Predator guys...Intake manifolds #1608574
04/17/14 02:25 PM
04/17/14 02:25 PM
Las Vegas
Al_Alguire Offline OP
Las Vegas
Any of you guys running the new Predator cast single 4 intake? Not the old style short one I am talking the new style larger volume one. Part number PRE-I4-3. Looking at purchasing one to use in Super Classes, just want to hear if ANYONE has any experience with it. Next question is who is the best place to get one from?
Re: Predator guys...Intake manifolds [Re: Al_Alguire] #1608575
04/17/14 06:42 PM
04/17/14 06:42 PM
Carson City, Nevada
Biginchmopar Offline
Carson City, Nevada
Al,
I got the cast tunnel ram and it is a nice piece. I bought it from Steve G. at Predator Heads .com but that site is down now. Maybe call him on the phone? I don't have a number. You know how I feel about dealing with Indy on anything.
Another guy that is great to deal with is Mike @ Muscle Motors.
Re: Predator guys...Intake manifolds [Re: Biginchmopar] #1608576
04/17/14 07:03 PM
04/17/14 07:03 PM
Las Vegas
Las Vegas
Re: Predator guys...Intake manifolds [Re: Al_Alguire] #1608577
04/17/14 09:01 PM
04/17/14 09:01 PM
Carson City, Nevada
Carson City, Nevada
Now that is a great piece! How many Predator guys are even out there, 5?
I know I want my Predator to make 1200HP and I'm not to sure it will, I guess we will see here inn a couple months.
Re: Predator guys...Intake manifolds [Re: Biginchmopar] #1608578
04/18/14 02:10 AM
04/18/14 02:10 AM
geezer acres rest home
dakotawilly Offline
dakotawilly  Offline
don't see much predator stuff,i believe the standardized formula for predator hp is about 50 dollars per...one can always dream though.or win the lottery.or marry oprah....
SFI 25.5 depends,no leak,even at 213 mph....
Re: Predator guys...Intake manifolds [Re: dakotawilly] #1608579
04/18/14 02:50 AM
04/18/14 02:50 AM
Las Vegas
Las Vegas
They aint that bad..But if you are a Mopar guy not many options. Went the 99 Hemi route, been using B1MC's so this seems like the next logical stop. Someone has to start trying to make these a tad more common place. Then again what am I sayign this is a mopar site where most are scared of new technology
Re: Predator guys...Intake manifolds [Re: Al_Alguire] #1608580
04/18/14 09:38 AM
04/18/14 09:38 AM
Shelton, Ct.
572_HEMI_Cuda Offline
Shelton, Ct.
Why did you step away from the Hemi 99 stuff?
Re: Predator guys...Intake manifolds [Re: Al_Alguire] #1608581
04/18/14 11:21 AM
04/18/14 11:21 AM
Shelby Twp. Mi
HardcoreB Offline
HardcoreB  Offline
Shelby Twp. Mi
Well I already have this one
[IMG]http://i222.photobucket.com/albums/dd105/blowncuda/IMAG03231_zps585596ea.jpeg[/IMG]
I'd call JohnM. and have him make you a different top for that manifold.
Re: Predator guys...Intake manifolds [Re: HardcoreB] #1608582
04/18/14 12:52 PM
04/18/14 12:52 PM
Las Vegas
Las Vegas
Sean I have and the teepee top he wants to use will simply be WAY to tall for the car. It adds another 3.5" to the height/
We got away from the 99 stuff(for now)due to maintenance right now. I will end up racing by myself, well with the wife, from time to time and it simply be to much work for me alone. So I am going to a bigger cube deal and will hope it is less maintenance intensive. Also we will likely have nitrous on this mill incase we decide to travel a bit to run TS. We will likely get back to the 99 stuff at some point as it flat makes power.
The reason I am looking for input on the intake is the ability to run this motor in Super Classes. Maybe we can go 170 in S/ST
Re: Predator guys...Intake manifolds [Re: Al_Alguire] #1608583
04/18/14 01:31 PM
04/18/14 01:31 PM
Carson City, Nevada
Carson City, Nevada
My combo is 596CID deal so I'm hoping it will make power in the lower RPM below 8000rpm. Less spring maintenance I hope. My heads have the Indy CNC port job so I'm guessing they will need a little more work to get them to flow real well.
How big of a deal are you going to run Al?
