Re: Is my vapor separator my fuel filter ?
[Re: Mr D21]
#1598128
03/25/14 10:03 AM
03/25/14 10:03 AM
Challenger 1
Cincinnati, Ohio
Yes it is a filter, I use them as filters on both my cars. I don't remember seeing a filter anywhere else on a 440 6 pack motor. I do remember seeing filters on a hemi, not sure about a hemi with a fuel pump mounted vapor separator? Good question...
[Re: Dixie]
#1598132
03/25/14 12:18 PM
03/25/14 12:18 PM
Challenger 1
Cincinnati, Ohio
I snuck one in between the metal fuel line from the tank and fuel pump. Not that my car is perfect "OE" correct, but I am going for a stock appearance. It's hard to see underneath the engine.
That will cause vapor lock on hot days. You should not have a filter before the fuel pump. Strainer yes, filter no.
[Re: Challenger 1]
#1598133
03/25/14 12:28 PM
03/25/14 12:28 PM
Posts: 2,336 Ball Ground, Georgia
Dixie
Well, if it does, I'll know the culprit!!
[Re: Dixie]
#1598134
03/25/14 02:01 PM
03/25/14 02:01 PM
Posts: 1,567 Ky
jt4406
Ky
My six pack set up has 3 of these in the carb bowls....
Yeah, it's hopped up to over 160...
[Re: Challenger 1]
#1598136
03/25/14 05:40 PM
03/25/14 05:40 PM
Posts: 21,538 N.E. OHIO, USA
A12
N.E. OHIO, USA
Good question...
so are ALL vapor separators fuel filters, I didn't think a MESH screen would filter fuel other than large chunks
Oh and BTW which model, engine and year are we talking about anyway?
[Re: RSNOMO]
#1598140
03/25/14 08:15 PM
03/25/14 08:15 PM
Posts: 1,132 Home of the Bluegrass
MoparJunkie
"It takes a Mopar to catch a Mopar” 1971 Roadrunner FJ6 Sassy Grass 505"RB, 18 spline 4 speed, and Dana 60 with 3.54 2022 Hellcat Charger Widebody Redeye Jailbreak: Hellraisin with 8 speed auto
[Re: jt4406]
#1598142
03/25/14 10:09 PM
03/25/14 10:09 PM
Posts: 5,123 Warrenton, VA
RoadRunnerJD
Warrenton, VA
Mine has those too. They are the filters. Don't the Carter carbs have something similar in the carb inlet?
[Re: RoadRunnerJD]
#1598143
03/26/14 12:29 AM
03/26/14 12:29 AM
Posts: 315 Ontario, Canada
RealWing
Ontario, Canada
There are some bogus repro separators out there. I got one and could not figure out why the car would not start. Found that there was no orifice restriction in the return line and the fuel was going straight back to the tank and none going to the carbs I cut it open to look inside. Surprise!! It was simply 3 tubes stuck into the can and there was no filter screen at all.
1970 Superbird 440-6bbl, auto 1969 Barracuda 340-4bbl, FB Formula S auto 1969 Barracuda 6.1 L Hemi, 5 speed, Convertible 2022 Can Am Spyder RTL
