Throttle bracket............
#1619945
05/14/14 12:00 AM
05/14/14 12:00 AM
Posts: 1,267 North, Alabama
D-50
North, Alabama
What throttle bracket does everybody use with there Dominator carb. I am switching from a 950 to a dominator with a spacer and my throttle cable bracket is not tall enough. I tried to use it and the angle is so bad it makes the pedal hard to push. I am also still using stock throttle cable. THANKS.........
1.33 60 ft,6.21 at 110.59 in the 1/8, pump gas small block,2950lbs,drag radials,mufflers and driven to track ...
Re: Throttle bracket............
[Re: D-50]
#1619946
05/14/14 12:12 AM
05/14/14 12:12 AM
Posts: 12,408 Taxes & Virus's R-US, NY
Dragula
Please post what gains you get from it...What dominator did you go with?
I have a Pro Systems Bracket for my SV1, and I know those will fit a dominator.
[Re: Dragula]
#1619947
05/14/14 12:18 AM
05/14/14 12:18 AM
D-50
North, Alabama
Do not know if I will get any gains yet. I put it on and could not get it to idle. I sent it to ProSystems today for a refresh and updates. When I had it on it the throttle was really hard to mash since the angle was really bad from using the old cable bracket. I just want to have everything corrected by the time the carb comes back next week.
[Re: racerx]
#1619950
05/14/14 09:44 AM
05/14/14 09:44 AM
Posts: 21,081 Niles , Ohio
therocks
Niles , Ohio
I run Mancin gracket with M1 and My dominator.I run a Dart /6 cable.I believe Andy a member here makes the brackets.They make them for different intakes also.Rocky
Chrysler Firepower
[Re: D-50]
#1619951
05/14/14 01:26 PM
05/14/14 01:26 PM
Posts: 31,060 Oregon
AndyF
[Re: Triple Threat]
#1619953
05/14/14 02:59 PM
05/14/14 02:59 PM
therocks
Niles , Ohio
Andy thats the one I have.Works perfect and also well made.I thought it was you design.Picked mine up pretty cheap at Carlisle from Mancin about 8 years ago.I did have to modify the cable end from the 73 dart to fit my 65 pedal.Rocky
Chrysler Firepower
[Re: Mopar-Al]
#1619959
06/05/14 01:35 AM
06/05/14 01:35 AM
Posts: 3,978 Hilltown Pa
1967dartgt
Hilltown Pa
I run a jegs bracket on my dominator. I wish you would have sent it back up here, we could have fixed it.
Brett Miller W9 cnc'd heads STR Chassis fabraction