Re: Predator guys...Intake manifolds [Re: Biginchmopar] #1608584
04/18/14 01:41 PM
04/18/14 01:41 PM
Sweet Home Alabama
MRMOPAR622 Offline
MRMOPAR622  Offline
Sweet Home Alabama
Al,call Indy they are not as Bad or as Hard to deal with as some of these people make them out to be.
"To Be The Man'You Have Got To Beat The Man" "T/D and Pro-Bracket Racer"
Re: Predator guys...Intake manifolds [Re: MRMOPAR622] #1608585
04/18/14 03:54 PM
04/18/14 03:54 PM
Taxes & Virus's R-US, NY
Dragula Online content
Dragula  Online Content
I disagree....And with big $$$ on the line, I would never go direct, ever!
Re: Predator guys...Intake manifolds [Re: Al_Alguire] #1608586
04/18/14 04:07 PM
04/18/14 04:07 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Depending on the plenum volume you might need... you
could just make a flat plate for a single carb and
make a plenum diverted to direct the A/F so you get
away from the center dead space
Re: Predator guys...Intake manifolds [Re: Dragula] #1608587
04/18/14 04:21 PM
04/18/14 04:21 PM
Sweet Home Alabama
MRMOPAR622 Offline
MRMOPAR622  Offline
Sweet Home Alabama
A intake is a intake,and Indy is the one that makes it.
OK Al,since my 1st advice was not helpful.I'll try to be a little more helpful this time.Since you are starting with more or less a clean slate AND WITH BIG $$$ ON THE LINE and you are thinking T/S think about it you are going to need a lot of Cu. In. to do the T/S deal.It would not be very wise to try and build a T/D or T/S engine with less than 700 cu. in.!
Al for once I am not picking at you or trying to give you a hard time.Look at the speeds the T/S car are running now and you know they are only gong to get faster.
Re: Predator guys...Intake manifolds [Re: MRMOPAR622] #1608588
04/18/14 04:38 PM
04/18/14 04:38 PM
Las Vegas
Las Vegas
Billy, believe me I hear ya. This will likely be my LAST attempt at doing this Mopar style. Bad enough I have to pay a $20K premium for a USED Mopar 6.00 cert car but wanna try an build a Mopar deal. Hard to pass up some of the big bore space stuff out there for the price.
I have most of the engine, just looking for possibilities of using it in multiple classes. Lot's of things happening around here It may end up being nothing more than a super class engine when it is done but hoping we can make enough power to get in a TS field. Thankfully for now out here that is quite doable.
Re: Predator guys...Intake manifolds [Re: Biginchmopar] #1608589
04/18/14 11:01 PM
04/18/14 11:01 PM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
You guys need to call Steve Gill.He IS mr preditor
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: Predator guys...Intake manifolds [Re: Al_Alguire] #1608590
04/18/14 11:37 PM
04/18/14 11:37 PM
Lehigh Acres, Florida
rickstershemi Offline
This is what 175 in the super classes can get you....personally I believe the huge HP is growing beyond what these cars are designed for...
Yep....my old vette
Rickster
Re: Predator guys...Intake manifolds [Re: Al_Alguire] #1608591
04/19/14 02:25 AM
04/19/14 02:25 AM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
Why are you hung on running Super Street Al? I guess I don't see the point in having Top Sportsman power and stopping it down to run a 10.90 class. Why not just run Top Sportsman. It's all about the start line and the finish line in both classes, you just don't get the "snooze fest" in the middle with Top Sportsman........LOL!!!
A decent 600" Predator motor should make 1100 fairly easily. With a TS weight car and a moderate amount of nitrous, you can get in a TS field anywhere.
Monte
Re: Predator guys...Intake manifolds [Re: rickstershemi] #1608592
04/19/14 02:36 AM
04/19/14 02:36 AM
dakotawilly Offline
dakotawilly  Offline
maybe u can talk indy into making a mod man intake for predators,but then you would need another two grand in mods just to make it work...
Re: Predator guys...Intake manifolds [Re: Al_Alguire] #1608593
04/19/14 10:04 AM
04/19/14 10:04 AM
Jerry Kathe Offline
Jerry Kathe  Offline
Throttle stopping that much power for 10.90 ETs and looking for maximum power to also run TS is two completely different spectrum's on plenum to runner ratio.
Don’t expect it to stop consistently with a plenum large enough to produce maximum HP - and in contrast, it will never produce max HP with a plenum small enough to stay consistently crisp when coming off the stop.
It hard to say with just looking at a photo…..but that intake, as pretty as it is, doesn't look like what you would want for stop racing. – FWIW…..
