Re: what size does this cam sound?
[Re: sunroofgtx]
#1603726
04/06/14 12:52 AM
04/06/14 12:52 AM
Posts: 6,591 Canton, Ohio
Sport440
Canton, Ohio
I couldnt play the vid myself, but from the explanation,
[Re: Exit1965]
#1603729
04/06/14 02:59 AM
04/06/14 02:59 AM
Posts: 4,209 New York
polyspheric
New York
Without a lot more detail on the car, you don't know anything. This includes: 1. how big? a 273 will do that with a 240° cam, a 572 idles like a milk truck with a 260°. 2. how high was that idle? 600 RPM means no cam to speak of, 2,000 RPM means the wrong cam. 3. what converter?
Just my 2¢? What I heard was a bad idle and a loud exhaust. IME, a big cam does not have an irregular idle, but goes through identical up-&-down cycles of engine speed that take up to 1 second even at 1,200 RPM.
I'll give you another test: very early exhaust opening + high compression makes the exhaust REALLY loud at idle.
Boffin Emeritus
[Re: Sport440]
#1603730
04/06/14 05:41 AM
04/06/14 05:41 AM
Sport440
Canton, Ohio
Just so everybody knows, Im just kidding around here.
But I am from the era of the 3/4 cams But hey now, where did the 7/8,s cams come into play.
I remember cruising McDonalds in the late 70,s, never heard of the 7/8,scams.
Those were some fun days, I miss them.
[Re: Sport440]
#1603731
04/06/14 11:59 AM
04/06/14 11:59 AM
Posts: 3,082 St. Paul , Mn.
tubtar
St. Paul , Mn.
Bigger is always better.
[Re: sunroofgtx]
#1603733
04/06/14 05:05 PM
04/06/14 05:05 PM
Posts: 345 Nebraska
451Cuda
Nebraska
Sounds more streetable than that...I'd guess it's a 11/16 cam.
[Re: 451Cuda]
#1603734
04/07/14 01:12 PM
04/07/14 01:12 PM
Posts: 5,163 CT
GTX MATT
CT
I'll play, 9:1 383, 906 heads with blended bowls, 484 Purpleshaft installed straight up, 10 degrees of initial, stock distributor, 28 degrees total timing, OLD 750 double pumper that needs a rebuild, Hedman headers, 2.5 inch exhaust, original Torker intake, 2500 stall off the shelf converter.
