** Feeler ** RECALL WHEELS - Any Serious Interest #1607922
04/15/14 07:23 PM
04/15/14 07:23 PM
Phoenix, AZ
MCTPhoenix Offline OP
Phoenix, AZ
This is an offshoot of my "Sandcasting" thread. Back when the repro "warrior" wheels were available I wanted a set but thought I'd just buy them when my project was ready. (I had more important things that needed purchasing at that time) When I was ready to buy there were no more available anywhere as the company producing them had been sold and the tooling went awol. I picked up several 15 inch Recall wheels a few weeks ago and am willing to dismantle any or all of the three to obtain suitable parts for sandcasting. I'd like to make 15x7 wheels with black powdercoated hoops which will accept readily available trim rings. I've got a quote from a wheel shop which can machine raw castings to final size, machine for steel inserts in the lug nut area (so standard conical lug nuts can be used)and assemble them into the steel hoops by a swage process in which the hoops are heated to expand, the center casting is frozen to contract and then the parts are pressed together to cool and then riveted. The quote I don't have yet is to sandcast the centers. I have a very rough idea using some online calculator which I'm not even sure I'm using correctly. Producing somewhere between 100-300 parts (25-75 sets of four wheels) doesn't drastically change the overall cost of the project from what I can tell. My guess is that a minimum of 25 sets of 4 wheels would need to be made at around $2500-$3000 per set would need to happen. My guess is that maybe 1 of 10 people who say they want will actually follow through with the purchase. I don't do this for a living so I'm open to assistance, thoughts, who is "seriously" interested etc. Please discuss.
Re: ** Feeler ** RECALL WHEELS - Any Serious Interest [Re: MCTPhoenix] #1607923
04/15/14 07:48 PM
04/15/14 07:48 PM
JERSEY
RJS Offline
RJS  Offline
JERSEY
When Specialty first came out with these wheels they made 15x7 which is an aftermarket size. I complained and a year later they made 15x6 at an additional $500 per set. 15x7 was $1800 and 15x6 was $2300.
Aren't the ones with the chrome lip still sold?
Ron
Re: ** Feeler ** RECALL WHEELS - Any Serious Interest [Re: MCTPhoenix] #1607924
04/15/14 08:16 PM
04/15/14 08:16 PM
Garden Grove, CA
OzHemi Offline
Penguin-hating Ginger
OzHemi  Offline
Garden Grove, CA
I know it is not correct...but if you went with a normal style 2 piece aluminum wheel construction...using aluminum outers, you would be able to get the price down I would say.
Then it is only a matter of making a mold for the outer, and welding them in aluminum outers.
I know the aluminum outer is quite a bit more than a steel outer, but you will save in the steps needed to make the centers at least. You'd just have the $6k or so for the molds for the centers, then the $130 a piece or so after that to crank them out.
I'd have to look up the price for 15" aluminum outers but from memory a 15 x 7 polished outers is around $81
Versus a chrome steel 15 x 7 outers at around $47 or so..(raw are cheaper obviously)..give or take, don't have my pricing info right in front of me.
Re: ** Feeler ** RECALL WHEELS - Any Serious Interest [Re: RJS] #1607925
04/15/14 08:43 PM
04/15/14 08:43 PM
Phoenix, AZ
Phoenix, AZ
Ron
No, long gone
Re: ** Feeler ** RECALL WHEELS - Any Serious Interest [Re: OzHemi] #1607926
04/15/14 08:46 PM
04/15/14 08:46 PM
Phoenix, AZ
Phoenix, AZ
There are so many aftermarket wheels available.. my thoughts are if I'm going to all this trouble, I'd like them more authentic looking, steel with trim rings. I didn't really care for the chrome repops. I'll take any referrals for a local casting company if you have.
Re: ** Feeler ** RECALL WHEELS - Any Serious Interest [Re: MCTPhoenix] #1607927
04/15/14 09:01 PM
04/15/14 09:01 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
IMHO if your going to repro them, do it correctly, you know the market will be VERY small for them, and an "Anal" market crowd at that, in regards to the correctness factor, otherwise they will shun it as an inadequate repro
Specialty Wheels had a steel insert hidden inside the casting where the lug pattern was, to prevent the wheel from exhibiting any cracking around the lug/hub area when torqued down, something you may want to consider when casting your centers
Re: ** Feeler ** RECALL WHEELS - Any Serious Interest [Re: DAYCLONA] #1607928
04/15/14 09:24 PM
04/15/14 09:24 PM
JERSEY
RJS Offline
RJS  Offline
JERSEY
I agree with Mike on this, remember I walked away from them when Specialty first came out with them exactly for that reason.
Also just a heads up, there was a heavy bead of silicone spread in the wheels where the cast center was welded to the steel rings due to leaking.
Ron
Re: ** Feeler ** RECALL WHEELS - Any Serious Interest [Re: RJS] #1607929
04/15/14 10:28 PM
04/15/14 10:28 PM
Dreaming of the 808
AZ_A12_BEE Offline
AZ_A12_BEE  Offline
Dreaming of the 808
Ron
That silicone bead is not uncommon, I see it with lots of aftermarket wheels
69.5 A12 Bee, first purchased in 1976, car 169 on registry 69 Coronet R/T 440/4 spd 69 Coronet 500 Conv H code 383 4bbl/auto 37 Plymouth PU Find your spot on earth and ride it.
