valve springs #1607517
04/14/14 07:05 PM
04/14/14 07:05 PM
libby mt
lifted85 Offline OP
lifted85  Offline OP
libby mt
ok guy's i will be running a comp XE256H in my 74 318 motor, now summit say's comp cam's recommend Valve Springs 926-16, cant i run the comp 901's & still be safe??
drive fast, drive hard, DRIVE MOPAR
Re: valve springs [Re: lifted85] #1607518
04/14/14 09:43 PM
04/14/14 09:43 PM
do either Comp or Summitt have published open/closed specs for both of those springs?
Re: valve springs [Re: RapidRobert] #1607519
04/14/14 10:06 PM
04/14/14 10:06 PM
WI
Dcuda69 Offline
Dcuda69  Offline
WI
That's what you'll need as well as installed height and coil bind specs.
Re: valve springs [Re: Dcuda69] #1607520
04/15/14 01:52 AM
04/15/14 01:52 AM
dogdays Offline
dogdays  Offline
It's so easy to look up.
The 926 installed at 1.8" has 109 seat pressure and spring rate of 415 lb per inch. So if your 318 is like mine it has installed height of 1.6" so seat pressure would be 192 lb. sounds too much to me, but what do I know?
The 901 has 101 at 1.6 IH and spring rate 353 lb per inch. I believe board members have used that spring on similar cams successfully.
R.
Re: valve springs [Re: dogdays] #1607521
04/15/14 03:40 AM
04/15/14 03:40 AM
libby mt
lifted85 Offline OP
lifted85  Offline OP
libby mt
i know hence i did look it up, my question was can i run the 901's safely..
Re: valve springs [Re: lifted85] #1607522
04/15/14 09:02 AM
04/15/14 09:02 AM
n.e. pa.
65rbdodge Offline
65rbdodge  Offline
n.e. pa.
run the 901's
that's what I had on the 302 heads I was using on the 318 I had the 256 cam in, that what comp says to use-
http://www.compcams.com/Company/CC/cam-specs/Details.aspx?csid=625&sb=0
Re: valve springs [Re: 65rbdodge] #1607523
04/15/14 02:27 PM
04/15/14 02:27 PM
Mi,U.S.A.
mike s Offline
mike s  Offline
Mi,U.S.A.
Try a set of edelbrock springs from their rpm heads. Perfect for that small cam and very inexpensive.
Leave the gun.......take the Cannoli's....Mike
