Hemi guys...Barton SP Intake to Indy 426-1 heads qun #1603305
04/05/14 02:46 AM
04/05/14 02:46 AM
Deep DEEP SOUTH
LAD 524 Offline OP
LAD 524  Offline OP
Deep DEEP SOUTH
Hey guys - quick qun.
Will this intake OOTB bolt up to a the Indy 426-1 heads? Are they a bolt on deal?
Im looking to run a shorter intake over an Indy 426-4 for hood clearance but after sitting this thing on the block there is a gap of 15.5mm b/w the top of the block and the bottom of the valley plate !! What gives?
Any advice would be much appreciated thx !
Re: Hemi guys...Barton SP Intake to Indy 426-1 heads qun [Re: LAD 524] #1603306
04/05/14 08:33 AM
04/05/14 08:33 AM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
It requires Indy valley plate or similar to seal since the Indy ports are higher.
Re: Hemi guys...Barton SP Intake to Indy 426-1 heads qun [Re: B G Racing] #1603307
04/05/14 08:44 AM
04/05/14 08:44 AM
sweden
sshemi Offline
sshemi  Offline
sweden
The big supprize here is that an american guy have figured out that the metric system is the way to go!
Re: Hemi guys...Barton SP Intake to Indy 426-1 heads qun [Re: sshemi] #1603308
04/05/14 08:57 AM
04/05/14 08:57 AM
Deep DEEP SOUTH
LAD 524 Offline OP
LAD 524  Offline OP
Deep DEEP SOUTH
Haha nice !
BG - I had the Indy valley plate on the engine with teh In 426-4 intake.
But that Barton intake has a valley plate already cast into it. I tried but he Barton intake wont mount to the engine with the Indy valley plate in place and besides, why would you do that when the Barton piece has the valley plate cast into the manifold.?
Confused .....
Re: Hemi guys...Barton SP Intake to Indy 426-1 heads qun [Re: LAD 524] #1603309
04/05/14 11:22 AM
04/05/14 11:22 AM
Norwich CT USA
Defbob Offline
Defbob  Offline
Norwich CT USA
In my opinion, I see three options (lowest cost first)
1: Cut the cast-in valley plate off of the Barton intake
2: Buy an Indy intake
3: Buy Stage V heads and use the Barton intake
Re: Hemi guys...Barton SP Intake to Indy 426-1 heads qun [Re: Defbob] #1603310
04/05/14 12:35 PM
04/05/14 12:35 PM
DFW
mr_340 Offline
mr_340  Offline
DFW
I'm thinking you should countersink the screw holes in the Indy valley plate so you can use flat head screws to hold it down and make the seal needed. If needed, mill a little off the top of the plate if it hits the intake anywhere or have a custom plate made up. I think AndyF makes a billet plate that might be thinner than the cast Indy plate. I wouldn't hack the intake. Sounds like more work than the plate and then you have an intake that only works with those heads. The plates are cheaper than the intake.
http://arengineering.com/home-page/valley-plates/
It doesn't look like Andy has a Hemi plate, but I'm sure he can fab one up for you. You won't need the access holes for the Hemi, so maybe you can save some money and have him make a one-piece plate.
Floyd Lippencott IV
Re: Hemi guys...Barton SP Intake to Indy 426-1 heads qun [Re: mr_340] #1603311
04/05/14 01:27 PM
04/05/14 01:27 PM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
The cast in place valley plate works with stock intake port height,we use the Indy or similar valley plates on any stock style intake such as X-rams and use the plate under it.You can also make spacers for the end rails,we have done this on blower manifolds and Indy raised port heads.You can tap the block rail and countersink the holes in the spacers and use capscrews to attach.Add a thin bead of silicone to the block side attach the spacer,silicone the manifold side and be good to go. There is more than one way to skin a cat but always start with a dead cat.
Re: Hemi guys...Barton SP Intake to Indy 426-1 heads qun [Re: LAD 524] #1603312
04/05/14 06:08 PM
04/05/14 06:08 PM
Mohnton, Pa
DodgeCharger Offline
Mohnton, Pa
How much is 15.5 mm? If it is 1/4 in or less just use weather stripping?
Re: Hemi guys...Barton SP Intake to Indy 426-1 heads qun [Re: DodgeCharger] #1603313
04/05/14 06:20 PM
04/05/14 06:20 PM
Kissimmee Fl.
dusturbd340W5 Offline
Kissimmee Fl.
15.5mm is well over a 1/2"
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
Re: Hemi guys...Barton SP Intake to Indy 426-1 heads qun [Re: dusturbd340W5] #1603314
04/05/14 07:15 PM
04/05/14 07:15 PM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
Indy plate measures aprox.1/2" ,countersink the 6 holes and use capscrews and you will have a gap under the manifold.
Re: Hemi guys...Barton SP Intake to Indy 426-1 heads qun [Re: mr_340] #1603315
04/05/14 11:39 PM
04/05/14 11:39 PM
AndyF Offline
AndyF  Offline
The double valley plate deal works and is the easiest way to solve the problem. I've used my valley plates that way before. The other option is to build some custom valley ends. It isn't too tough of a fab job for a local machine shop.
Re: Hemi guys...Barton SP Intake to Indy 426-1 heads qun [Re: AndyF] #1603316
04/05/14 11:57 PM
04/05/14 11:57 PM
Deep DEEP SOUTH
LAD 524 Offline OP
LAD 524  Offline OP
Deep DEEP SOUTH
Thanx for the input fellas - I thought I may go with the fabbed spacers but upon reflection, its prob better to go the route BG suggested and go the double valley late.
As I dotn want to have to remove the Indy plate to swap intakes(to do it you have to remove at least one head), if I reuse the Indy valley plate and use countersunk bolts, itll be easier for me to swap b/w the Barton intake and the Indy 426-4 intake as the Indy plate sits below both heads on the deck and cant be removed with both heads on.
Here's another pic of the gap and the Indy Valley plate. For those who want to know, the Valley plate has two diff thicknesses at its end as cast/machined. 0.44" (11mm) and 0.23" (6mm) mm as can be seen in the pic.
Thanks to all.
Re: Hemi guys...Barton SP Intake to Indy 426-1 heads qun [Re: LAD 524] #1603317
04/08/14 10:35 AM
04/08/14 10:35 AM
an8sec70cuda Offline
If it was me, I'd cut the valley plate off the Barton manifold and just use the Indy plate. That way you could switch back and forth no problem. You may have to mill the bottom of the intake flange a little.
The Barton manifold would still work w/ non-Indy heads and the Indy valley plate.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Hemi guys...Barton SP Intake to Indy 426-1 heads qun [Re: an8sec70cuda] #1603318
04/12/14 03:29 PM
04/12/14 03:29 PM
Winnipeg ,Mb. CA.
chryco Offline
chryco  Offline
Winnipeg ,Mb. CA.
Mine has the valley pan / plate removed and an aluminum sheet metal pan installed . Straight from RBRE .
Gas is fer washin' parts ....Alky`s fer drinkin' ...Nitro`s fer Racin'!
