valve springs
#1607517
04/14/14 07:05 PM
04/14/14 07:05 PM
Posts: 256 libby mt
lifted85
libby mt
ok guy's i will be running a comp XE256H in my 74 318 motor, now summit say's comp cam's recommend Valve Springs 926-16, cant i run the comp 901's & still be safe??
drive fast, drive hard, DRIVE MOPAR
Re: valve springs
[Re: lifted85]
#1607518
04/14/14 09:43 PM
04/14/14 09:43 PM
RapidRobert
do either Comp or Summitt have published open/closed specs for both of those springs?
Re: valve springs
[Re: RapidRobert]
#1607519
04/14/14 10:06 PM
04/14/14 10:06 PM
Posts: 4,946 WI
Dcuda69
WI
That's what you'll need as well as installed height and coil bind specs.
Re: valve springs
[Re: dogdays]
#1607521
04/15/14 03:40 AM
04/15/14 03:40 AM
Posts: 256 libby mt
lifted85
libby mt
i know hence i did look it up, my question was can i run the 901's safely..
Re: valve springs
[Re: 65rbdodge]
#1607523
04/15/14 02:27 PM
04/15/14 02:27 PM
Posts: 1,668 Mi,U.S.A.
mike s
Mi,U.S.A.
Try a set of edelbrock springs from their rpm heads. Perfect for that small cam and very inexpensive.
Leave the gun.......take the Cannoli's....Mike
