In your opinion, who has the best combustion chamber? #1598080
03/24/14 11:18 PM
03/24/14 11:18 PM
USA
hudsonhornet7x Offline OP
USA
If you were to compare all of the current big block heads( not including B1, Predator), who has the best combustion chamber design?
Take into consideration that the typical street/ strip car would use these heads on a daily basis.
I have always wondered this and I am not knowledgeable enough on heads to form an opinion.
Thanks!
Re: In your opinion, who has the best combustion chamber? [Re: hudsonhornet7x] #1598081
03/25/14 01:17 AM
03/25/14 01:17 AM
gregsdart Offline
gregsdart  Offline
I am partial to the Indy stuff, based on the wide spread you can use the various heads on. Anything from a 361 to a 604. Small ports, bigger ports, stock placement exhaust port versions for A bodys, combustion chambers can be sized to work with a variety of engine sizes for pump gas and flat or dished pistons.
Re: In your opinion, who has the best combustion chamber? [Re: hudsonhornet7x] #1598082
03/25/14 03:01 AM
03/25/14 03:01 AM
IL
E
EchoSixMike Offline
EchoSixMike  Offline
E
IL
Strictly combustion chamber? B-1BS. S/F....Ken M
Re: In your opinion, who has the best combustion chamber? [Re: hudsonhornet7x] #1598083
03/25/14 10:50 AM
03/25/14 10:50 AM
MR_P_BODY Offline
MR_P_BODY  Offline
I would think it would be the head with the highest
volumetric efficiency .... I'm not a BB guy so I
cant really say which is better
Re: In your opinion, who has the best combustion chamber? [Re: MR_P_BODY] #1598084
03/25/14 11:19 AM
03/25/14 11:19 AM
Finalnd, Perkele
jyrki Offline
jyrki  Offline
Finalnd, Perkele
I think most of them are decent, it's way easier to say which are worst; RPM and 440 source. But Indys and Victors both have pretty nice chambers, haven't used BS's so really can't say. But I guess they are good too, although small.
Plynouth VIP '67 TT IC EFI
Re: In your opinion, who has the best combustion chamber? [Re: jyrki] #1598085
03/25/14 11:25 AM
03/25/14 11:25 AM
gregsdart Offline
gregsdart  Offline
When you think about it, there is a reason to pick any of the heads mentioned, depending on what your intended build is. I believe the B1bs heads have the smallest as cast chambers? The RPMs are a good standard port head, the Stealths are for a tight budget, an the Victors kind of fill a gap between the SRs and 440-1? So if you are thinking of a certain motor combo, guys could be more specific.
Re: In your opinion, who has the best combustion chamber? [Re: gregsdart] #1598086
03/25/14 11:42 AM
03/25/14 11:42 AM
USA
USA
I didn't have a certain motor combination in mind, I was just thinking about modern style heads for the big block.
Re: In your opinion, who has the best combustion chamber? [Re: hudsonhornet7x] #1598087
03/25/14 12:07 PM
03/25/14 12:07 PM
USA
USA
Okay, how about this: if someone had a nice 440, stock stroke and went from 84cc rpm heads to victor heads ( both standard opening), what could you expect?
Re: In your opinion, who has the best combustion chamber? [Re: hudsonhornet7x] #1598088
03/25/14 12:25 PM
03/25/14 12:25 PM
chrysler 426 street hemi cylinder head is the best.
Re: In your opinion, who has the best combustion chamber? [Re: ] #1598089
03/25/14 12:50 PM
03/25/14 12:50 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
Gen 3 Hemi
Re: In your opinion, who has the best combustion chamber? [Re: hudsonhornet7x] #1598090
03/25/14 12:52 PM
03/25/14 12:52 PM
CT
GTX MATT Offline
GTX MATT  Offline
CT
Depends on the rest of the combo, whats the rest of the build? Are they both out of the box? The Victors look like a REAL nice head, especially for what they cost. The combustion chamber on the Victors are certainly better than the RPMs, which are probably the worst of the aftermarket heads available in a tie with the Stealths. But the difference in flow is what I'd be more excited about.
