Re: Broken Speedo Needle
[Re: 1965Monaco]
#1606728
04/15/14 01:21 PM
04/15/14 01:21 PM
Posts: 1,573 Rockford, IL.
Ruppman
Rockford, IL.
Do you know if the needle will pull straight off the head, or is there anything special I need to do to get it off? I'm thinking I'll just find a head that has a good needle and take it off for mine.
Thats what i was thinking. Just pop a different needle on. My 1980 has the same problem.
[Re: 1965Monaco]
#1606730
04/15/14 09:56 PM
04/15/14 09:56 PM
Posts: 1,357 central Florida
VL21
central Florida
If the speedo went whacko and wrapped around breaking the needle, and now reads fast and doesn't drop all the way, I am thinking the magnet/spring (drum?) thing in the speedo gut has broken ... and you need another speedo. I have had that happen. Unless accuracy is not your goal, and if so, why worry about the needle? Yes, I believe the needle will pull off ...start with the broken one, you've got nothing to lose.
It takes gasoline to interest me.
[Re: moparmandjh]
#1606733
04/18/14 02:02 AM
04/18/14 02:02 AM
Ruppman
Rockford, IL.
mine works ok. just for some reason 1/2 the needle broke off
Does that mean you are going half fast?????
yep, half-assed!
