Re: Firecore and Top Fuel
[Re: pittsburghracer]
#1608069
04/16/14 02:49 PM
04/16/14 02:49 PM
Posts: 1,049 ohio
all spooled up
ohio
Im suprised that snot nosed lil punk even knew what a plug wire was!!!!!
Gene Snow probably showed him.
[Re: dogdays]
#1608074
04/16/14 04:56 PM
04/16/14 04:56 PM
Posts: 4,489 northern,Ohio,USA
Clanton
northern,Ohio,USA
Ohms per foot is a meaningless number. It is measured by a small DC voltage when you use an ohmmeter. Ohms per foot is used by plug wire manufacturers to try to get you to believe that their wire is better than someone else's.
The power for the spark event is more like AC and it flows over the surface of the core, kind of a cylinder flow.
It would take pretty specialized equipment to measure the power flow in a real spark situation.
Year ago, Circle Track magazine did a plug wire test and the results for new carbon conductor wires (the stock ones most of us consider crap) were indistinguishable from any of the other wires. I seem to remember that all the hp numbers were within the testing error, including solid conductor wires.
Wires add value when they: 1. Last a long time 2. Withstand reasonable handling and operating abuse 3. Control RFI so your other electronics aren't affected.
R.
Good points and they are why the fuel teems use them with Hundreds of runs on a set of wire with 44Mag with no problems on top dragsters and I believe over 100 runs on a top fuel car using Firecore50.Schumacher tested the wire in his own facility as has been seen on youtube including in a pressure chamber.
[Re: Moparnut426]
#1608078
04/16/14 09:00 PM
04/16/14 09:00 PM
Posts: 1,285 okla.
sam64
okla.
well little snot nose bracket races too,saw him at north star dragway in denton tx.a couple weeks ago.i guess we should ask what he thinks of you!
[Re: sam64]
#1608079
04/16/14 09:20 PM
04/16/14 09:20 PM
Posts: 11,726 Portage,michigan
B3422W5
Portage,michigan
Not just because of this thread( but because of thread after thread getting posted shamelessly in one fashion or another " plugging" these wires.... I wish reference to products members sell would stay in the new products section after a thread or two touting them. These wires become threads on here started by Rick( who I have noting against at all), seemingly all the time..but geez, enough is enough all ready after a couple of years of droning on and on about them.
[Re: sam64]
#1608080
04/16/14 11:30 PM
04/16/14 11:30 PM
Posts: 12,013 Finally a HUSKER again
Moparnut426
I honestly could give 2 S#$TS what he thinks of me, and Im sure he cares less what I think, but he is darn lucky to have a ride after the crap he pulled. At his age he should have more respect for the guys he is competing with as they are old enough to have changed his poopooed diapers.
[Re: Moparnut426]
#1608081
04/16/14 11:45 PM
04/16/14 11:45 PM
Clanton
northern,Ohio,USA
If you are going to accuse Rick of something say it!
[Re: slantzilla]
#1608084
04/17/14 08:57 AM
04/17/14 08:57 AM
Posts: 52,972 Romeo MI
MR_P_BODY
Think he was alluding to Spenser Massey.
Thats how I took it also.. referring to Massey
[Re: mopar dave]
#1608085
04/17/14 10:31 AM
04/17/14 10:31 AM
Posts: 11,686 W. Kentucky
justinp61
W. Kentucky
didn't know that. learning something from this site is one reason i'm on here everyday. the ohms/ft I was taught in tech school back in 82. out with the old and in with the new. anyway, where's the best place to buy a set?
Me too, now we have no way to test them. I think I'm going with Moroso Ultra 40s this time.
