what size does this cam sound? #1603724
04/06/14 12:14 AM
04/06/14 12:14 AM
Rancho Cordova, CA
Exit1965 Offline OP
Exit1965  Offline OP
Rancho Cordova, CA
Not my car, just found this video and thought the car sounded great. Anyone guess what specs cam would sound like that?
https://www.youtube.com/watch?v=6dZPRVPWiaM
Re: what size does this cam sound? [Re: Exit1965] #1603725
04/06/14 12:48 AM
04/06/14 12:48 AM
Cleveland
sunroofgtx Offline
sunroofgtx  Offline
Cleveland
3/4
Join the quickest team in motorsports. Team FireCore. CustomWiresets.com
Re: what size does this cam sound? [Re: sunroofgtx] #1603726
04/06/14 12:52 AM
04/06/14 12:52 AM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
I couldnt play the vid myself, but from the explanation,
Re: what size does this cam sound? [Re: Sport440] #1603727
04/06/14 01:27 AM
04/06/14 01:27 AM
St. Paul , Mn.
tubtar Offline
tubtar  Offline
St. Paul , Mn.
You'd better ask Donnie.
I'm gonna say 7/8ths.
Re: what size does this cam sound? [Re: tubtar] #1603728
04/06/14 02:30 AM
04/06/14 02:30 AM
junction city oregon
V
viperblue72 Offline
viperblue72  Offline
V
Too many variables to know. Could be a 292 hydraulic. Could be a Thumper cam, could be a decent size solid roller. Could be a 312 590.
It's anybody's guess.
Re: what size does this cam sound? [Re: Exit1965] #1603729
04/06/14 02:59 AM
04/06/14 02:59 AM
New York
polyspheric Offline
polyspheric  Offline
New York
Without a lot more detail on the car, you don't know anything. This includes:
1. how big? a 273 will do that with a 240° cam, a 572 idles like a milk truck with a 260°.
2. how high was that idle? 600 RPM means no cam to speak of, 2,000 RPM means the wrong cam.
3. what converter?
Just my 2¢?
What I heard was a bad idle and a loud exhaust. IME, a big cam does not have an irregular idle, but goes through identical up-&-down cycles of engine speed that take up to 1 second even at 1,200 RPM.
I'll give you another test: very early exhaust opening + high compression makes the exhaust REALLY loud at idle.
Boffin Emeritus
Re: what size does this cam sound? [Re: Sport440] #1603730
04/06/14 05:41 AM
04/06/14 05:41 AM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
Just so everybody knows, Im just kidding around here.
But I am from the era of the 3/4 cams But hey now, where did the 7/8,s cams come into play.
I remember cruising McDonalds in the late 70,s, never heard of the 7/8,scams.
Those were some fun days, I miss them.
Re: what size does this cam sound? [Re: Sport440] #1603731
04/06/14 11:59 AM
04/06/14 11:59 AM
St. Paul , Mn.
tubtar Offline
tubtar  Offline
St. Paul , Mn.
Bigger is always better.
Re: what size does this cam sound? [Re: Exit1965] #1603732
04/06/14 04:51 PM
04/06/14 04:51 PM
San Diego
formula S Offline
formula S  Offline
San Diego
maybe 255 to 265 @.050 and 108 to 110 lc
Re: what size does this cam sound? [Re: sunroofgtx] #1603733
04/06/14 05:05 PM
04/06/14 05:05 PM
Nebraska
451Cuda Offline
451Cuda  Offline
Nebraska
Sounds more streetable than that...I'd guess it's a 11/16 cam.
Re: what size does this cam sound? [Re: 451Cuda] #1603734
04/07/14 01:12 PM
04/07/14 01:12 PM
CT
GTX MATT Online content
GTX MATT  Online Content
CT
I'll play, 9:1 383, 906 heads with blended bowls, 484 Purpleshaft installed straight up, 10 degrees of initial, stock distributor, 28 degrees total timing, OLD 750 double pumper that needs a rebuild, Hedman headers, 2.5 inch exhaust, original Torker intake, 2500 stall off the shelf converter.
