Throttle bracket............ #1619945
05/14/14 12:00 AM
05/14/14 12:00 AM
North, Alabama
D-50 Offline OP
D-50  Offline OP
North, Alabama
What throttle bracket does everybody use with there Dominator carb. I am switching from a 950 to a dominator with a spacer and my throttle cable bracket is not tall enough. I tried to use it and the angle is so bad it makes the pedal hard to push. I am also still using stock throttle cable.
THANKS.........
1.33 60 ft,6.21 at 110.59 in the 1/8, pump gas small block,2950lbs,drag radials,mufflers and driven to track ...
Re: Throttle bracket............ [Re: D-50] #1619946
05/14/14 12:12 AM
05/14/14 12:12 AM
Taxes & Virus's R-US, NY
Dragula Online content
Dragula  Online Content
Please post what gains you get from it...What dominator did you go with?
I have a Pro Systems Bracket for my SV1, and I know those will fit a dominator.
Re: Throttle bracket............ [Re: Dragula] #1619947
05/14/14 12:18 AM
05/14/14 12:18 AM
North, Alabama
D-50 Offline OP
D-50  Offline OP
North, Alabama
Do not know if I will get any gains yet. I put it on and could not get it to idle. I sent it to ProSystems today for a refresh and updates. When I had it on it the throttle was really hard to mash since the angle was really bad from using the old cable bracket. I just want to have everything corrected by the time the carb comes back next week.
Re: Throttle bracket............ [Re: D-50] #1619948
05/14/14 12:34 AM
05/14/14 12:34 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Sounds like the cable is too short... look on Mancini's
site for a longer one
Re: Throttle bracket............ [Re: D-50] #1619949
05/14/14 04:01 AM
05/14/14 04:01 AM
Mo.
racerx Online work
racerx  Online Work
Mo.
Jegs with a stock cable
Re: Throttle bracket............ [Re: racerx] #1619950
05/14/14 09:44 AM
05/14/14 09:44 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
I run Mancin gracket with M1 and My dominator.I run a Dart /6 cable.I believe Andy a member here makes the brackets.They make them for different intakes also.Rocky
Chrysler Firepower
Re: Throttle bracket............ [Re: D-50] #1619951
05/14/14 01:26 PM
05/14/14 01:26 PM
AndyF Offline
AndyF  Offline
Re: Throttle bracket............ [Re: racerx] #1619952
05/14/14 02:17 PM
05/14/14 02:17 PM
Renton Washington
Triple Threat Offline
Renton Washington
What I run as well.
-Dustin
67 Dart, 9 second, 392" G3 Hemi
68 Barracuda 340 F/SA
Re: Throttle bracket............ [Re: Triple Threat] #1619953
05/14/14 02:59 PM
05/14/14 02:59 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Andy thats the one I have.Works perfect and also well made.I thought it was you design.Picked mine up pretty cheap at Carlisle from Mancin about 8 years ago.I did have to modify the cable end from the 73 dart to fit my 65 pedal.Rocky
Chrysler Firepower
Re: Throttle bracket............ [Re: therocks] #1619954
05/14/14 06:48 PM
05/14/14 06:48 PM
AndyF Offline
AndyF  Offline
Thanks. I've been making the tall throttle brackets for about 15 years now. I have a press out in the shop and I just knock them out as the orders come in. Mancini has been selling them for a long time now. I ended up designing brackets for various Mopar engines including cross rams and dual quad intakes of various flavors.
Re: Throttle bracket............ [Re: AndyF] #1619955
05/14/14 08:34 PM
05/14/14 08:34 PM
North, Alabama
D-50 Offline OP
D-50  Offline OP
North, Alabama
http://arengineering.com/products/extra-tall-bracket413426w-and-440/
That is the one I have and it is not tall enough.
Re: Throttle bracket............ [Re: D-50] #1619956
05/15/14 02:49 PM
05/15/14 02:49 PM
AndyF Offline
AndyF  Offline
The bracket will work with an Indy intake plus a spacer. The bracket is adjustable so you can change the angle of the throttle cable.
Re: Throttle bracket............ [Re: AndyF] #1619957
06/04/14 10:35 PM
06/04/14 10:35 PM
Scatchamatoon
Saskabusa Offline
Saskabusa  Offline
Scatchamatoon
I run that on an Indy 3X intake and a dominator.
Works great.
1974 Roadrunner
1967 Charger
Re: Throttle bracket............ [Re: Saskabusa] #1619958
06/04/14 10:52 PM
06/04/14 10:52 PM
Alabama
Mopar-Al Offline
Mopar-Al  Offline
Alabama
Since my car is a race car, I just run a steel rod, it is a lot less headaches
Re: Throttle bracket............ [Re: Mopar-Al] #1619959
06/05/14 01:35 AM
06/05/14 01:35 AM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
I run a jegs bracket on my dominator. I wish you would have sent it back up here, we could have fixed it.
Brett Miller W9 cnc'd heads
STR Chassis fabraction