Re: In your opinion, who has the best combustion chamber? [Re: FastmOp] #1598091
03/25/14 09:19 PM
03/25/14 09:19 PM
North, Alabama
D-50 Offline
D-50  Offline
North, Alabama
Gen 3 Hemi
I agree............
1.33 60 ft,6.21 at 110.59 in the 1/8, pump gas small block,2950lbs,drag radials,mufflers and driven to track ...
Re: In your opinion, who has the best combustion chamber? [Re: D-50] #1598092
03/25/14 09:22 PM
03/25/14 09:22 PM
dogdays Offline
dogdays  Offline
Look at the latest NASCAR combustion chambers, they would be state-of-the-art for a two-valve design. Then find the head that most closely replicates those. IMHO they pretty much all look the same, between the four engines.
R.
Re: In your opinion, who has the best combustion chamber? [Re: dogdays] #1598093
03/25/14 10:49 PM
03/25/14 10:49 PM
Trumbull,CT.
jim sciortino Offline
Trumbull,CT.
All current out of the box chambers offered for the wedge MOPAR, except the Predator and custom PSO stuff are outdated and inefficient.
There are no exceptions, as ALL manufacturers of these heads.....Indy and Edelbrock included, obviously doesn't care about modernizing their designs for the MOPAR crowd.
Re: In your opinion, who has the best combustion chamber? [Re: jim sciortino] #1598094
03/25/14 11:19 PM
03/25/14 11:19 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
I hear ya and agree and plan on someday replacing my e-brock rpm junk w/some good heads and intake THEN this puppy will fly..........
Re: In your opinion, who has the best combustion chamber? [Re: jim sciortino] #1598095
03/25/14 11:59 PM
03/25/14 11:59 PM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
Hemi 99
Brett Miller W9 cnc'd heads
STR Chassis fabraction
Re: In your opinion, who has the best combustion chamber? [Re: 1967dartgt] #1598096
03/26/14 12:21 AM
03/26/14 12:21 AM
PA.
pittsburghracer Online work
"Little"John
pittsburghracer  Online Work
"Little"John
PA.
Some of the suggested heads and chambers would be GREAT but just remember some of these come at a cost, RPM. And RPM costs lots of MONEY. And lots of Mopar racers have MONEY but don't like to spend MONEY.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: In your opinion, who has the best combustion chamber? [Re: 1967dartgt] #1598097
03/26/14 07:34 AM
03/26/14 07:34 AM
LONG ISLAND
fishy340 Offline
fishy340  Offline
LONG ISLAND
My W9 done by Brett and touched/softened by Slawko
Re: In your opinion, who has the best combustion chamber? [Re: fishy340] #1598098
03/26/14 08:39 AM
03/26/14 08:39 AM
jersey
Spaceman Spiff Offline
jersey
Poly head....
526 cubes of angry wedge, pushbutton shifted, 9 passenger killer!
Re: In your opinion, who has the best combustion chamber? [Re: Spaceman Spiff] #1598099
03/26/14 09:53 AM
03/26/14 09:53 AM
IL
E
EchoSixMike Offline
EchoSixMike  Offline
E
IL
The OP said big block and eliminated all the serious race stuff. He also just asked about combustion chambers, which is sort of odd, when there's other things much more pertinent to making power. The BS comes in about 65cc and when CNC'd about 75, which is about where you want to be with a flat top piston.
AFAIK, none of the common Mopar heads come with semi finished chambers so they can be properly CNC machined, as is SOP with serious stuff, but the BS is probably best suited to this, for the reasons I mentioned.
Would that be what I recommend? No, I have a set of Victors for the engine that's going to the step down from the B-1. That would be my suggestion at present. S/F....Ken M
