Viper oil pressure too high
#1607188
04/14/14 09:17 AM
04/14/14 09:17 AM
Posts: 2,652 Stuttgart, Arkansas
rickseeman
Stuttgart, Arkansas
Is there a way to adjust the oil pressure like on a big block? It has 85-90 psi idling cold. I think they call this one a 4th generation Viper engine. Thanks.
2011 Drag Pak Challenger
Re: Viper oil pressure too high
[Re: rickseeman]
#1607189
04/14/14 09:27 AM
04/14/14 09:27 AM
Posts: 10,007 Frostbitefalls MN (Rocky&Bullw...
gregsdart
There has to be a bypass spring, but I bet the pump is inside the oil pan. How much pressure does it show? Does the pressure consistently level off at a certain point? If it keeps building pressure and goes way over the factory settings, or worse yet, fluctuates, you have to take a look inside. If it is stock parts, then you better get that pump out of it and go new. Check for any metal debris while there, and cut open the oil filter to see what gives. Bypasses don't stick on a whim, something is up.
[Re: rickseeman]
#1607191
04/14/14 04:52 PM
04/14/14 04:52 PM
Posts: 25,821 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Be sure it's not a faulty sender.
[Re: John_Kunkel]
#1607192
04/14/14 07:42 PM
04/14/14 07:42 PM
Posts: 10,137 A Red State
SNK-EYZ
A Red State
What weight oil is in the engine?
[Re: rickseeman]
#1607196
04/15/14 02:35 PM
04/15/14 02:35 PM
Posts: 1,668 Mi,U.S.A.
mike s
Mi,U.S.A.
Bypass should be in the front cover (lower left side).Sounds like piston is sticking.IIRC there is a large hex plug you need to remove to access the piston and spring.
Leave the gun.......take the Cannoli's....Mike
[Re: rickseeman]
#1607198
04/16/14 11:59 PM
04/16/14 11:59 PM
rickseeman
Stuttgart, Arkansas
Found it. Finally got it out. But it doesn't look user serviceable. It appears to be all made together. I can push the spring in (hard). Is one available with less pressure?
[Re: rickseeman]
#1607199
04/17/14 12:14 AM
04/17/14 12:14 AM
Posts: 52,972 Romeo MI
MR_P_BODY
You could contact Arrow Engine in Auburn Hills, Mi.. they do all the major style engine repairs on Viper engines for the dealers http://www.arrowracingengines.com/aboutus.html
[Re: rickseeman]
#1607200
04/17/14 04:08 AM
04/17/14 04:08 AM
mike s
Mi,U.S.A.
Spring is not the problem.Replace the piston and spring.Deburr edges w/1000 grit paper.
