Who sells rebuilt or new 4speed shifters #1615070
05/02/14 03:59 PM
05/02/14 03:59 PM
Athens, Greece
Pyper70 Offline OP
Pyper70  Offline OP
Athens, Greece
There is a lot of slop in this shifter on my buddy's car (A833) and we wanna tighten it up a bit. I'd rather buy one than have ours rebuilt.
Also...because I have played with 727s all my life...how hard is it to do the adjustment on the linkages of the shifter? Is there a walkthrough to follow somewhere?
Family owned 1969 Charger R/T DualQuad 440/727/GVO/3.55s
Re: Who sells rebuilt or new 4speed shifters [Re: Pyper70] #1615071
05/02/14 04:06 PM
05/02/14 04:06 PM
tennessee
P
pushbutton Offline
pushbutton  Offline
P
tennessee
Brewers can probably fix you up with a shifter and the adj. imfo also.
www.brewersperformance.com
Re: Who sells rebuilt or new 4speed shifters [Re: pushbutton] #1615072
05/02/14 04:13 PM
05/02/14 04:13 PM
South San Francisco, Ca
70sixpkrt Offline
70sixpkrt  Offline
I sent mine to Hurst to rebuild. That was about 10 years ago. If you want new call Brewers or Passon. Passon added positive stops on mine about 5 years ago.
[img]http://www.imgur.com/hxlGUJt.gif[/img]
4-speed
3:54 Dana
13.01 @107.93 with street tires (not hooking up)
Re: Who sells rebuilt or new 4speed shifters [Re: 70sixpkrt] #1615073
05/02/14 05:55 PM
05/02/14 05:55 PM
Athens, Greece
Pyper70 Offline OP
Pyper70  Offline OP
Athens, Greece
How do the positive stops help in shifting?
Re: Who sells rebuilt or new 4speed shifters [Re: pushbutton] #1615074
05/02/14 06:13 PM
05/02/14 06:13 PM
Philadelphia PA
Pynzo Offline
Drugs are bad
Pynzo  Offline
Drugs are bad
Philadelphia PA
I had Hurst rebuild mine a while back('92). The price has tripled since then. Brewers has the whole parts kit for sale and I'd go with that for original appearance, otherwise Hurst sells new shifters and pistol grips. And it's very simple to get the rods adjusted, check a service manual.
Re: Who sells rebuilt or new 4speed shifters [Re: Pynzo] #1615075
05/02/14 07:07 PM
05/02/14 07:07 PM
70sixpkrt Offline
70sixpkrt  Offline
positive stops physically stop the shifter once its gone in gear
4-speed
3:54 Dana
Re: Who sells rebuilt or new 4speed shifters [Re: Pyper70] #1615076
05/02/14 07:08 PM
05/02/14 07:08 PM
Chicken coop
dustergirl340 Offline
Chicken Little
Chicken Little
Chicken coop
Brewers or Passon, as mentioned. Both great companies with great products.
Re: Who sells rebuilt or new 4speed shifters [Re: Pynzo] #1615077
05/02/14 07:37 PM
05/02/14 07:37 PM
Athens, Greece
Pyper70 Offline OP
Pyper70  Offline OP
Athens, Greece
Would you recommend getting new shift linkages along with the shifter mechanism? Maybe the ends of the linkages are worn out? I imagine so since many of the other parts on this car seem to have been junkyard scores and installed to sell the car quick...the linkages may have an issue as well...its this dude's dream car so i don't think the car is going anywhere anytime soon
Re: Who sells rebuilt or new 4speed shifters [Re: dustergirl340] #1615078
05/02/14 07:40 PM
05/02/14 07:40 PM
USA
Grizzly69 Online content
Grizzly69  Online Content
USA
Re: Who sells rebuilt or new 4speed shifters [Re: Grizzly69] #1615079
05/02/14 07:51 PM
05/02/14 07:51 PM
Philadelphia PA
Pynzo Offline
Drugs are bad
Pynzo  Offline
Drugs are bad
Philadelphia PA
New Hursts have the stops mentioned and use bushings at the shifter ends. They come with nylon bushings but you used to be able to get steel ones. The new Hursts have bolt in handles where the originals pushed into a clip. Get a set of new rods just to ease your mind- the Pistol Grips they make new are very nice. Is this a console car?
