Firecore and Top Fuel #1608066
04/16/14 01:01 PM
04/16/14 01:01 PM
KYbywayof WV
Frito Offline OP
Frito  Offline OP
KYbywayof WV
Last week I noticed a nice set of wires on Spencer Massey's Don Schumacher owned Top Fuel Hemi. When I ask about them Spencer proudly took me into his pit and showed me the FIRECORES!!!!
Re: Firecore and Top Fuel [Re: Frito] #1608067
04/16/14 01:45 PM
04/16/14 01:45 PM
Finally a HUSKER again
Moparnut426 Offline
Moparnut426  Offline
Im suprised that snot nosed lil punk even knew what a plug wire was!!!!!
Re: Firecore and Top Fuel [Re: Moparnut426] #1608068
04/16/14 02:26 PM
04/16/14 02:26 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
Gene Snow probably showed him.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Firecore and Top Fuel [Re: pittsburghracer] #1608069
04/16/14 02:49 PM
04/16/14 02:49 PM
ohio
all spooled up Offline
ohio
Re: Firecore and Top Fuel [Re: all spooled up] #1608070
04/16/14 02:56 PM
04/16/14 02:56 PM
KYbywayof WV
Frito Offline OP
Frito  Offline OP
KYbywayof WV
I guess I should get a shot of Beckman or Antron's car. Or maybe Matt Smith or Cruz. The point of the post was to show the Firecores work on street cars, to Carey Bales 4 banger turbo to a Top Fuel Hemi.
Re: Firecore and Top Fuel [Re: Frito] #1608071
04/16/14 03:16 PM
04/16/14 03:16 PM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
not to steal the thread, but whats the ohms/ft on the firecore wire?
Re: Firecore and Top Fuel [Re: mopar dave] #1608072
04/16/14 03:50 PM
04/16/14 03:50 PM
dogdays Offline
dogdays  Offline
Ohms per foot is a meaningless number. It is measured by a small DC voltage when you use an ohmmeter.
Ohms per foot is used by plug wire manufacturers to try to get you to believe that their wire is better than someone else's.
The power for the spark event is more like AC and it flows over the surface of the core, kind of a cylinder flow.
It would take pretty specialized equipment to measure the power flow in a real spark situation.
Year ago, Circle Track magazine did a plug wire test and the results for new carbon conductor wires (the stock ones most of us consider crap) were indistinguishable from any of the other wires. I seem to remember that all the hp numbers were within the testing error, including solid conductor wires.
Wires add value when they:
1. Last a long time
2. Withstand reasonable handling and operating abuse
3. Control RFI so your other electronics aren't affected.
R.
Re: Firecore and Top Fuel [Re: mopar dave] #1608073
04/16/14 03:52 PM
04/16/14 03:52 PM
I don't think that the ohms per foot relate to any of the new Hi Po resitor type wires that have a stainless wire wound around the outside of the inner cores I fought a set of Moroso that ohmed well, but ran like crap on the motor I had used a different set of wires on the motor when I dynoed it and switch to the Moroso wires that I had used on the street car before, no worky so good on the new motor with the MSD 7AL2 box
Re: Firecore and Top Fuel [Re: dogdays] #1608074
04/16/14 04:56 PM
04/16/14 04:56 PM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
1. Last a long time
R.
Good points and they are why the fuel teems use them with Hundreds of runs on a set of wire with 44Mag with no problems on top dragsters and I believe over 100 runs on a top fuel car using Firecore50.Schumacher tested the wire in his own facility as has been seen on youtube including in a pressure chamber.
Re: Firecore and Top Fuel [Re: dogdays] #1608075
04/16/14 06:15 PM
04/16/14 06:15 PM
Oologah, Oklahoma
Big Squeeze Offline
Big Squeeze  Offline
Oologah, Oklahoma
1. Last a long time
R.
Exactly right....everything else is just salesman voodoo...
If you can't handle the truth, you're living a lie.......
Re: Firecore and Top Fuel [Re: Clanton] #1608076
04/16/14 07:00 PM
04/16/14 07:00 PM
Moparnut426 Offline
Moparnut426  Offline
The last time i went to a NHRA race was in 11, and all the DSR cars from top fuel to funny cars had fire cores on them...
Re: Firecore and Top Fuel [Re: Big Squeeze] #1608077
04/16/14 08:00 PM
04/16/14 08:00 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
1. Last a long time
R.
Well that may be true but fuel teams can use MSD wires for FREE while they pay hundreds for a set of Firecore50 wires.
Now I will admit Rick is a pretty good salesman but if his wires weren't head and shoulders above the rest they wouldn't be on the car
Gus
64 Plymouth Savoy
Dana 60
Re: Firecore and Top Fuel [Re: Moparnut426] #1608078
04/16/14 09:00 PM
04/16/14 09:00 PM
okla.
sam64 Offline
sam64  Offline
okla.
well little snot nose bracket races too,saw him at north star dragway in denton tx.a couple weeks ago.i guess we should ask what he thinks of you!
Re: Firecore and Top Fuel [Re: sam64] #1608079
04/16/14 09:20 PM
04/16/14 09:20 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
Not just because of this thread( but because of thread after thread getting posted shamelessly in one fashion or another " plugging" these wires.... I wish reference to products members sell would stay in the new products section after a thread or two touting them.
These wires become threads on here started by Rick( who I have noting against at all), seemingly all the time..but geez, enough is enough all ready after a couple of years of droning on and on about them.
Best so far, low 10.30’s 1/4
1.41 best 60 foot
6.56 at 104.17
Re: Firecore and Top Fuel [Re: sam64] #1608080
04/16/14 11:30 PM
04/16/14 11:30 PM
Moparnut426 Offline
Moparnut426  Offline
I honestly could give 2 S#$TS what he thinks of me, and Im sure he cares less what I think, but he is darn lucky to have a ride after the crap he pulled. At his age he should have more respect for the guys he is competing with as they are old enough to have changed his poopooed diapers.
Re: Firecore and Top Fuel [Re: Moparnut426] #1608081
04/16/14 11:45 PM
04/16/14 11:45 PM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
If you are going to accuse Rick of something say it!
Re: Firecore and Top Fuel [Re: dogdays] #1608082
04/17/14 01:16 AM
04/17/14 01:16 AM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
didn't know that. learning something from this site is one reason i'm on here everyday. the ohms/ft I was taught in tech school back in 82. out with the old and in with the new. anyway, where's the best place to buy a set?
Re: Firecore and Top Fuel [Re: Clanton] #1608083
04/17/14 03:16 AM
04/17/14 03:16 AM
Park Forest, IL
slantzilla Online content
slantzilla  Online Content
Park Forest, IL
Think he was alluding to Spenser Massey.
Re: Firecore and Top Fuel [Re: slantzilla] #1608084
04/17/14 08:57 AM
04/17/14 08:57 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Thats how I took it also.. referring to Massey
Re: Firecore and Top Fuel [Re: mopar dave] #1608085
04/17/14 10:31 AM
04/17/14 10:31 AM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
Me too, now we have no way to test them. I think I'm going with Moroso Ultra 40s this time.
