also its would make a difference on
how much the deck has been cut.. if any
Re: Small block Eddies and solid roller lifters [Re: MR_P_BODY] #1620452
05/16/14 09:30 PM
05/16/14 09:30 PM
Kissimmee Fl.
dusturbd340W5 Offline
Kissimmee Fl.
yes a lot depends on deck height, mine was at 9.350 and there was no way a roller lifter was coming out without pulling the heads.
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
Re: Small block Eddies and solid roller lifters [Re: dusturbd340W5] #1620453
05/17/14 10:36 AM
05/17/14 10:36 AM
Tulsa OK
Tulsa OK
I am sure the block has been cut some, as the pistons are zero deck and not custom. I'll have to pull the intake and look again. This is something I should have checked while it was apart lol.
Re: Small block Eddies and solid roller lifters [Re: Bad340fish] #1620454
05/17/14 01:32 PM
05/17/14 01:32 PM
NJ central
Scamp408 Offline
Scamp408  Offline
NJ central
So from my reading here the 828 lifters wont come out unless you take the heads off?
Re: Small block Eddies and solid roller lifters [Re: Scamp408] #1620455
05/17/14 01:54 PM
05/17/14 01:54 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I havent checked all the different lifters but of
the ones I have, I havent had all 8 sets come out
without some work... on most the end sets need a bit
of clearance added on the bottom of the head... this
is with a minor bit of deck cut... even the center
clys are close but with a bit of wiggle they come out
Re: Small block Eddies and solid roller lifters [Re: Scamp408] #1620456
05/17/14 05:01 PM
05/17/14 05:01 PM
Tulsa OK
Tulsa OK
Mine won't, they could be pulled up for a cam swap no problem but removing them isn't going to happen. I will be changing them in a few weeks and I will try and remember to snap some pics.
Re: Small block Eddies and solid roller lifters [Re: Bad340fish] #1620457
05/19/14 09:58 AM
05/19/14 09:58 AM
NJ central
Scamp408 Offline
Scamp408  Offline
NJ central
Well this throws a monkey wrench in my whole plan.
Re: Small block Eddies and solid roller lifters [Re: Scamp408] #1620458
05/19/14 10:15 AM
05/19/14 10:15 AM
Tulsa OK
Tulsa OK
It wouldn't be a Mopar if it didn't would it?
Re: Small block Eddies and solid roller lifters [Re: Bad340fish] #1620459
06/10/14 10:22 AM
06/10/14 10:22 AM
Tulsa OK
Tulsa OK
I pulled the motor Sunday afternoon and got the intake and rocker gear off last night. It looks like i would have to shave a good amount of meat from the heads to get the lifters out. The deck area of the head overlaps into the valley a fair amount and that is where the hold up is. I am going to check with Ryan J and see what he thinks about taking out material there.
I do know if it wasn't for drag week I wouldn't be replacing anything. 5000ish miles on this valvetrain(other than the springs) and it all looks great. I figured its best to swap in some new lifters and send these to comp to be checked out rather than wait for them to fail
Re: Small block Eddies and solid roller lifters [Re: Bad340fish] #1620460
06/10/14 11:38 AM
06/10/14 11:38 AM
MR_P_BODY Offline
MR_P_BODY  Offline
If I recall you blocked off the oil to the lifters
and just use the return oil to lube them... what do
you idle at(rpm) and what is your spring pressure
Re: Small block Eddies and solid roller lifters [Re: Bad340fish] #1620461
06/10/14 12:00 PM
06/10/14 12:00 PM
Renton Washington
Triple Threat Offline
Renton Washington
Let us know what they say...
-Dustin
67 Dart, 9 second, 392" G3 Hemi
68 Barracuda 340 F/SA
Re: Small block Eddies and solid roller lifters [Re: MR_P_BODY] #1620462
06/10/14 12:36 PM
06/10/14 12:36 PM
Tulsa OK
Tulsa OK
It idles about 1200RPM. The cam is grooved so it oils full time and I don't have any restrictions in it. Being a street car I figured I can't get to much oil up top as long as I hold solid oil pressure on the big end.
Re: Small block Eddies and solid roller lifters [Re: Bad340fish] #1620463
06/10/14 01:08 PM
06/10/14 01:08 PM
Charleston
sixpackgut Offline
Drag Week Mod Champion
sixpackgut  Offline
Charleston
Clark, I once changed lifters without removing the intake
Re: Small block Eddies and solid roller lifters [Re: sixpackgut] #1620464
06/10/14 03:52 PM
06/10/14 03:52 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Dig the Mountain Dew overflow bottle................. The very first time I raced at L.A.C.R. I had no clue about tech so upon getting my junk inspected they pointed out that I needed an overflow bottle or I couldn`t race. Well I finished my Southern Comfort and Cherry Coke that I was drinking out of a blue sports bottle(stupid I know)and asked if this would work and he said just secure it well and have fun and it`s been on ever since which has been over 22+ years.
Re: Small block Eddies and solid roller lifters [Re: Thumperdart] #1620465
06/10/14 04:00 PM
06/10/14 04:00 PM
Andrews,In. U.S.of A.
67_Satellite Online content
67_Satellite  Online Content
By the looks of the towel in the intake he must be one of Jeff Gordons "rainbow warriors" too.
Re: Small block Eddies and solid roller lifters [Re: 67_Satellite] #1620466
06/10/14 04:02 PM
06/10/14 04:02 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Tho what are you thaying thilly............
Re: Small block Eddies and solid roller lifters [Re: sixpackgut] #1620467
06/10/14 04:46 PM
06/10/14 04:46 PM
Indy
FlyFish Offline
FlyFish  Offline
Indy
Now that's just COLD man!!
67 Barracuda street car, 408, e85, 1.38 60', 6.44 @105.9 in the 1/8 mile, 10.19 @130.5 in the 1/4...so far....
Re: Small block Eddies and solid roller lifters [Re: sixpackgut] #1620468
06/10/14 06:00 PM
06/10/14 06:00 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
Ya but did you do it on a 360 powered 1976 Dodge van in the parking garage, during vacation, at Ocean City, MD. I did.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Small block Eddies and solid roller lifters [Re: sixpackgut] #1620469
06/11/14 12:27 AM
06/11/14 12:27 AM
Tulsa OK
Tulsa OK
That was uncalled for lol.
