Engine oil suggestions #1618046
05/09/14 08:54 AM
05/09/14 08:54 AM
Riyadh, Saudi Arabia
Merlin45 Offline OP
Merlin45  Offline OP
Just had my 440/6 rebuilt and put several hundred miles on it and wanted inputs on best engine oil options and where to get it when I change the oil. The engine is a basic 440 build, 030 over and a mild cam, new headers, auto trans, with a new 4 row radiator. My engine builder recommends a good quality race oil, recommending 20w 50 for the summer and 10w 30 for the winter (though the car is parked during the winter months). What oil would meet my needs? Where do I get it? Do I order it and have it shipped to my home address or go to a parts store and get it.
Thanks!
Re: Engine oil suggestions [Re: Merlin45] #1618047
05/09/14 09:40 AM
05/09/14 09:40 AM
Rancho Cordova, CA
Exit1965 Offline
Exit1965  Offline
Rancho Cordova, CA
This topic comes up a lot.
I'm no expert but I'd recommend Rotella T or Delo 400 LE. Both have fairly high levels of zinc to protect a flat tappet cam and are easy to find and not expensive.
I run it, my dad runs it, many here run this diesel oil no problems.
I personally think race oil would be money out the window for your engine. It sounds fairly mild. Even fairly wild engines are getting by with cheap diesel oil.
Re: Engine oil suggestions [Re: Merlin45] #1618048
05/09/14 09:52 AM
05/09/14 09:52 AM
Philadelphia PA
Pynzo Offline
Drugs are bad
Pynzo  Offline
Drugs are bad
Philadelphia PA
I use Valvoline 20/50. You can get it at most part stores.
Re: Engine oil suggestions [Re: Merlin45] #1618049
05/09/14 01:02 PM
05/09/14 01:02 PM
Memphis
HemiRick Offline
HemiRick  Offline
Memphis
I 2nd the diesel oil suggestion, modern day motor oil does not have the stuff a flat tappet cam needs.
Take care,
Rick
68 Coronet R/T 440 & 68 Charger 528 Hemi,and 5 Challengers! 6 cyl, 318, 360, 383, 451
Re: Engine oil suggestions [Re: Merlin45] #1618050
05/09/14 01:11 PM
05/09/14 01:11 PM
Indiana
Y
YO7_A66 Offline
YO7_A66  Offline
Y
Indiana
Brad Penn Green Oil.
Re: Engine oil suggestions [Re: YO7_A66] #1618051
05/09/14 01:20 PM
05/09/14 01:20 PM
X2 on the Bradd Penn & your next decision will be how often you'll change it. I would checkout www.bobistheoilguy.com Valvoline delo rotella diesel oil & others are good as is using GM EOS as an additive & might checkout hughes engines for his take on it
Re: Engine oil suggestions [Re: Merlin45] #1618052
05/09/14 01:21 PM
05/09/14 01:21 PM
PORT ALBERNI , BC., CANADA
superwrench Offline
superwrench  Offline
I used to run 20w-50 in my Hemi car. It had awesome oil pressure, but the downside was the time it took the pressure to rise when started cold. I didn't like that.....a good 5 seconds for the guage to reach 85#.
So....to make the story short, the only vehicle out of the 5 I have that DOESN'T use 15W40 Rotella is my wifes 07 Charger 3.5 HO.
Makes the trip to the parts store simple !!!
Re: Engine oil suggestions [Re: superwrench] #1618053
05/09/14 01:26 PM
05/09/14 01:26 PM
, the only vehicle out of the 5 I have that DOESN'T use 15W40 Rotella .
I'm assuming you're getting the multiple case discount
Re: Engine oil suggestions [Re: RapidRobert] #1618054
05/09/14 01:51 PM
05/09/14 01:51 PM
superwrench Offline
superwrench  Offline
LOL ! .....buy it by the 19 litre pail.....60 bucks. One heck of a lot cheaper than individual jugs.
I just usually stick some Comp #159 break-in stuff in with the oil when I service the race car.
