12/04/08 09:03 PM
12/04/08 09:03 PM
griff70440 Offline OP
Hi guys.
In 76 did 440 motors only have cast cranks or did some(truck motors)have steel cranks?
its got a polit hole for a 4spd.the motor didn`t come with a damper.
how can I tell what the crank is?
thanks mike
Re: 1976 440 [Re: griff70440] #161277
12/04/08 09:10 PM
12/04/08 09:10 PM
3
340dart4spd Offline
Parts Problem
340dart4spd  Offline
Parts Problem
3
doubt it's a steel crank motor... I did find one in a Original 73 car once..
Re: 1976 440 [Re: griff70440] #161278
12/04/08 09:10 PM
12/04/08 09:10 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
Forged cranks were gone. Some trucks still got the heavy 6 pack style rods but put on the cast cranks. I'm sure those engines balanced horribly from the factory but they did it.
All 440's had the pilot hole in the back. It was a two step process. They all had a rough pilot hole, but ones that were destined for a stick shift were bored out and drilled a little deeper.
Re: 1976 440 [Re: DaytonaTurbo] #161279
12/04/08 09:55 PM
12/04/08 09:55 PM
Sk. Canada
RemCharger Offline
RemCharger  Offline
Sk. Canada
I've got a 75 truck with a steel crank , so never say never. you will have to look at the crank to know for sure, or try it with different balancers and see which one it likes
Re: 1976 440 [Re: griff70440] #161280
12/04/08 10:06 PM
12/04/08 10:06 PM
Garden Grove, CA
OzHemi Offline
Penguin-hating Ginger
OzHemi  Offline
Garden Grove, CA
You could always just pull the oil pan for a look..
Re: 1976 440 [Re: OzHemi] #161281
12/04/08 11:09 PM
12/04/08 11:09 PM
Carstairs, Alberta, Canada
dave571 Offline
dave571  Offline
No substitute for a real look.
I've seen Class A mh chassis motors that were steel as new as 79.
The pilot hole may not tellyou much either way. Even a lot steels didn't have that.
More than likely cast, but worth a look.
Re: 1976 440 [Re: dave571] #161282
12/05/08 12:01 AM
12/05/08 12:01 AM
Madison Wi
NTOLERANCE Offline
NTOLERANCE  Offline
Madison Wi
I have owned 3 steel crank big blocks well past the magical '73 cut off date.
All were 3/4 ton trucks.
Two were stick, one auto.
Auto truck had a 400,727 and a D60 front axle.
This was a 1978 vintage
Stick trucks, one was 400, one was 440. One was 78 one was 77.
Why did these HD trucks get a steel crank? Not sure, but if I had to guess, Mopar was getting out of the big block business, so perhaps they were using left over replacement cranks or parts from Direct Connnection, to use up stock or fill needed orders.
Re: 1976 440 [Re: NTOLERANCE] #161283
12/05/08 12:10 AM
12/05/08 12:10 AM
3
340dart4spd Offline
Parts Problem
340dart4spd  Offline
Parts Problem
3
mine was a car... besides who said never...
Re: 1976 440 [Re: 340dart4spd ] #161284
12/05/08 12:22 AM
12/05/08 12:22 AM
Abilene, Texas
fastmark Online content
fastmark  Online Content
Abilene, Texas
I have a 76 steel crank 440 from a 1 ton truck sitting at the shop right now.
Re: 1976 440 [Re: 340dart4spd ] #161285
12/05/08 12:27 AM
12/05/08 12:27 AM
Madison Wi
NTOLERANCE Offline
NTOLERANCE  Offline
Madison Wi
I didnt say it.
They OP mentioned trucks and I related MY experience.
Re: 1976 440 [Re: NTOLERANCE] #161286
12/05/08 10:15 AM
12/05/08 10:15 AM
Dennispsalm91 Offline
I have a 76 440 , no pilot hole in my crank thats why i getting rid of it
Re: 1976 440 [Re: griff70440] #161287
12/05/08 11:16 AM
12/05/08 11:16 AM
Whats the vibration damper look like?
Sheldon
Re: 1976 440 [Re: NTOLERANCE] #161288
12/05/08 11:46 AM
12/05/08 11:46 AM
Charlotte, NC
446acuda Offline
446acuda  Offline
Charlotte, NC
I've seen a few steel crank 440's right up to '78. I had a '76 400 with a .010/.010 steel crank. Has a maltese cross on the pad so that's the way it came from the factory. Also big '73-4 motorhomes seem to always have a 440-3 with a steel crank, six pak rods and internal balance since the low comp pistons were lighter.
Re: 1976 440 [Re: Dennispsalm91] #161289
12/05/08 11:58 AM
12/05/08 11:58 AM
There was an article where they used a MP roller bearing to support the input shaft placing it(further forward) in the crank recess where a torque converter nose would normally fit then just hand drilling out the hole in the crank further back where the pilot bearing would be. They didn't have to dissassemble the crank either. Might save you from having to sell your current engine.
Re: 1976 440 [Re: RapidRobert] #161290
12/05/08 12:37 PM
12/05/08 12:37 PM
Abilene, Texas
Abilene, Texas
The several 76 to 78 steel crank truck motor I have had all had the thin balancer and big rods.
Re: 1976 440 [Re: RapidRobert] #161291
12/05/08 01:54 PM
12/05/08 01:54 PM
3
340dart4spd Offline
Parts Problem
340dart4spd  Offline
Parts Problem
3
Mopar performance sells this part...as at dealer for roller bearing
Re: 1976 440 [Re: 340dart4spd ] #161292
12/05/08 06:27 PM
12/05/08 06:27 PM
the crank is out of the motor,but I`m not sure what it is.how can I tell by looking at the crank?
thanks,
mike
Re: 1976 440 [Re: griff70440] #161293
12/05/08 06:37 PM
12/05/08 06:37 PM
If the parting line is really thin it is a cast crank. If the parting line is thick (about 3/8") it is forged.
Sheldon
Re: 1976 440 #161294
12/05/08 06:39 PM
12/05/08 06:39 PM
Charlotte, NC
446acuda Offline
446acuda  Offline
Charlotte, NC
Sheldon
Also the 440 cast cranks that I have seen have "440" on them
