Re: Is my vapor separator my fuel filter ? [Re: RealWing] #1598145
03/25/14 11:37 PM
03/25/14 11:37 PM
Ontario, Canada
RealWing Offline
RealWing  Offline
Ontario, Canada
This is also a repro, but is correctly manufactured. Note markings on the can. The bogus one had no markings.
1970 Superbird 440-6bbl, auto
1969 Barracuda 340-4bbl, FB Formula S auto
1969 Barracuda 6.1 L Hemi, 5 speed, Convertible
2022 Can Am Spyder RTL
Re: Is my vapor separator my fuel filter ? [Re: RealWing] #1598146
03/25/14 11:37 PM
03/25/14 11:37 PM
Ontario, Canada
RealWing Offline
RealWing  Offline
Ontario, Canada
other end.
The return line was not orificed correctly. I soldered it closed and drilled a 0.040" hole- somewhat smaller than the factory size of approx. 0.060"
Re: Is my vapor separator my fuel filter ? [Re: RealWing] #1598147
03/25/14 11:39 PM
03/25/14 11:39 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
There are some bogus repro separators out there. I got one and could not figure out why the car would not start. Found that there was no orifice restriction in the return line and the fuel was going straight back to the tank and none going to the carbs
I cut it open to look inside. Surprise!! It was simply 3 tubes stuck into the can and there was no filter screen at all.
I see it IS a filter....just look at all of the metal shavings it captured
Re: Is my vapor separator my fuel filter ? [Re: A12] #1598148
03/26/14 12:04 AM
03/26/14 12:04 AM
RSNOMO Offline
Moparts Torchbearer
RSNOMO  Offline
Moparts Torchbearer
Imagine...
An incorrectly reproduced, reproduction part...
Re: Is my vapor separator my fuel filter ? [Re: RealWing] #1598149
03/26/14 12:42 AM
03/26/14 12:42 AM
New State
kidmopar Offline
kidmopar  Offline
New State
So ..... Who makes the better / best reproduction Vapor Separator vs the "junk" ones ?
Re: Is my vapor separator my fuel filter ? [Re: kidmopar] #1598150
03/26/14 02:09 PM
03/26/14 02:09 PM
Ontario, Canada
RealWing Offline
RealWing  Offline
Ontario, Canada
I got mine from Bill Allphin at the time. I suspect Bill Rolik will have the correct ones.
Re: Is my vapor separator my fuel filter ? [Re: RealWing] #1598151
03/26/14 03:05 PM
03/26/14 03:05 PM
California
mickm Offline
mickm  Offline
California
as far as being a filter, i ran just the vapor separator for years. i had the tops of the carbs off many times playing with jetting, and never once did i see any contamination in the bowls.
that doesn't mean there wasn't any, but i would assume if it wasn't doing it's job as a filter, at least to some degree, i would have seen some evidence of crud in the bowls.
Re: Is my vapor separator my fuel filter ? [Re: RealWing] #1598152
03/26/14 03:46 PM
03/26/14 03:46 PM
Ball Ground, Georgia
Dixie Offline
Dixie  Offline
We carry them as well, although I am out of stock at the moment. Should have some soon.
Dixie Restoration Parts
Phone -(770) 975-9898
Phone Hours: M-F 10am-5pm EST
website: www.dixierestorationparts.com
email: mail@dixierestorationparts.com
Veteran owned small business
The Best Parts at a Fair Price.
