Re: 1966 coronet to 70 dodge charger suspension swap???
[Re: Kern Dog]
#1602312
04/03/14 09:06 PM
04/03/14 09:06 PM
Posts: 3,691 MO
cdp
MO
thanks.
Yes, I have the whole K member assembly, sway bar, and upper, lower A-arms, spindles, disc brakes, etc.
Same with the rear. springs and rear, drum to drum.
[Re: cdp]
#1602315
04/07/14 06:58 PM
04/07/14 06:58 PM
Posts: 24,562 Brookeville, Md
Mr.Yuck
Brookeville, Md
are the rear springs usable also?
8 3/4 has the hemi springs on it. I was thinking they will work and the same as we put on my dads old hemi gtx.
measure them. Or you could go online to Mancini and see if the part numbers are the same. I'd guess they are the same, but I could be wrong.
[Re: Mr.Yuck]
#1602316
04/08/14 11:32 AM
04/08/14 11:32 AM
Posts: 8,273 fredericksburg,va
cudaman1969
fredericksburg,va
Does the 66 already have the 8 3/4 rear? If so just change springs and center section, nothing special about the Hemi or 440 rear.
[Re: cudaman1969]
#1602317
04/08/14 03:34 PM
04/08/14 03:34 PM
Posts: 18,493 Granite Bay CA
Kern Dog
Striving for excellence
Granite Bay CA
Good point. The 66 models still used the 8 3/4" axle, just the weaker 741 chunk. The housing and axle shafts are the same as they used for the higher HP cars.
