Page 1 of 3 1 2 3
My new motor 540 B1, Indy Maxx UPDATED pics motors in #1601509
03/31/14 10:17 PM
03/31/14 10:17 PM
SE Washington
Forest Offline OP
Forest  Offline OP
SE Washington
All this talk the last couple weeks about low deck builds. Figured I was far enough along with my build to show some pics...
So its a low deck Indy Maxx block 4.5" bore and a Callies 4.25" stroke crank. Callies Ultra h-beams, Diamond custom 14 to 1 pistons. Custom Push rod oil conversion and a 54mm cam core.
IMM built the the short with the oil mods, and set up the Koffels ported B1 Originals.
Should crack 900 HP and move my 2,500 lbs stratus along nicely compared to the small block.
I also converted the car to a glide and took some rear gear out of it. Motor should be in the car this week. I have headers yet to build, so hopefully that goes smooth and I can get to testing!
Re: My new motor 540 B1, Indy Maxx [Re: Forest] #1601510
03/31/14 10:27 PM
03/31/14 10:27 PM
NC
440Jim Offline
440Jim  Offline
NC
Wow, look at that custom lifter and cam lobe oiling system. Seems like a simple idea, but lots of little tubes and fittings.
With the B1 heads, that should make some power!
Looks like all new parts, even on the outside.
Is that the new, black hard anodized Milodon oil pump cover? (for external oil pickup lines and remote filter).
Re: My new motor 540 B1, Indy Maxx [Re: Forest] #1601511
03/31/14 10:28 PM
03/31/14 10:28 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Like the valley plate. Where can I get me one of those? Look forward to hearing the results.
Re: My new motor 540 B1, Indy Maxx [Re: Forest] #1601512
03/31/14 10:32 PM
03/31/14 10:32 PM
Renton Washington
Triple Threat Offline
Renton Washington
Get back to work, those headers wont build themselves!
Looking good Bud, cant wait to see it run.
-Dustin
67 Dart, 9 second, 392" G3 Hemi
68 Barracuda 340 F/SA
Re: My new motor 540 B1, Indy Maxx [Re: Al_Alguire] #1601513
03/31/14 10:38 PM
03/31/14 10:38 PM
SE Washington
Forest Offline OP
Forest  Offline OP
SE Washington
Pasco Machine, has been kind of a local sponsor for me on stuff like that. The built my Racepak mount, and do little things like that on the lathe or mill I need for the race car...
I am way excited to have some results too! Its been a long winter making all this come together!
Re: My new motor 540 B1, Indy Maxx [Re: 440Jim] #1601514
03/31/14 10:42 PM
03/31/14 10:42 PM
SE Washington
Forest Offline OP
Forest  Offline OP
SE Washington
Yes its all new, and yes that is the Milodon cover. I wanted to run the filter the conventional way but it just barely contacted my rack. I didn't want to run a smaller filter...
Re: My new motor 540 B1, Indy Maxx [Re: Forest] #1601515
03/31/14 10:43 PM
03/31/14 10:43 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Looks good... should make a some power... and push
a 2500# car nicely
Re: My new motor 540 B1, Indy Maxx [Re: MR_P_BODY] #1601516
03/31/14 10:53 PM
03/31/14 10:53 PM
On the parachute mount
N
n20mstr Online content
n20mstr  Online Content
N
Nice..... Where's the nitrous ?
Should run very well, even without it !
....BAD A$$ STREET CAR.....
Re: My new motor 540 B1, Indy Maxx [Re: n20mstr] #1601517
03/31/14 10:58 PM
03/31/14 10:58 PM
SE Washington
Forest Offline OP
Forest  Offline OP
SE Washington
See them stainless plugs in the intake...lol
Re: My new motor 540 B1, Indy Maxx [Re: Forest] #1601518
03/31/14 11:01 PM
03/31/14 11:01 PM
Q
Quicktree Offline
Quicktree  Offline
Q
WoW
Re: My new motor 540 B1, Indy Maxx [Re: Quicktree] #1601519
03/31/14 11:15 PM
03/31/14 11:15 PM
Trumbull,CT.
jim sciortino Offline
Trumbull,CT.
Good looking plant...
Re: My new motor 540 B1, Indy Maxx [Re: jim sciortino] #1601520
03/31/14 11:25 PM
03/31/14 11:25 PM
Puyallup, WA
StealthWedge67 Offline
Puyallup, WA
Looks great! Can't wait to see that one go!
Re: My new motor 540 B1, Indy Maxx [Re: Forest] #1601521
04/01/14 12:11 AM
04/01/14 12:11 AM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Looks great and someone`s goin really fast soon............thinkin maybe 8`s?
Re: My new motor 540 B1, Indy Maxx [Re: Thumperdart] #1601522
04/01/14 12:32 AM
04/01/14 12:32 AM
Salt Lake City
camastomcat Offline
camastomcat  Offline
Salt Lake City
Forest,
I'll be looking for you at Woodburn this year. That should get you in the mid to high 8's. I forget how much your car weighs? Hopefully I'll have the new Predator in the car, and running well.
Re: My new motor 540 B1, Indy Maxx [Re: camastomcat] #1601523
04/01/14 12:42 AM
04/01/14 12:42 AM
sccuda Offline
sccuda  Offline
Looks good Forest I see easy mid eights in you future if not quicker.
Re: My new motor 540 B1, Indy Maxx [Re: sccuda] #1601524
04/01/14 12:45 AM
04/01/14 12:45 AM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
Look GREAT. Should be a VERY nice combo.
Wallace Racing - ET/MPH/HP Calculator Weight is as the car sits on the line: driver and gas in it.
Calculate ET and MPH from HP and Weight
Weight HP
Your ET / MPH computed from your vehicle weight of 2500 pounds and HP of 900 is 8.19 seconds and MPH of 165.05 MPH.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: My new motor 540 B1, Indy Maxx [Re: Forest] #1601525
04/01/14 01:07 AM
04/01/14 01:07 AM
WA
JD Dart Offline
JD Dart  Offline
WA
Nice can't wait to see what it will run.
Re: My new motor 540 B1, Indy Maxx [Re: pittsburghracer] #1601526
04/01/14 01:16 AM
04/01/14 01:16 AM
aotearoa
rebel Offline
rebel  Offline
aotearoa
i see your valley plate is removable with the heads still in place, what are you proposing to use to seal along the flange face? on my Maxx block the valley plate is sandwiched under the heads so i had to use one of Andys removable inner plates to access the valley which works fine. On my Stage 6 head engine i had to bolt the valley plate to the flange face to stop it wanting to leak since it wasn't held like the Indy headed version even with a quality 3 Bond sealer.
Re: My new motor 540 B1, Indy Maxx [Re: JD Dart] #1601527
04/01/14 01:59 AM
04/01/14 01:59 AM
SE Washington
Forest Offline OP
Forest  Offline OP
SE Washington
Thanks everyone for the nice compliments! I will be happy with mid 8's, but wouldn't mid a lower eight.
Yes I plan to be at Woodburn for the Mopar Nats and hopefully again for the ET finals.
I used silicon on the beveled 1/4" plate, and am hoping that it is ridged enough to stay sealed...
Re: My new motor 540 B1, Indy Maxx [Re: Forest] #1601528
04/01/14 02:12 AM
04/01/14 02:12 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Once you get the chassis sorted out mid 8 wont be
a problem... I would expect low 8s easy
Page 1 of 3 1 2 3
