Re: In your opinion, who has the best combustion chamber?
[Re: hudsonhornet7x]
#1598081
03/25/14 01:17 AM
03/25/14 01:17 AM
Posts: 10,011 Frostbitefalls MN (Rocky&Bullw...
gregsdart
I am partial to the Indy stuff, based on the wide spread you can use the various heads on. Anything from a 361 to a 604. Small ports, bigger ports, stock placement exhaust port versions for A bodys, combustion chambers can be sized to work with a variety of engine sizes for pump gas and flat or dished pistons.
#1598083
03/25/14 10:50 AM
03/25/14 10:50 AM
Posts: 52,972 Romeo MI
MR_P_BODY
I would think it would be the head with the highest volumetric efficiency .... I'm not a BB guy so I cant really say which is better
[Re: MR_P_BODY]
#1598084
03/25/14 11:19 AM
03/25/14 11:19 AM
Posts: 2,933 Finalnd, Perkele
jyrki
Finalnd, Perkele
I think most of them are decent, it's way easier to say which are worst; RPM and 440 source. But Indys and Victors both have pretty nice chambers, haven't used BS's so really can't say. But I guess they are good too, although small.
Plynouth VIP '67 TT IC EFI
[Re: jyrki]
#1598085
03/25/14 11:25 AM
03/25/14 11:25 AM
gregsdart
When you think about it, there is a reason to pick any of the heads mentioned, depending on what your intended build is. I believe the B1bs heads have the smallest as cast chambers? The RPMs are a good standard port head, the Stealths are for a tight budget, an the Victors kind of fill a gap between the SRs and 440-1? So if you are thinking of a certain motor combo, guys could be more specific.
#1598088
03/25/14 12:25 PM
03/25/14 12:25 PM
chrysler 426 street hemi cylinder head is the best.
#1598090
03/25/14 12:52 PM
03/25/14 12:52 PM
Posts: 5,163 CT
GTX MATT
CT
Okay, how about this: if someone had a nice 440, stock stroke and went from 84cc rpm heads to victor heads ( both standard opening), what could you expect?
Depends on the rest of the combo, whats the rest of the build? Are they both out of the box? The Victors look like a REAL nice head, especially for what they cost. The combustion chamber on the Victors are certainly better than the RPMs, which are probably the worst of the aftermarket heads available in a tie with the Stealths. But the difference in flow is what I'd be more excited about.
[Re: FastmOp]
#1598091
03/25/14 09:19 PM
03/25/14 09:19 PM
Posts: 1,267 North, Alabama
D-50
North, Alabama
Gen 3 Hemi
I agree............
1.33 60 ft,6.21 at 110.59 in the 1/8, pump gas small block,2950lbs,drag radials,mufflers and driven to track ...
