Hemi guys...Barton SP Intake to Indy 426-1 heads qun
#1603305
04/05/14 02:46 AM
04/05/14 02:46 AM
Posts: 623 Deep DEEP SOUTH
LAD 524
Deep DEEP SOUTH
Hey guys - quick qun. Will this intake OOTB bolt up to a the Indy 426-1 heads? Are they a bolt on deal? Im looking to run a shorter intake over an Indy 426-4 for hood clearance but after sitting this thing on the block there is a gap of 15.5mm b/w the top of the block and the bottom of the valley plate !! What gives? Any advice would be much appreciated thx !
Re: Hemi guys...Barton SP Intake to Indy 426-1 heads qun
[Re: LAD 524]
#1603309
04/05/14 11:22 AM
04/05/14 11:22 AM
Posts: 3,619 Norwich CT USA
Defbob
Norwich CT USA
In my opinion, I see three options (lowest cost first) 1: Cut the cast-in valley plate off of the Barton intake 2: Buy an Indy intake 3: Buy Stage V heads and use the Barton intake
[Re: Defbob]
#1603310
04/05/14 12:35 PM
04/05/14 12:35 PM
Posts: 3,505 DFW
mr_340
DFW
I'm thinking you should countersink the screw holes in the Indy valley plate so you can use flat head screws to hold it down and make the seal needed. If needed, mill a little off the top of the plate if it hits the intake anywhere or have a custom plate made up. I think AndyF makes a billet plate that might be thinner than the cast Indy plate. I wouldn't hack the intake. Sounds like more work than the plate and then you have an intake that only works with those heads. The plates are cheaper than the intake. http://arengineering.com/home-page/valley-plates/It doesn't look like Andy has a Hemi plate, but I'm sure he can fab one up for you. You won't need the access holes for the Hemi, so maybe you can save some money and have him make a one-piece plate.
Floyd Lippencott IV
[Re: dusturbd340W5]
#1603314
04/05/14 07:15 PM
04/05/14 07:15 PM
Posts: 9,910 Eighty Four, PA
B G Racing
Eighty Four, PA
How much is 15.5 mm? If it is 1/4 in or less just use weather stripping?
15.5mm is well over a 1/2"
Indy plate measures aprox.1/2" ,countersink the 6 holes and use capscrews and you will have a gap under the manifold.
[Re: LAD 524]
#1603317
04/08/14 10:35 AM
04/08/14 10:35 AM
Posts: 13,376 Marion, South Carolina [><]
an8sec70cuda
If it was me, I'd cut the valley plate off the Barton manifold and just use the Indy plate. That way you could switch back and forth no problem. You may have to mill the bottom of the intake flange a little. The Barton manifold would still work w/ non-Indy heads and the Indy valley plate.
