Broken Speedo Needle #1606723
04/13/14 11:26 AM
04/13/14 11:26 AM
Maine
1965Monaco Offline OP
Maine
Anyone know where I can buy a replacement needle for my '78 D150 Club Cab? Not exactly sure what happened, but the speedo freaked out and pinned, and broke the needle in half.
Odometer and needle still work now, but it only drops to 10mph at stop, and reads about 10 high when driving.
I have a A518 trans.
thanks for any help!
Re: Broken Speedo Needle [Re: 1965Monaco] #1606724
04/13/14 12:58 PM
04/13/14 12:58 PM
N
NITROUSN Offline
NITROUSN  Offline
N
You need to replace the speedometer head.
Re: Broken Speedo Needle [Re: NITROUSN] #1606725
04/14/14 12:12 AM
04/14/14 12:12 AM
Amarillo, Tx
old_goat Offline
Six Abuser
old_goat  Offline
Six Abuser
Amarillo, Tx
84 D150 440/727
79 /6 swb D150
1964 A100 window van. Just because it has spark plug tubes doesn't mean it's a Hemi.
If ya haven't been there, ya just wouldn't understand.
Re: Broken Speedo Needle [Re: old_goat] #1606726
04/14/14 09:01 AM
04/14/14 09:01 AM
Maine
Maine
Do you know if the needle will pull straight off the head, or is there anything special I need to do to get it off?
I'm thinking I'll just find a head that has a good needle and take it off for mine.
Re: Broken Speedo Needle [Re: 1965Monaco] #1606727
04/14/14 11:03 AM
04/14/14 11:03 AM
Sunny South Florida
Golden-Arm Offline
Golden-Arm  Offline
Sunny South Florida
i've had several break myself. a tiny dot of superglue will put it back together.
Re: Broken Speedo Needle [Re: 1965Monaco] #1606728
04/15/14 01:21 PM
04/15/14 01:21 PM
Rockford, IL.
Ruppman Offline
Ruppman  Offline
Rockford, IL.
Thats what i was thinking. Just pop a different needle on. My 1980 has the same problem.
Re: Broken Speedo Needle [Re: 1965Monaco] #1606729
04/15/14 07:52 PM
04/15/14 07:52 PM
Southwest
way2fast Offline
way2fast  Offline
Southwest
Stevie, pm ejtmopar on here he's probably got a bucket of speedometers. (Guy I bought the CC from).
Go Fast and Swerve!
Re: Broken Speedo Needle [Re: 1965Monaco] #1606730
04/15/14 09:56 PM
04/15/14 09:56 PM
central Florida
VL21 Offline
VL21  Offline
central Florida
If the speedo went whacko and wrapped around breaking the needle, and now reads fast and doesn't drop all the way, I am thinking the magnet/spring (drum?) thing in the speedo gut has broken ... and you need another speedo.
I have had that happen.
Unless accuracy is not your goal, and if so, why worry about the needle?
Yes, I believe the needle will pull off ...start with the broken one, you've got nothing to lose.
It takes gasoline to interest me.
Re: Broken Speedo Needle [Re: VL21] #1606731
04/15/14 11:00 PM
04/15/14 11:00 PM
Rockford, IL.
Ruppman Offline
Ruppman  Offline
Rockford, IL.
mine works ok. just for some reason 1/2 the needle broke off
Re: Broken Speedo Needle [Re: Ruppman] #1606732
04/16/14 01:03 AM
04/16/14 01:03 AM
SW Missouri
moparmandjh Offline
moparmandjh  Offline
SW Missouri
Does that mean you are going half fast?????
American soldiers in battle don't fight for what some president says on tv, they don't fight for mom, apple pie, or the American flag... they fight for one another. -Lt. General Hal Moore
Re: Broken Speedo Needle [Re: moparmandjh] #1606733
04/18/14 02:02 AM
04/18/14 02:02 AM
Rockford, IL.
Ruppman Offline
Ruppman  Offline
Rockford, IL.
yep, half-assed!
