Re: help. light weight master cylinder
[Re: POZEST]
#1597938
03/24/14 07:37 PM
03/24/14 07:37 PM
Posts: 2,422 Pittsburgh PA
Eric
Pittsburgh PA
Take a look at one from a K car. If I remember correctly that might work.
5.53 @ 125 1/8th on the launch control..more left in her!
[Re: mopar65]
#1597943
03/24/14 09:51 PM
03/24/14 09:51 PM
Posts: 2,475 SW Ohio
cgall
SW Ohio
[Re: cgall]
#1597944
03/24/14 09:56 PM
03/24/14 09:56 PM
Posts: 1,942 Metro Detroit
OUTLAWD
Metro Detroit
Mine was off a mid to late 80s half ton truck IIRC
Faster, Faster until the thrill of speed overcomes the fear of death...
71 Swinger - slowly collecting dust/parts 66 Belv. II - just a streetcar 88 Mustang - turbo LS beater
[Re: cgall]
#1597945
03/24/14 10:00 PM
03/24/14 10:00 PM
Posts: 52,972 Romeo MI
MR_P_BODY
I will guarantee he gets the Summit one before the others... but if he is close enough he can pick it up.. if he orders it early enough in the morning(6-7 am) he will have it that day... at least I do and he is a lot closer
[Re: clyde]
#1597949
03/26/14 02:59 AM
03/26/14 02:59 AM
Posts: 8,889 Ontario, Canada
Stanton
Don't question me!
Don't question me!
Ontario, Canada
Mancini's carry that little rubber piece. I know of no other place. Surprising because its junk once you pull the pushrod out! But some guys on here have used thin rubber or vinyl hose. All it does is stop the pushrod from wobbling around in the cup. http://chucker54.stores.yahoo.net/brpubu.html
[Re: Stanton]
#1597951
03/26/14 12:17 PM
03/26/14 12:17 PM
MR_P_BODY
If thats the piece I think it is.. it looks like it.. but that is to keep the push rod in the master.. it can be a real PITA to get it out... it snaps in place with the push rod... was for safety so the rod couldnt slip out
[Re: POZEST]
#1597953
03/28/14 07:49 AM
03/28/14 07:49 AM
Posts: 2,709 NJ central
Scamp408
NJ central
Ended up with a mc for a 85 Dodge diplomat, seemed like the same bore as a stock demon. Thanks prochamp for running all the numbers and rbduster for the actual sale. Mc didn't come with the retaining bushing so it was made with a piece of vacuum line. Feels good and solid. Thanks for the ideas fellas.
Was it aluminum or cast iron?
[Re: POZEST]
#1597955
03/31/14 03:46 PM
03/31/14 03:46 PM
Posts: 9,910 Eighty Four, PA
B G Racing
Eighty Four, PA
Just get a Wilwood,Aerospace or Strange kit,they have everything you need.Wilwood kit-260-4894,Aerospace-MBC7993,Strange-3359 or 3360.Wilwood and Strange are aprox,$100 and you get fittings,rod and boots,rubber retainer and a couple of plate adapter/spacers.
