Viper oil pressure too high #1607188
04/14/14 09:17 AM
04/14/14 09:17 AM
Stuttgart, Arkansas
rickseeman Offline OP
Stuttgart, Arkansas
Is there a way to adjust the oil pressure like on a big block? It has 85-90 psi idling cold. I think they call this one a 4th generation Viper engine. Thanks.
2011 Drag Pak Challenger
Re: Viper oil pressure too high [Re: rickseeman] #1607189
04/14/14 09:27 AM
04/14/14 09:27 AM
gregsdart Online content
gregsdart  Online Content
There has to be a bypass spring, but I bet the pump is inside the oil pan. How much pressure does it show? Does the pressure consistently level off at a certain point? If it keeps building pressure and goes way over the factory settings, or worse yet, fluctuates, you have to take a look inside.
If it is stock parts, then you better get that pump out of it and go new. Check for any metal debris while there, and cut open the oil filter to see what gives. Bypasses don't stick on a whim, something is up.
Re: Viper oil pressure too high [Re: gregsdart] #1607190
04/14/14 11:48 AM
04/14/14 11:48 AM
Stuttgart, Arkansas
Stuttgart, Arkansas
The pump is behind the harmonic balancer but I'm hoping there is an external adjustment.
Re: Viper oil pressure too high [Re: rickseeman] #1607191
04/14/14 04:52 PM
04/14/14 04:52 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Be sure it's not a faulty sender.
Re: Viper oil pressure too high [Re: John_Kunkel] #1607192
04/14/14 07:42 PM
04/14/14 07:42 PM
A Red State
SNK-EYZ Offline
SNK-EYZ  Offline
A Red State
What weight oil is in the engine?
Re: Viper oil pressure too high [Re: SNK-EYZ] #1607193
04/15/14 12:58 AM
04/15/14 12:58 AM
Stuttgart, Arkansas
Stuttgart, Arkansas
It's a light synthetic. Mobil 1 0-20 or 10-30.
Re: Viper oil pressure too high [Re: John_Kunkel] #1607194
04/15/14 01:26 AM
04/15/14 01:26 AM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
Re: Viper oil pressure too high [Re: Sport440] #1607195
04/15/14 12:23 PM
04/15/14 12:23 PM
Stuttgart, Arkansas
Stuttgart, Arkansas
I think the gauge is right. It blew out the o-ring on the oil filter.
Re: Viper oil pressure too high [Re: rickseeman] #1607196
04/15/14 02:35 PM
04/15/14 02:35 PM
Mi,U.S.A.
mike s Offline
mike s  Offline
Mi,U.S.A.
Bypass should be in the front cover (lower left side).Sounds like piston is sticking.IIRC there is a large hex plug you need to remove to access the piston and spring.
Leave the gun.......take the Cannoli's....Mike
Re: Viper oil pressure too high [Re: mike s] #1607197
04/16/14 12:24 AM
04/16/14 12:24 AM
Stuttgart, Arkansas
Stuttgart, Arkansas
Thanks, I will go look.
Re: Viper oil pressure too high [Re: rickseeman] #1607198
04/16/14 11:59 PM
04/16/14 11:59 PM
Stuttgart, Arkansas
Stuttgart, Arkansas
Found it. Finally got it out. But it doesn't look user serviceable. It appears to be all made together. I can push the spring in (hard). Is one available with less pressure?
Re: Viper oil pressure too high [Re: rickseeman] #1607199
04/17/14 12:14 AM
04/17/14 12:14 AM
MR_P_BODY Offline
MR_P_BODY  Offline
You could contact Arrow Engine in Auburn Hills, Mi..
they do all the major style engine repairs on Viper
engines for the dealers
http://www.arrowracingengines.com/aboutus.html
Re: Viper oil pressure too high [Re: rickseeman] #1607200
04/17/14 04:08 AM
04/17/14 04:08 AM
Mi,U.S.A.
mike s Offline
mike s  Offline
Mi,U.S.A.
Spring is not the problem.Replace the piston and spring.Deburr edges w/1000 grit paper.
Re: Viper oil pressure too high [Re: mike s] #1607201
04/17/14 10:07 PM
04/17/14 10:07 PM
Oklahoma City OK
Cudajon Offline
Cudajon  Offline
Oklahoma City OK
Got 65k on my 2004 SRT 10. It idled at 90lbs up to 60k or so. Still idles at 100 when cold. 5w-30w Mobil one. All I ever used. When hot it now idles at 60lbs. Did have to go to braided stainless lines to the cooler. The mopar lines didnt last 25k. Go to VTCOA and check out their forums. All the engines run high oil pressure.
