1976 440
#161276
12/04/08 09:03 PM
12/04/08 09:03 PM
griff70440
Hi guys. In 76 did 440 motors only have cast cranks or did some(truck motors)have steel cranks? its got a polit hole for a 4spd.the motor didn`t come with a damper. how can I tell what the crank is? thanks mike
Re: 1976 440
[Re: dave571]
#161282
12/05/08 12:01 AM
12/05/08 12:01 AM
Posts: 4,384 Madison Wi
NTOLERANCE
Madison Wi
I have owned 3 steel crank big blocks well past the magical '73 cut off date. All were 3/4 ton trucks. Two were stick, one auto. Auto truck had a 400,727 and a D60 front axle. This was a 1978 vintage Stick trucks, one was 400, one was 440. One was 78 one was 77. Why did these HD trucks get a steel crank? Not sure, but if I had to guess, Mopar was getting out of the big block business, so perhaps they were using left over replacement cranks or parts from Direct Connnection, to use up stock or fill needed orders.
Re: 1976 440
[Re: NTOLERANCE]
#161283
12/05/08 12:10 AM
12/05/08 12:10 AM
340dart4spd
Parts Problem
Parts Problem
mine was a car... besides who said never...
Re: 1976 440
[Re: griff70440]
#161287
12/05/08 11:16 AM
12/05/08 11:16 AM
Whats the vibration damper look like?
Sheldon
Re: 1976 440
[Re: NTOLERANCE]
#161288
12/05/08 11:46 AM
12/05/08 11:46 AM
Posts: 2,734 Charlotte, NC
446acuda
Charlotte, NC
I've seen a few steel crank 440's right up to '78. I had a '76 400 with a .010/.010 steel crank. Has a maltese cross on the pad so that's the way it came from the factory. Also big '73-4 motorhomes seem to always have a 440-3 with a steel crank, six pak rods and internal balance since the low comp pistons were lighter.
Re: 1976 440
[Re: RapidRobert]
#161291
12/05/08 01:54 PM
12/05/08 01:54 PM
340dart4spd
Parts Problem
Parts Problem
I have a 76 440 , no pilot hole in my crank thats why i getting rid of it
There was an article where they used a MP roller bearing to support the input shaft placing it(further forward) in the crank recess where a torque converter nose would normally fit then just hand drilling out the hole in the crank further back where the pilot bearing would be. They didn't have to dissassemble the crank either. Might save you from having to sell your current engine.
Mopar performance sells this part...as at dealer for roller bearing
Re: 1976 440
[Re: griff70440]
#161293
12/05/08 06:37 PM
12/05/08 06:37 PM
If the parting line is really thin it is a cast crank. If the parting line is thick (about 3/8") it is forged.
Sheldon
Re: 1976 440
#161294
12/05/08 06:39 PM
12/05/08 06:39 PM
446acuda
Charlotte, NC
Sheldon
Also the 440 cast cranks that I have seen have "440" on them