Re: ** Feeler ** RECALL WHEELS - Any Serious Interest [Re: MCTPhoenix] #1607930
04/16/14 02:26 AM
04/16/14 02:26 AM
A Red State
SNK-EYZ Offline
SNK-EYZ  Offline
A Red State
As I said in your other thread I have a buddy that wants a set.
He doesn't really use the internet or computers for that matter.
The car he's wanting them for is real J code, Q5 Turquoise, Hemi 4 speed 69 Coronet R/T convertible.
I can pm you his contact info if you think this is going to happen.
Re: ** Feeler ** RECALL WHEELS - Any Serious Interest [Re: MCTPhoenix] #1607931
04/16/14 02:57 AM
04/16/14 02:57 AM
Garden Grove, CA
OzHemi Offline
OzHemi  Offline
Garden Grove, CA
No problem, just was thinking aloud with the change in design idea.
Re: ** Feeler ** RECALL WHEELS - Any Serious Interest [Re: SNK-EYZ] #1607932
04/16/14 02:43 PM
04/16/14 02:43 PM
Phoenix, AZ
Phoenix, AZ
Please do. The point of this thread is to see who's interested and under what conditions. IE; If 15x7's with commonly available trim rings are acceptable or only if the wheels are 15x6 as original etc. Thanks
Re: ** Feeler ** RECALL WHEELS - Any Serious Interest [Re: MCTPhoenix] #1607933
04/16/14 04:08 PM
04/16/14 04:08 PM
Ontario, Canada
Stanton Online content
Don't question me!
Stanton  Online Content
Don't question me!
Ontario, Canada
Not exactly a stampede of interested parties, huh!
I suspect the lack of interest is based on two things. 1) someone who isn't an expert in the field heading up the project and 2) committing to an unknown end result.
You'd probably do better if you pursued a "group buy" and contacted the original reproducer to make another limited run. Or even contact those guys first to see what they'd need as a commitment to do a re-run.
Re: ** Feeler ** RECALL WHEELS - Any Serious Interest [Re: MCTPhoenix] #1607934
04/16/14 04:49 PM
04/16/14 04:49 PM
A Red State
SNK-EYZ Offline
SNK-EYZ  Offline
A Red State
Sent you a pm with his info.
Re: ** Feeler ** RECALL WHEELS - Any Serious Interest [Re: SNK-EYZ] #1607935
04/16/14 06:22 PM
04/16/14 06:22 PM
Round Lake Beach, Illinoisy
Rhinodart Online penguin-006
Rhinotruck
Rhinodart  Online Penguin-006
Rhinotruck
No interest here unless they were small bolt pattern.
JB Rhinehart, Realist
A-Body's RULE!
Re: ** Feeler ** RECALL WHEELS - Any Serious Interest [Re: Rhinodart] #1607936
04/16/14 06:36 PM
04/16/14 06:36 PM
Phoenix, AZ
Phoenix, AZ
Since all the centers get machined for bolt pattern anyway I don't see that as a problem. You would have to be ok with 15's and not 14's of course
Re: ** Feeler ** RECALL WHEELS - Any Serious Interest [Re: MCTPhoenix] #1607937
04/17/14 10:11 AM
04/17/14 10:11 AM
Greer, SC
TooMany62s Offline
TooMany62s  Offline
Greer, SC
As a former aluminum foundry owner I can tell you these guys could make the tooling and castings for you:
http://www.andersonglobal.com/
However, unless you have LOTS of buyers I doubt that it would be financially feasible.
Re: ** Feeler ** RECALL WHEELS - Any Serious Interest [Re: Rhinodart] #1607938
04/17/14 02:49 PM
04/17/14 02:49 PM
NO RUST IN AZ!!!
azmopar Offline
azmopar  Offline
NO RUST IN AZ!!!
Id be in a for a set of small pattern ones too
70 Challenger Convertible 340 six pak CLONE?
70 Duster real FM3 car
65 Dart Charger FOR SALE
#NONIKESEVER
A Real man aint afraid to drive PINK!!!!
67 Plymouth Valiant PILOT CAR 273 Commando 4 spd
Re: ** Feeler ** RECALL WHEELS - Any Serious Interest [Re: TooMany62s] #1607939
04/17/14 04:24 PM
04/17/14 04:24 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
And Rick,just about anytime an item that is no longer available is mentioned as a possibility you know as well as I do in most cases everyone will say I'm in but in the end most are out.
Re: ** Feeler ** RECALL WHEELS - Any Serious Interest [Re: 62maxwgn] #1607940
04/17/14 06:44 PM
04/17/14 06:44 PM
Ontario, Canada
Don't question me!
Don't question me!
Ontario, Canada
A number of years ago I sent out feelers regarding importing a product into Canada and I had a lot of "interest". But what I found out is this:
"I'd buy that" REALLY means
a) if I had any money
b) if I had a (insert item here) to use it on
or
c) (and MOST importantly) if my wife will let me
