Re: Is my vapor separator my fuel filter ?
[Re: RealWing]
#1598145
03/26/14 12:37 AM
03/26/14 12:37 AM
Posts: 315 Ontario, Canada
RealWing
Ontario, Canada
This is also a repro, but is correctly manufactured. Note markings on the can. The bogus one had no markings.
1970 Superbird 440-6bbl, auto 1969 Barracuda 340-4bbl, FB Formula S auto 1969 Barracuda 6.1 L Hemi, 5 speed, Convertible 2022 Can Am Spyder RTL
[Re: RealWing]
#1598146
03/26/14 12:37 AM
03/26/14 12:37 AM
RealWing
Ontario, Canada
other end. The return line was not orificed correctly. I soldered it closed and drilled a 0.040" hole- somewhat smaller than the factory size of approx. 0.060"
[Re: RealWing]
#1598147
03/26/14 12:39 AM
03/26/14 12:39 AM
Posts: 21,538 N.E. OHIO, USA
A12
N.E. OHIO, USA
There are some bogus repro separators out there. I got one and could not figure out why the car would not start. Found that there was no orifice restriction in the return line and the fuel was going straight back to the tank and none going to the carbs I cut it open to look inside. Surprise!! It was simply 3 tubes stuck into the can and there was no filter screen at all.
I see it IS a filter....just look at all of the metal shavings it captured
[Re: A12]
#1598148
03/26/14 01:04 AM
03/26/14 01:04 AM
RSNOMO
Moparts Torchbearer
Moparts Torchbearer
Imagine...
An incorrectly reproduced, reproduction part...
[Re: RealWing]
#1598149
03/26/14 01:42 AM
03/26/14 01:42 AM
Posts: 3,821 New State
kidmopar
New State
So ..... Who makes the better / best reproduction Vapor Separator vs the "junk" ones ?
[Re: RealWing]
#1598152
03/26/14 04:46 PM
03/26/14 04:46 PM
Posts: 2,336 Ball Ground, Georgia
Dixie
I got mine from Bill Allphin at the time. I suspect Bill Rolik will have the correct ones.
We carry them as well, although I am out of stock at the moment. Should have some soon.
