Is my vapor separator my fuel filter ? #1598125
03/25/14 12:15 AM
03/25/14 12:15 AM
california
Mr D21 Offline OP
Mr D21  Offline OP
california
Is my vapor separator my fuel filter? Do you OE guys run a hidden one somewhere ?
Re: Is my vapor separator my fuel filter ? [Re: Mr D21] #1598126
03/25/14 12:46 AM
03/25/14 12:46 AM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
the one I use or know of to come standard is NOT a fuel filter, no filter element inside that I'm aware of on a '69 440
Re: Is my vapor separator my fuel filter ? [Re: A12] #1598127
03/25/14 12:48 AM
03/25/14 12:48 AM
Warrenton, VA
RoadRunnerJD Offline
Warrenton, VA
The vapor separator is not a fuel filter.
Re: Is my vapor separator my fuel filter ? [Re: Mr D21] #1598128
03/25/14 10:03 AM
03/25/14 10:03 AM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Yes it is a filter, I use them as filters on both my cars.
I don't remember seeing a filter anywhere else on a 440 6 pack motor. I do remember seeing filters on a hemi, not sure about a hemi with a fuel pump mounted vapor separator?
Good question...
Re: Is my vapor separator my fuel filter ? [Re: Challenger 1] #1598129
03/25/14 11:32 AM
03/25/14 11:32 AM
Ohio
jlatessa Offline
jlatessa  Offline
Ohio
X2, it has a flat screen/mesh between the halves, I had one apart
long ago...Joe
Re: Is my vapor separator my fuel filter ? [Re: jlatessa] #1598130
03/25/14 11:36 AM
03/25/14 11:36 AM
Az
69hemibeep Offline
69hemibeep  Offline
Az
Its the only filter on my car. Wish there was room for another without cutting a line.
1969 Hemi Roadrunner 2nd owner
Re: Is my vapor separator my fuel filter ? [Re: 69hemibeep] #1598131
03/25/14 12:16 PM
03/25/14 12:16 PM
Ball Ground, Georgia
Dixie Offline
Dixie  Offline
I snuck one in between the metal fuel line from the tank and fuel pump. Not that my car is perfect "OE" correct, but I am going for a stock appearance. It's hard to see underneath the engine.
Dixie Restoration Parts
Phone -(770) 975-9898
Phone Hours: M-F 10am-5pm EST
website: www.dixierestorationparts.com
email: mail@dixierestorationparts.com
Veteran owned small business
The Best Parts at a Fair Price.
Re: Is my vapor separator my fuel filter ? [Re: Dixie] #1598132
03/25/14 12:18 PM
03/25/14 12:18 PM
Cincinnati, Ohio
Cincinnati, Ohio
That will cause vapor lock on hot days. You should not have a filter before the fuel pump. Strainer yes, filter no.
Re: Is my vapor separator my fuel filter ? [Re: Challenger 1] #1598133
03/25/14 12:28 PM
03/25/14 12:28 PM
Dixie Offline
Dixie  Offline
Well, if it does, I'll know the culprit!!
Re: Is my vapor separator my fuel filter ? [Re: Dixie] #1598134
03/25/14 02:01 PM
03/25/14 02:01 PM
Ky
jt4406 Offline
jt4406  Offline
Ky
My six pack set up has 3 of these in the carb bowls....
Yeah, it's hopped up to over 160...
Re: Is my vapor separator my fuel filter ? [Re: jt4406] #1598135
03/25/14 03:45 PM
03/25/14 03:45 PM
Cincinnati, Ohio
Cincinnati, Ohio
Re: Is my vapor separator my fuel filter ? [Re: Challenger 1] #1598136
03/25/14 05:40 PM
03/25/14 05:40 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
Good question...
so are ALL vapor separators fuel filters, I didn't think a MESH screen would filter fuel other than large chunks
Oh and BTW which model, engine and year are we talking about anyway?
Re: Is my vapor separator my fuel filter ? [Re: A12] #1598137
03/25/14 06:10 PM
03/25/14 06:10 PM
california
Mr D21 Offline OP
Mr D21  Offline OP
california
That's my point, I cant see the VS doing much to clean the fuel.
I was wondering if a filter before the pump hidden was a good idea - sounds like its not due to Vapor Lock potential.
70 Challenger - 440 / Carter
Re: Is my vapor separator my fuel filter ? [Re: Mr D21] #1598138
03/25/14 07:14 PM
03/25/14 07:14 PM
RSNOMO Offline
Moparts Torchbearer
RSNOMO  Offline
Moparts Torchbearer
A 'vapor separator' is not a 'fuel filter'...
I run the proper 'filter' in-line on a '71 B-body...
No 'Vapor' issues...
Re: Is my vapor separator my fuel filter ? [Re: RSNOMO] #1598139
03/25/14 07:56 PM
03/25/14 07:56 PM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
If memory serves me, 70, and 71 the VS was a 440/ Hemi thing, and did not get a separate filter. The service manual shows whats what, and which engine gets what.
Re: Is my vapor separator my fuel filter ? [Re: RSNOMO] #1598140
03/25/14 08:15 PM
03/25/14 08:15 PM
Home of the Bluegrass
MoparJunkie Offline
MoparJunkie  Offline
The service manual for 1970 Challenger shows a breakdown of the separator and they do call the screen a filter screen inside the vapor separator. And... 440's and Hemi's did get just a vapor separator. No inline filter from the factory other than the vapor separator's filtering capabilities.
"It takes a Mopar to catch a Mopar”
1971 Roadrunner FJ6 Sassy Grass 505"RB, 18 spline 4 speed, and Dana 60 with 3.54
2022 Hellcat Charger Widebody Redeye Jailbreak: Hellraisin with 8 speed auto
Re: Is my vapor separator my fuel filter ? [Re: MoparJunkie] #1598141
03/25/14 08:34 PM
03/25/14 08:34 PM
NB, Canada
moparfan53 Offline
moparfan53  Offline
NB, Canada
Yes, the separator was designed to be a fuel filter also. However some of the repros had wrong size or no orifices. Does anyone know if they have the correct filter screen?
Here is the complete info from the '70 FSM in case anyone wants to read the explanation/description. It also says how to check for a plugged filter screen.
Re: Is my vapor separator my fuel filter ? [Re: jt4406] #1598142
03/25/14 10:09 PM
03/25/14 10:09 PM
Warrenton, VA
Warrenton, VA
Mine has those too. They are the filters. Don't the Carter carbs have something similar in the carb inlet?
Re: Is my vapor separator my fuel filter ? [Re: RoadRunnerJD] #1598143
03/26/14 12:29 AM
03/26/14 12:29 AM
Ontario, Canada
RealWing Offline
RealWing  Offline
Ontario, Canada
There are some bogus repro separators out there. I got one and could not figure out why the car would not start. Found that there was no orifice restriction in the return line and the fuel was going straight back to the tank and none going to the carbs
I cut it open to look inside. Surprise!! It was simply 3 tubes stuck into the can and there was no filter screen at all.
1970 Superbird 440-6bbl, auto
1969 Barracuda 340-4bbl, FB Formula S auto
1969 Barracuda 6.1 L Hemi, 5 speed, Convertible
2022 Can Am Spyder RTL
Re: Is my vapor separator my fuel filter ? [Re: RealWing] #1598144
03/26/14 12:30 AM
03/26/14 12:30 AM
Ontario, Canada
RealWing Offline
RealWing  Offline
Ontario, Canada
Photo of the other end