Re: Who sells rebuilt or new 4speed shifters [Re: Pyper70] #1615080
05/02/14 11:28 PM
05/02/14 11:28 PM
mt. pleasant, PA
Diplomat440 Offline
Diplomat440  Offline
mt. pleasant, PA
The best thing is to get the whole kit, new mechanism, rods, levers, bushings, they even come with billet mounting brackets now.
Brewers and Passon are both great to deal with
Re: Who sells rebuilt or new 4speed shifters [Re: Pyper70] #1615081
05/03/14 05:47 PM
05/03/14 05:47 PM
Missouri
68KillerBee Offline
68KillerBee  Offline
Missouri
I bought brewers kit and did it myself. or you can send it to them and they will install the kit.
http://www.brewersperformance.com/proddetail.asp?prod=H0001
Re: Who sells rebuilt or new 4speed shifters [Re: Pyper70] #1615082
05/03/14 06:34 PM
05/03/14 06:34 PM
Georgia
Steve Bryant Offline
Georgia
Wayne/Dan at Brewers can hook you up. It will cost about 1/4 the price to get the parts and rebuild it yourself and there are far fewer parts than you might imagine.
The shift levers in the shifter are probably good but there are wavy shim plates that go in the shifter body that can wear and create some slop. Also, the pin could be worn. For $100 you can get the entire shifter rebuild kit from Brewers. As far as the rods are concerned there are nylon inserts that you can install to take some of that slop out. It is rare that the rods themselves are bad.
Lastly, a majority of my slop was with the operating levers for 1-2 and 3-4 on the transmission itself. Not only that, the shift levers themselves can get their studs rounded off.
Feel free to take some photos and send them to us. Replacing the shifter and rods may not be enough and it could be way too much. For mine, I had to replace the shifter shims, the shifter levers (inside the side cover) and one operating lever.
Re: Who sells rebuilt or new 4speed shifters [Re: Steve Bryant] #1615083
05/03/14 09:37 PM
05/03/14 09:37 PM
Athens, Greece
Pyper70 Offline OP
Pyper70  Offline OP
Athens, Greece
I mentioned it to my buddy and its his decision. It's 299 for the shifter with the stops and 149 for the rod kit from Brewers. It used to be a console car but it looked awful so we removed it and put the boot and bezel on the floor...looks much much nicer
Re: Who sells rebuilt or new 4speed shifters [Re: Pyper70] #1615084
05/04/14 10:25 AM
05/04/14 10:25 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Is the shifter itself sloppy?The OE one in my 65 was sloppy and loose shiftibg.I was going to have it rebuilt.Through the years the factory rod pins that hold them to the arms were either gone or worn and cotter pins used.I got the Hurst kit with new clips and bushings.I couldnt believe how tight the shifting got.Its still in the car and shifts great.65 Ma used a good Hurst with stops.Rocky
Chrysler Firepower
Re: Who sells rebuilt or new 4speed shifters [Re: therocks] #1615085
05/05/14 11:48 AM
05/05/14 11:48 AM
Athens, Greece
Pyper70 Offline OP
Pyper70  Offline OP
Athens, Greece
I can feel slop in the shifting but I don't have anything to compare it to as all my cars have been automatics. It surely can't hurt anything doing it now, correctly, so it lasts 2 more decades
Re: Who sells rebuilt or new 4speed shifters [Re: Pyper70] #1615086
05/05/14 03:14 PM
05/05/14 03:14 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
My box has lasted 4 decades.Just some lube and the new clips from Summit.I couldnt believe how it tightened up the shifter.Rocky
Chrysler Firepower