Re: Engine oil suggestions [Re: superwrench] #1618055
05/09/14 01:55 PM
05/09/14 01:55 PM
I gotta bone up on my metric, how many gallons is that in American
Re: Engine oil suggestions [Re: Merlin45] #1618056
05/09/14 02:06 PM
05/09/14 02:06 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Royal Purple
Re: Engine oil suggestions [Re: RapidRobert] #1618057
05/09/14 02:08 PM
05/09/14 02:08 PM
Kirkland, Washington
Pacnorthcuda Offline
5 gallons
Re: Engine oil suggestions [Re: DAYCLONA] #1618058
05/09/14 02:09 PM
05/09/14 02:09 PM
Cincinnati, Ohio
superbeedave Offline
Cincinnati, Ohio
Brad Penn!
Re: Engine oil suggestions [Re: Pacnorthcuda] #1618059
05/09/14 02:12 PM
05/09/14 02:12 PM
superwrench Offline
superwrench  Offline
5 gallons
....4.17 IMPERIAL gallons (just to confuse things ) !!!!
Re: Engine oil suggestions [Re: superwrench] #1618060
05/09/14 02:16 PM
05/09/14 02:16 PM
5 gallons
Only Feets drives an Imperial!
Re: Engine oil suggestions [Re: Merlin45] #1618061
05/09/14 02:29 PM
05/09/14 02:29 PM
I have been using 5W20Wt Valvoline non synthetic in all my Hi Po Mopar motors for a long time, the roller lifter motors get no additives, the flat lifter cam motors get a bottle of either zinc additive or Comp Cams lcam lube There have been horror storys posted on this site about deisel oil foaming, I have no expereince with that so I won't comment on it You need to think about what oil does for our motors, it needs to lubricate and cool That being said thinner oil moves quicker and with less resistance to the oil pump when cold, it also take less HP to turn the oil pump I've seen 10 HP loss at 130 F with straight 30 Wt oil years ago compared to the same oil and motor when we let the oil temps climb to 160 F No loss or gain of HP or torque when using 5W20Wt from 80F to 230 F I do run very loose oil clearances on the rod and main bearings also, .003 + on both I've shifted my 650 HP + pump gas street motor at or above 7000 RPM for a long time when running it at the track, a lot of laps over the years with no noticeable bearing wear or abuse OP, run what you feel comfortable with BTW, I do run both Rotella and Delo 400 in my CTD truck, depending on where and when I have the oil and filter changed and what they have in stock If you want to run race oil in your motor the only one I would run now is the RACING Pennzoil 25W50WT It has some lube additives, friction reduction, that no other oil has that I know of You can feel it when rubbing it between your fingers All the SCCA raers I know use it now
Re: Engine oil suggestions [Re: Cab_Burge] #1618062
05/09/14 08:17 PM
05/09/14 08:17 PM
Merlin45 Offline OP
Merlin45  Offline OP
Is the Pennzoil 25W50WT available off the shelf or do you need to order it from a part store? What's the cost per Quart? Many people talk about Zinc content and I see normal commercial oils recommended, do they have a high enough Zinc content? Several people run diesel oil and have great luck, some worry the oil foams so that makes me stay away from diesel oil in my engine. I change my oil once per year due to working in Kuwait so my drive miles are very small per year. Thanks for your comments.
Re: Engine oil suggestions [Re: YO7_A66] #1618063
05/09/14 08:20 PM
05/09/14 08:20 PM
Merlin45 Offline OP
Merlin45  Offline OP
Do you order the oil direct from Brad Penn? Or order it from a parts store? What's the cost per quart? I've heard of BP products and the happy customers but have never used them.
Re: Engine oil suggestions [Re: Exit1965] #1618064
05/09/14 08:23 PM
05/09/14 08:23 PM
IN
ahy Offline
ahy  Offline
IN
Me too in a low deck stroker. Rotella T 15W40 gives me good oil pressure at hot idle and handles the moderately cool temps (mid 20's) I occasionally encounter in 3 season driving. I usually get it at Walmart.
Re: Engine oil suggestions [Re: Merlin45] #1618065
05/09/14 08:53 PM
05/09/14 08:53 PM
Jacksonville, FL
Chris2581 Offline
Chris2581  Offline
Jacksonville, FL
I use either 15w40 Mobil Delvac diesel oil or Shell Rotella 15w40 diesel.Never any problems.
Nautilus Racing-
