1966 coronet to 70 dodge charger suspension swap??? #1602310
04/02/14 09:11 PM
04/02/14 09:11 PM
MO
cdp Offline OP
cdp  Offline OP
MO
A buddy fully customized his 70 Charger RT and I'm buying the full front and rear suspension out of the car.
My plan is to rebuild the suspension, detail it and slide a 440/auto onto the K-frame and slide the whole thing into a 30k mile slant-6/auto 66 coronet 4door.
My question is on the rear. Will the Hemi springs and 8-3/4 rear from the 70 charger fit into the coronet OK? I was thinking the rear is a little narrower on the 66 and may cause me some wheel well clearance. I do plan on running G-Series redlines I have sitting around.
Chris
Re: 1966 coronet to 70 dodge charger suspension swap??? [Re: cdp] #1602311
04/03/14 01:22 AM
04/03/14 01:22 AM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
The 70 K member is differnt but if you use the 70 lower control arms and sway bar, it all bolts up.
Regarding the rear axle, yes it is a bit wider. I believe the difference is 3/4" total. If you intend to run stock 6" wide rims you'll be fine.
Re: 1966 coronet to 70 dodge charger suspension swap??? [Re: Kern Dog] #1602312
04/03/14 09:06 PM
04/03/14 09:06 PM
MO
cdp Offline OP
cdp  Offline OP
MO
thanks.
Yes, I have the whole K member assembly, sway bar, and upper, lower A-arms, spindles, disc brakes, etc.
Same with the rear. springs and rear, drum to drum.
Re: 1966 coronet to 70 dodge charger suspension swap??? [Re: cdp] #1602313
04/03/14 10:30 PM
04/03/14 10:30 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
I think the rear might be a tad wider, but I'm not sure. In any even that can be offset w/ some offset rims
Coming soon!!!!
Re: 1966 coronet to 70 dodge charger suspension swap??? [Re: Mr.Yuck] #1602314
04/07/14 05:16 PM
04/07/14 05:16 PM
MO
cdp Offline OP
cdp  Offline OP
MO
are the rear springs usable also?
8 3/4 has the hemi springs on it. I was thinking they will work and the same as we put on my dads old hemi gtx.
Re: 1966 coronet to 70 dodge charger suspension swap??? [Re: cdp] #1602315
04/07/14 06:58 PM
04/07/14 06:58 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
measure them. Or you could go online to Mancini and see if the part numbers are the same. I'd guess they are the same, but I could be wrong.
Re: 1966 coronet to 70 dodge charger suspension swap??? [Re: Mr.Yuck] #1602316
04/08/14 11:32 AM
04/08/14 11:32 AM
fredericksburg,va
cudaman1969 Online sleepy
cudaman1969  Online Sleepy
fredericksburg,va
Does the 66 already have the 8 3/4 rear? If so just change springs and center section, nothing special about the Hemi or 440 rear.
Re: 1966 coronet to 70 dodge charger suspension swap??? [Re: cudaman1969] #1602317
04/08/14 03:34 PM
04/08/14 03:34 PM
Granite Bay CA
Kern Dog Offline
Kern Dog  Offline
Granite Bay CA
Good point. The 66 models still used the 8 3/4" axle, just the weaker 741 chunk. The housing and axle shafts are the same as they used for the higher HP cars.
Re: 1966 coronet to 70 dodge charger suspension swap??? [Re: Kern Dog] #1602318
04/14/14 01:31 AM
04/14/14 01:31 AM
MO
cdp Offline OP
cdp  Offline OP
MO
I'm not sure if its an 8-3/4 car or not. Slant 6 auto, with no power options including radio delete.
Car is only a few blocks away, and I've yet to buy it. Estate is still not quite settled, but I have my foot in the door on it first.
I'm hoping the rear is already in it. My gears are 323 open, but 489 case.
Re: 1966 coronet to 70 dodge charger suspension swap??? [Re: cdp] #1602319
04/14/14 02:52 AM
04/14/14 02:52 AM
Vallejo, CA
ditchdrift Offline
ditchdrift  Offline
Vallejo, CA
my slant 6, 3 speed, 66 belevedere had a 7 1/4 rear end. I would assume yours would too.
Re: 1966 coronet to 70 dodge charger suspension swap??? [Re: ditchdrift] #1602320
04/14/14 01:21 PM
04/14/14 01:21 PM
APACHE JUNCTION AZ
Joesixpack Offline
Joesixpack  Offline
APACHE JUNCTION AZ
all of that stuff will bolt right on.
my 66 6 had same stuff you got now, i swapped in 68 B-body V8 kframe, springs, 8 3/4,tbars etc
