Re: Rocker oiling on Indy 360-2 cylinder heads
[Re: cj391]
#1602911
04/03/14 11:58 PM
04/03/14 11:58 PM
Posts: 3,415 Toronto
mshred
Toronto
you'll be good. I had the same concern with my w2's, put it together and it oiled fine.
My current RHS heads could be exactly the same, but I can't remember right now to be honest as they are on the car and it is in storage
[Re: mshred]
#1602912
04/04/14 12:44 AM
04/04/14 12:44 AM
Posts: 1,267 North, Alabama
D-50
North, Alabama
I am running the 360-2 also but I am using the ARP head bolts instead of the studs. I have had no issues so far.I am also oiling through the push rods.
1.33 60 ft,6.21 at 110.59 in the 1/8, pump gas small block,2950lbs,drag radials,mufflers and driven to track ...
[Re: Scamp408]
#1602914
04/04/14 09:20 AM
04/04/14 09:20 AM
Posts: 3,978 Hilltown Pa
1967dartgt
Hilltown Pa
I just ran arp studs with no problems.
Brett Miller W9 cnc'd heads STR Chassis fabraction
[Re: Scamp408]
#1602916
04/04/14 12:30 PM
04/04/14 12:30 PM
Posts: 3,544 Syracuse,NY
CompWedgeEngines
Syracuse,NY
Have the arp stud thinned out alittle in the middle by a machine shop.Also ck the shaft stud.
Doesnt need to be ground in half, but look at the rocker studs that came with your T&D rockers, you will see how they are ground in the center. Do the same with the 2 head studs, and you should have no issues whatsoever.
RIP Monte Smith
[Re: mshred]
#1602918
04/04/14 04:37 PM
04/04/14 04:37 PM
Posts: 52,972 Romeo MI
MR_P_BODY
I am glad I asked this question and caught this before bolting the heads on! I will take a look at the rocker studs and do the same to the head studs.
Pays to look over the finer details
Measure the studs and measure the holes in the heads.. your head studs being a larger dia(1/2") might have plenty of clearance since your playing with a larger dia which is more area
